Question about Saeco Magic De Luxe Espresso Machine
Coffeee beans won't feed into grinder
The coffee machine ran out of beans as the machine was grinding and now the grinder will not grind beans, even though the machine now has beans in the container. The message comes up that the container has no beans.
  • 1 more comment
  • hwang_ho May 05, 2009
    same problem, what I do is that I push the beans into the grinder with a little can, letting go and pushing in . it´s a complete mess. I do not like that
  • Anonymous Mar 14, 2014
    the machine grinds the coffee beans but does not brew the coffee. It also does the same when using already grounded coffee. When you look n the used coffee container you see the un used coffee grinds. can you suggest how to fix the problem?
  • Anonymous Mar 17, 2014
    The machine has stopped grinding the beans
  • 29 Answers
Push the coffe brew button again. It should take right off and grind again.
Posted on Jul 27, 2007
  • Tom Corkill
    Tom Corkill Jul 31, 2007
    OK,
    If the grinder does not take off after "timing out" by pressing the coffee selection then I need to know if there are other warning lights on. If it does not take off after timing out by pressing the coffee button and there are no other warning lights on then there is an electrical problem that a repair center would need to address.
    Do a search for an authorized Saeco repair center and discuss it with them.
I have a saeco royal my machine is grinding beans but will not stop
Your question is not right.
Grinder stops on its own in 16 to 18 seconds (times out).
It may not be grinding beans an spinning free because the beans are not feeding.
You may have used oily beans or set the grind fineness at very fine powder like. This powder like fineness also clogs the grinder..
You need to clean the grinding chamber and the ground coffee outlet.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
Dec 19, 2016 | Saeco Coffee Makers & Espresso Machines
Just bought a mazzer super jolly grinder, used it once, the grind was too coarse (#6), adjusted it to a finer grind ((3), and the next time i ran it it stopped grinding, the motor is on, the grinder turns,...
yes, you have to remove the beans inside because there is beans stuck between the burrs. after removing the beans, start doing the finest first before loading the hopper then after putting the beans test the grind as you go courser.
Feb 11, 2012 | Mazzer Coffee-grinder SUPER JOLLY Electric
Does not grind beans
This can be caused from a broken by a brken grinder motor or even broken grinder sensor.
However this can be cased by a stuck grinder from grinded coffee to the grinder bledes. So you try from the last posible problem by removing all the coffee beans from the machine and by the use of a vacum cleaner try to **** all the remainings both beans and grinded coffee. If you can remove the top panel then you will have access more direct to the grinder and by the use of painting brush and vacum cleaner you will be able to clean the grinding blades mere intesive. Try to rotate the blade manualy to be sure that they can run after the cleaning.
So now you will be able to add some beans and try the machine again. If the probelm remains then you will need a new motor.
Good luck.
Please emeber to vote for this answer
Mar 13, 2010 | Saeco Easy Espresso Machine
I have a gaggia syncrony logic.The coffee beans are not going to the grinder so the grinder is just spinning,we have cleaned the machine and cant tell if something is stuck in it or what. cand you help?
This fixes almost all the "beans will not feed or beans will not grind" problems caused by coffee bean dust packed in the burrs. Oily beans cause this problem more fequently.
a. Pour all the beans out the top.
b. Open the settings up all the way and see what else can be poured out. Use your shop vacuum to **** grounds out the spout and backward out the bean bin.
c. Pour in some instant rice and start grinding. Reduce the grind to a small setting like six and then open the settings all the way again. (The grinder will not start at a low setting with the rice in it. If you let it stop, open the settings to about 16 before trying to restart.)
d. Pour out the rice and vacuum out the ground rice.
e. Adjust the grinder to your favorite setting and try a coffee grind. Grind until most of the rice dust is expelled (any remaining trace of rice dust will not affect the flavor of the coffee).
Oct 27, 2009 | Coffee Makers & Espresso Machines
I bought new green coffee beans recently, roasted it myself and wanted to use it in the machine but the grinder gets stuck and won't turn. The new beans are harder and smaller than the type I used to have....
Oct 21, 2009 | Gaggia Paros Espresso Machine
Beans are too oily
Aug 06, 2009 | Bosch Benvenuto B30 Espresso/Coffee Maker
I have a Divina Deluxe and the coffee grinder is moving but it does not appear to be grinding it justs runs until the cycle stops. The machine turns on and gets ready but not grind. I have opened it up and...
Remove brew unit and check the grounds chute from the grinder, if that is clear, then re-insert unit, then when the grinder is grinding adjust to a coarser grind.
May 31, 2009 | Spidem Divina De Luxe Espresso & Coffee...
After grinding no coffeee comes out
If you open the steam knob and make a cup of water (the), can you get any water comes that way?
If not then i think you have calcium in the system.
If the grinder goes for long time it can be oily beans or if you get damp into the grinder.
Let me know if you need more help.
Best regards
/Mirran
Jan 17, 2009 | Coffee Makers & Espresso Machines
Machine will not grind beans.
I had the same problem and Saeco recommended that I clean the grinder. Check this link for instructions.http://saecooutlet.com/instructions/Grinder%20Cleaning_Magics_Royals.pdf
Jul 15, 2007 | Saeco Royal Professional Espresso Machine
Saeco Magic De Luxe Espresso Machine Logo
941 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Ray Murphy
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
