Question about Lexmark T650n Laser Printer
935.17 service printhead error in lexmark t650n printer
  • 412 Answers
SOURCE: 931.01 Printhead Service Error
there is a Printhead error - No first sync
Posted on Mar 09, 2009
SOURCE: 900 service error with lexmark printer
OK, a couple of things... Some earlier Lexmark units had code on both a RIP board (raster image
processor) and an engine board. In this case, the code would have to be reloaded into both
boards. Fortunately, this can be done even if the printer will not boot to a ready state. However, if
this has already been done sucessfuly, the problem may well not be the printer but rather something
in the data stream. To confirm this, remove any and all data cables and reboot the printer. If it comes ready and you can print all the internal pages including the network config pages, then it is likely the
problem is the data stream. One must be careful when the printer is controlled by a print server
because the end user may not have control over the print que. If a corrupt or printer incomprehensible
job is stuck in the que, the printer will go to a 900 condition as soon as the network interface
initializes. This will continue until the print que is cleared.
Hope this helps...
Sean.
Posted on May 01, 2009
  • 300 Answers
SOURCE: Lexmark Colour C752 108 service printhead error
You are correct, Below is that section from the manual. Before you follow this, i've found in the past that the cable connector is not seated properly on the rip board, so check this first.
If you require any of the instructions on replacing the printhead or board let me know.
Yellow Printhead Lost Hsync
Check for the correct installation of the all the cables to the RIP
Board assembly and to the Printhead assembly; J2, J3, and J4 on
the RIP Board. Go to “RIP Board” on page 5-11. If the cables are
connected correctly to the RIP Board and to the Printhead
assembly, replace the following FRU:
“RIP Board” on page 4-11
If this does not fix the problem replace:
Yellow Printhead Assembly - Go to “Printheads” on page 4-33.
Note: Whenever a printhead assembly is replaced, it is necessary
to perform the “Printhead Adjustments” on page 4-1.
Posted on Jun 03, 2008
wyomork
  • 3 Answers
SOURCE: Lexmark C752 108 Printhead error
They mean the respective printheads have lost the HSynch.  The first thing the we do (and have had great success with) is to clean the laser lenses.  Then check the head wiring.  The following codes apply:
106 & 110 CYAN 107 & 111 MAGENTA 108 & 112 YELLOW 109 & 113 BLACK
Posted on Apr 27, 2009
brett207
  • 231 Answers
SOURCE: how can i solve this problem? 935.10 service
This is a service error, which will need a technician to diagnose and repair.
Probably a faulty laser scanner assembly.
Posted on Dec 07, 2009
Lexmark T650n has a flashing red light and will not print
Are there any error messages on the screen. I have access to Lexmark service manuals but need more details to help you with this.
Mar 15, 2013 | Lexmark T650n Laser Printer
How can i set paper size to A4 in printer of model lexmark T650n
The paper size is set in SOFTWARE, the printer is essentially a slave...Change the paper size and type (like photo paper) in your software, like Word.
Mar 18, 2011 | Lexmark T650n Laser Printer
I have an error on my Lexmark T632 printer saying 933 service printhead error, can you tell me what this means
Printhead error message indicates that the printhead (laser scanner) unit inside the printer is not working correctly.
First step trying to fix this is to turn printer off, and back on after 10 seconds. If this won't clear it, try and plug the printer in a different power point straight into the wall. If the error does not clear, the printer will probably require service to correct the issue.
Sep 28, 2010 | Lexmark Optra T610 Laser Printer
It will not print and is reading 935.15 Service Printhead Error what do i need to do to fix this?
Here's an article in the Lexmark website on A Printhead Error Is Appearing on a Lexmark E250d(n), E350d, E352dn, or E450dn Printer. Just click on this link: http://bit.ly/9GQzbO. If all else fails, it may require service. I would also suggest you replace the power supply.
Jun 20, 2010 | Lexmark E450dn Laser Printer
How to I factory rest lexmark t650n printer
You can reset the Lexmark T650n to factory defaults in two ways:
A. Press Menu > go to Settings > General Settings > choose Factory Defaults
B. Go to Configuration mode by pressing and holding down Select button (check mark) and right arrow button while powering on the printer. It should display config mode. Choose Factory Defaults. Then power cycle the printer.
Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
May 27, 2010 | Lexmark T650DTN Laser - Monochrome Laser -...
JUST INSTALL MY NEW PRINTER, LEXMARK C540 SERIES, I KEEP GETTING A ERROR MESSAGE THAT READS 100.08 SERVICE PRINTHEAD ERROR. WHAT DOES THIS MEAN PLEASE? I HAVE INSTALLED AND UNINSTALLED TO REINSTALL. THE...
Most of the time the problem can be resolved by reseating the printhead cable which can be accessed by opening the back cover of the printer. If that won't resolve the problem, I recommend to have it serviced. It's a possible defective printhead.
Apr 29, 2010 | Lexmark C543dn 26B0000 Workgroup Up to 21...
The T650n printer is displaying in Chinese? I
Make sure to follow these instructions carefully. Make sure that your printer is on ready. If you're not sure, you can turn it off and on again. Once ready, press Menu button ONCE, UP Button ONCE, Check Button 4 times. That should set it to English.
Mar 30, 2010 | Lexmark T650n Laser Printer
I have a Lexmark E450dn displaying a "935.15 Service Printhead" error message and will not print. Seeing as Laser Printers do not have printheads, instead they have Scanners and Fusers, which should I be...
a 935 printhead error is a fatal error which means the scanner motor has failed to initialize. the term printhead is short for printhead scanner. this error can be caused by either the engine board or the scanner % wise 40%engine board 60% scanner ive done 120 repairs on lexmark laser for the last 7 years trust me one of these is the problem
Jun 16, 2009 | Lexmark E450dn Laser Printer
Dec 21, 2008 | Lexmark X342n All-In-One Laser Printer
Lexmark C510 - 930 Printhead Error
93x Printhead Error
Each printhead error has its own error code number. The error codes and their respective meanings are listed below, together with some actions you can take to resolve the problem.
ALL printhead errors:
If this is the first time the error has occurred, try turning the printer off and on.
Let it sit turned off for at least 20 seconds before powering it back on.
If powering off and on the printer clears the error, please continue using the printer but watch it to see if any printhead errors return.
If your printer continues to display a Printhead Error message, make sure it is plugged straight to the wall and not through a surge device or power strip. Power strips and uninterrupted power supplies can cause a low amperage problem in your printer. This can trigger a printhead error even if the printer has worked on this surge device for months.
If the printer continues to post a 930 Printhead Error, it thinks the wrong printhead unit is installed.
If the printer was recently serviced, make sure the correct parts were used. This is especially true if the parts replaced were either the printhead unit or the printer's engine/system board. It is in one of these two parts that the printer is detecting the problem. Note: If you are the person repairing such a printer, please be aware that parts from different, though similar, printer models may not be compatible with this printer. Also make sure to check the laser cable going from the printer's engine board to the printhead unit, as it reads that signal.
If the printer was not recently serviced before this error occurred and powering the printer off and on does not help, the printhead unit and possibly the laser cable or the engine/system board to this printer may need to be replaced.
If the printer continues to post a 931 Printhead Error, it thinks there is an error in the signal going to the laser or the Hsync part of the printhead assembly.
If the printer continues to post a 932 Printhead Error, it thinks there is an Hsync error occurring in the printhead assembly.
If the printer continues to post a 933 Printhead Error, it thinks there is a failure in either the Hsync signal or with the mirror motor unit of the printhead.
If the printer continues to post a 934 Printhead Error, it thinks there is a "lock" failure with the mirror motor assembly within the printhead assembly.
If the printer continues to post a 935 Printhead Error, it thinks the mirror motor unit within the printhead unit cannot reach its operating speed.
If powering the printer off and on does not clear any of these errors and it is already connected directly to the wall, your printer may require service. It could have a defective printhead unit or there might be a problem with the engine board or one of the printhead cables. Note: If you are the person repairing such a printer, check all of the cables going from the printer's engine board to the printhead unit for any damage. Also check the continuity across these cables.
Source: Lexmark KnowledgeBase
Jul 28, 2008 | Lexmark C510 Laser Printer
Lexmark T650n Laser Printer Logo
2,259 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
