Question about Haier HLP21E Top Load Washer
Out of balance switch
After and out of balance problem it would not spin again need to know where the out of balance switch is
  • mloskot54
    mloskot54 Jan 20, 2013
    the switch is located in back of the lid let side and is used to turn off machine when lid is lifted as well. But in this case it was the electronic switch consol
  • 35 Answers
Safety switch, usually has red wires with white stripes. Disconnect power plug from wall outlet before working or touching parts protected by outer cabinet.
Posted on Oct 15, 2013
Why does my washer agitate for two minutes, then stop and beep for ten minutes?
IS THIS A MAYTAG? DO U KNOW IF THIS MODEL HAS AN INERTIA BALANCE SWITCH IT MAY BE OUT? BUT IT USUALLY SHUTS DOWN DURING SPIN NOT WASH?
UR ISSUE SEEMS TO INDICATE YOUR HAVING BALANCE ISSUES. SORRY CANT BE MUCH MORE HELP AND YES IT MAY BE IN THE BOARD OR ELSEWHERE, WILL NEED MORE INFORMATION TO TRY AND DIAGNOSE FOR U
May 23, 2015 | Washing Machines
FAV6800AWW won't spin without going out of balance
Each of the legs supporting the washer need to be adjusted and the washer leveled. You will need a Level with bubble indicators to see the exact position of the liquid within & it is in the center of the glass container. Level front to back and side to side. When done the washer should be level at all 4 sides and it will not move around and cause the level indicators to trip any switches.
Mar 05, 2014 | Maytag Neptune FAV6800AW Top Load Washer
Spins out of balance even emty
http://www.askmehelpdesk.com/plumbing/whirlpool-out-balance-spin-cycle-18991.html
http://fixitnow.com/sbrvrs/washers.htm
http://www.repairclinic.com/Washing-Machine-Troubleshooting
This model of washer does not have an out of balance cut off switch. If the load is not balanced properly the tub could hit the cabinet sides. If the unit spins evenly while empty & out of balance while loaded, I recommend checking & balancing the load. If the basket spins out of balance while empty, I recommend having the suspension springs & balance ring checked. Be sure not to wash light fabric with heavy fabric clothes. Also ensure that the adjustable feet are level, that's most important.
Aug 01, 2010 | Kenmore 24032\24036 Top Load Washer
I have a FMC computer tire balancer mod 2500 but I
CAL SULG SCREWED IN THE BACK BY ON OFF SWITCH.PUSH F1 SPIN SCREW SLUG ON THEN SPIN IT SLOUD SAY 0 THEN REMOVE SLUG AND SPIN THEN IT SHOULD SAY CAL GOOD.NEED MORE INFO I HAVE THAT BALANCER 2500 BEEN USING IT 1980 ITS THE BEST.SNAP-ON STILL FIXES IT CJAUTOREPAIR@OPTIMUM.NET
Mar 07, 2010 | Computers & Internet
I have a Maytag LAT2500AAE top load washer. The
check the balance ring on the tub just below the tub cover and tub cover gasket which can be done from the top of the machine by removing the top cover,while doing this pull and push tub from side to side and see if it moves easier in certain directions, if it does you may have a tub spring broken on the tub leading to an un balance condition cause the springs stabilize the tub like a shock absorber on an auto, if this is it then you need to access the lower unit area by removing the front cover of the unit there are screws at the toe kick panel to remove this panel
Dec 08, 2009 | Kenmore 24032\24036 Top Load Washer
Washing machine wont spin the water out.
IT IS VERY POSSIBLE THAT YOU HAVE A BAD OUT OF BALANCE SWITCH. THE MACHINE WILL NOT GO INTO A HIGH SPEED SPIN IF THE SWITCH IS BAD.
Mar 18, 2009 | Fisher Paykel EcoSmart GWL15
Knocking sound in the spin cycle off balance.
The motor switch that is mounted on the motor may need replacing. The knocking could mean that the "run" winding is cutting off momentarily, and running on the "start" winding of the motor. I dont know about a 22 year old model, but in most "near modern" machines, the switch has a plastic actuator that is pushed when the motor obtains near-run speed, that plastic may be worn or the actuator part on the motor may be at fault. If you replace the motor, you usually get this switch as part of the deal.
Feb 05, 2009 | Maytag Washing Machines
Extra Spin cycle?
(I know this is an old question, but its probably a common question for new owners - including me a couple of weeks ago...)
Power the unit back on, press the spin speed button and it will select the "drain and spin" cycle. Pressing the spin speed button again will select different spin speeds as well as just "drain".
Something you might try instead of medium spin speed is to turn on "SpinSense". To turn this on (and off), press and hold the "Stain Cycle" button for 3 seconds while any wash program is in process.
What SpinSense does is measure the imbalance by doing a very slow spin before cranking the spin speed up (and measuring how constant the very low spin speed is). If the balance is out too much, it will stop, let the clothes drop, and then try another slow spin. It will try this over and over many times until the balance is decent. Then it will let it rip. It makes a huge difference, but it can spend a lot of time getting a good balance some times.
SpinSense also seems to be able to detect if the machine is shaking terribly, shut the spin down and try again.
Our LG 2688 is on our 1st floor (wooden floor). Without SpinSense, the vibration was terrible and with it, it is tolerable.
For some reason we typically get less vibration with "Extra High" spin speed compared to "High" so that is another option you might try.
May 08, 2008 | LG WM2688H Front Load Washer
Neptune MAH5500B
ladymaid, nf is the error for no fill. There could be a bunch or reasons for this but because you just moved I'm suspecting that a harness came loose on the control board or the motor control. First of all, and Im sure you did, make sure both water valves are on to the machine. If you are sure of that, press the delicates and heavy soil keys together for 3 seconds. Now you are in the service mode. In this mode press wrinkle free key, cold water should start entering. Press the cotton sturdy and hot water should flow. To exit the test mode, either unplug the machine or press the delicates and heavy soil again for 3 seconds. If the washer still does not fill, some complicated test will have to be run. Let me know, Catriver.
Jun 27, 2007 | Maytag Neptune MAH5500B Front Load Washer
Haier HLP21E Top Load Washer Logo
85 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
