Question about Frigidaire Dryers
Frigidaire ffle1011mw dryer spins but does not heat
  • 113 Answers
SOURCE: Frigidaire dryer model number LGQ1442ES0 won't stop spinnin
Ive seen this before. There was actually a coin that had fallen out of the drum and got stuck on one of the contacts, causing it too short. Open the dryer panel, unplug it first, and look for any signs of a coin or somthing shorting a circuit. Thats step one. Hope this helps. Dave www.washermd.com
Posted on Dec 17, 2008
  • 659 Answers
SOURCE: dryer drum spins but no heat
These units have a limit switch is located near the burner compartment. It is about the size of a dime or penny with 2 wires going to it. In between the wires, there is a small button that you can depress firmly. This should reset the limit. If it trips again, you will need to replace the limit switch. Hope this helps.
Posted on Apr 11, 2009
  • 1525 Answers
SOURCE: dryer will not turn
hello check to see if the long pin inside the door has not snaped off if thats ok .then check capacitor next to the motor inside the dryer may have blown
regards
shaun
Posted on Mar 01, 2010
heatman101
  • 43501 Answers
SOURCE: Frigidaire model MEX731CFS- Dryer will not spin
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on Apr 20, 2010
  • 3074 Answers
SOURCE: dryer spins but does not heat up lint area has all
http://www.repairclinic.com/Dryer-Troubleshooting
Posted on Mar 05, 2011
Need to replace belt
Search Results
    How to repair a KENMORE double decker washer&dryer ...
    ? 4:59
    www.youtube.com/watch?v=Rc_ZGugYBTY
    May 31, 2014 - Uploaded by MrProductionist
    How to repair a broken dryer belt from a Double Decker Washer and Dryer. ... I have a Kenmore stackable Washer-Dryer, and the dryer belt is ...
Oct 21, 2015 | Frigidaire FFLE1011MW White Washer/Dryer...
READ FRIGIDAIRE ERROR CODES
Hello Rob Olsen, I appreciate your inquiry!
I understand that you would like to have information upon reading error codes for your Frigidaire laundry center. I was able to locate a manual that has information regarding error codes for your laundry center. I hope this information is helpful to some degree. -Matt
Frigidaire Manual Search Results
Nov 09, 2014 | Frigidaire FFLE1011MW White Washer/Dryer...
My Frigidaire dryer model # FDE847GES0 spins and heats. When it stops to change direction, often it wont start back up. Some times it does, sometimes it wont. What is the cause of this?
Good Afternoon Friend,
I understand that your Frigidaire dryer, model# FDE847GES0, spins and heats. I also see that when it stops to change direction, it is intermittently starting back up. There are numerous possibilities that can be causing this. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your dryer as well as determine what the cause of your appliance not starting back up after it changes direction. I hope this is helpful.
-Best Regards-
WP
Jun 18, 2014 | Frigidaire Dryers
Why wont my dryer stay running?
Good Morning Friend,
I understand that your Frigidaire dryer, model# FEQ1442ES, will not stay running. Please check to make sure the door is staying closed. If the door is opening in mid-cycle, then the dryer will stop running. Also, make sure the plug is in the socket tightly. Your dryer could be shaking the plug loose, which could possibly be causing it to stop running. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 17, 2014 | Frigidaire FEQ1442ES Electric Dryer
FFLE1011MWO will not heat
Good Morning Steven,
I understand that the dryer on is not heating on your Frigidaire laundry center, model# FFLE1011MW0. Before calling a technician, check the following solutions:
    1)Make sure that the two house fuses your dryer is attached to. If one of the two fuses is blown, the drum may turn but you won't receive any heat.
    2)For Gas Models Only: Make sure the gas supply valve is open, make sure there is enough air supply to support the burner flame, and make sure the LP gas supply tank is not empty or there has been a utility interruption of the natural gas.
    3)Check the lint filter, the ducting that leads outside, as well as the outside vent for any lint that might be clogged inside. This can cause a no heat issue, due to your dyer is not getting a good air flow.
    4)For Electric Dryers Only: Make sure your dryer is connected to a 208 volt circuit.
    I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully. Hope this is helpful.
    -Best Regards-
    WP
May 29, 2014 | Frigidaire FFLE1011MW Electric...
Frigidaire stack dryer turns off after few seconds
CHECK MOISTER SENSOR AND OR THERMISTOR. THERMAL CUT OFF AND CYCLING AND HI LIMIT THERMOSTATS
Feb 15, 2014 | Frigidaire FFLE1011MW Electric...
My Frigidaire Galaxy Series Commercial Heavy Duty Dryer does not spin it heats up but doesn't spin. What would be the cause of that?
most likely cause is a broken belt.next time send the model number,i can look up your model and give part numbers.
Oct 06, 2013 | Frigidaire FDE336RE Dryer
Dryer spins but does not heat up lint area has all
Mar 05, 2011 | Frigidaire Dryers
Dryers Logo
43 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
