Question about Water Heaters
Error code 14 on Bosch 22E
Can code control panel to operate but when hot water tap is turned on reverts to Code 14 error
  • 25 Answers
SOURCE: Keep getting error codes and have to reset too often
This paticular problem your having is specific to the jumper in the heater. The jumper is for condensing heaters. Your heater does not have the specific wiring or computer for condensing. So they added a jumper in the wiring. It is failed or failing. It should ohm out at about 120ohms. sometimes its just a loose connection. Check this out, and called 1-800-642-3111, they have been very busy, but leave them a message and they will call you back.
Posted on Jan 19, 2009
  • 11 Answers
SOURCE: BOSCH AQUASTAR 2400ES NATURAL GAS TANKLESS HOT WATER HEATER
Q. FA - Gas leakage error, gas valve circuit not closing properly
A.
  1. Disconnect power supply cord and check wire connections on gas valve and the two connectors on the control board.
  2. Flow water out of a hot water tap above the minimum activation point of .8GPM. Measure voltage at the gas valve wire connector. The connector should measure 24VDC between the left pair of wires and 24VDC between the right pair of wires when the unit is operating. If voltage is not correct, contact Bosch Water Heating for further instruction.
  3. Gas valve may be defective, contact Bosch Water Heating for further instruction.
Q. EA - No flame ionization detected with water flow
A.
  1. Verify that all manual gas shut off valves are open.
  2. Verify gas type (See Fig. 2 in installation manual) corresponds with the type of gas supplied to the heater.
  3. Reset error code and open a water tap to cycle the heater in an effort to purge air from gas line (especially on new installations). Cycling hot water tap on and off multiple times may be necessary. If heater still faults with EA error code, have a licensed gas technician properly purge air out of the gas line leading to the water heater.
  4. Verify the three yellow wire connections to the set of electrodes (underside of the burner assembly) are secure.
  5. Verify gas pressure meets specifications outlined in chapter 3.8. See Bulletin TWH-G2-03.
  6. Verify venting meets specifications outlined in chapter 3.6 of the installation manual. Improper venting may cause premature failure of the flame sensor rod.
  7. Observe inside the viewing window of the heat exchanger when a hot water tap is opened. Sparking should be followed by a steady blue flame. If not, Call Bosch Water Heating with observations. Readings from above gas pressure test will be required.
Q. C1 - Fan rotation too low on startup
A.
  1. Disconnect power supply cord. Check wire connections on back side of fan and the two large wire connectors on the control unit. Removal of lower access panel on control unit is necessary to access connectors.
  2. Verify that supply voltage is 120VAC and is properly grounded.
  3. Verify that venting meets specifications outlined in chapter 3.6 of the installation manual. Long vent lengths, venting with more than three elbows, blocked vent or combination venting may cause this failure. Verify backdraft flapper inside flue gas collector is not stuck shut.
  4. Check gas pressure. See Bulletin TWH-G2-03. Low gas pressure may cause the fan to change its speed to meet desired temperature.
  5. Possible defective control unit. Call Bosch Water Heating for further instructions.
Posted on Mar 15, 2009
SOURCE: Noritz tankless water heater not producing hot water
I called Noritz error code 16 is a overheat problem. Noritz say's to flush your coil with vinegar or CLR.
Use a small pump to recirculate the CLR or vinegar through the system for 45 minutes and flush with fresh water. This worked for me.
Posted on May 12, 2009
connertamago
  • 37 Answers
SOURCE: Rheem Eco-180dvn. Error code 12
actually, does it give you a big rumble? if it does, then your problem is that the meter's btu's are not high enough and there's too litle gas getting to the heater so it's blowing itself out, basically. you'll need to call your gas provider and ask for them to bring in a higher btu meter. around 220,000 btu meter is best, so your furnace and gas stove(if you have one) dont take to much gas themselves, meaning dont get a 180,000 btu meter, because it would only be able to supply the heater.
Posted on Oct 18, 2009
senor8
  • 73 Answers
SOURCE: error code 14 shows on the remote for a noritz
This means the thermal fuse has broken and needs replacement. The thermal fuse is a white cord which wraps around the heat exchanger. It typically breaks if the unit is excessively dirty and sooted. Before the fuse is replaced you should make sure the unit is cleaned with compressed air and descaled.
Posted on Jul 15, 2010
My Bosh 24ES has error code 14 what does this mean and can I fix it
The year 2009 Bosch 24ES manual does not show error code 14.
Your manual may be different.
Call Bosch 1-800-642-3111
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
http://waterheatertimer.org/pdf/Bosch-GWH2400ES.pdf
Don't forget to read the product manual for required yearly maintenance, and performing this maintenance will eliminate many common error codes.
Aug 09, 2012 | Water Heaters
My bosch tankless water heater is flashing ae
Before calling service technician, open following links for Bosch error codes, and contact information, and possible product manual for your model, etc:
http://waterheatertimer.org/pdf/Bosch_EA_error_code_troubleshooting.pdf
http://waterheatertimer.org/pdf/Bosch-GWH2400ES-error-codes.pdf
http://waterheatertimer.org/pdf/Bosch_A4-E4_error_code_troubleshooting.pdf
Error code AE is not shown, but error EA means "burner flame not recognized by control unit when water is flowing"
There is also error A3 and A3 E3: jumper connection is not correct
Sep 26, 2011 | Bosch & Tankless LP Hot Water Heater
No hot water at all when I turn on the hot water faucets nothing nomad I would hear the burner kick on but nothing what so ever
Before calling service tech, open following links for Bosch troubleshoot resources including phone support, error codes, possible manual.
No error code can mean PC board failure, or plumbing problem
http://waterheatertimer.org/pdf/No-Error-Code.pdf
Aug 13, 2011 | Bosch AquaStar 125FXKIT-LP 125FX Liquid...
It often flashes ea or af and doesnt want to light
Before calling service technician, open following links for troubleshoot resources including common error codes, Bosch contact information, link to service manuals, and possible product manual
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/2400ESTechSupport/Troubleshooting/tabid/1295/Default.aspx
Call Bosch 800-642-3111
Multiple error codes can mean PC board failure.
AF might be A9, but not sure.
EA is 'no flame ionization detected with water flow'
  2. Check gas type.
  3. Reset error code and open a water tap to cycle the heater in an effort to purge air on new installations. Cycling hot water tap on and off multiple times may be necessary. If heater still faults with EA error code, have a licensed gas technician properly purge air out of the gas line leading to the water heater.
  4. Check three wire connections to ignition group on the lower front of the heat exchanger are secure.
  5. Check gas pressure.
  6. Check venting specifications are met. Improper venting may cause premature failure of the flame sensor rod.
  7. Check that the minimum power fan speed has been adjusted to the proper value.
  8. Observe inside the viewing window of the heat exchanger when a hot water tap is opened. Sparking should be followed by a steady blue flame. If flame is unstable or yellow with proper gas pressure.
Aug 11, 2011 | Bosch AquaStar 2400ES-NG
Bosch GWH 715 ES flashing EA code. This unit was working fine for over a year so I am assuming gas pressure can't be the problem? The spark is flashing and the unit lights for about 2 seconds then...
http://www.digelair.net/pdfs/TECHLIT/BOSCH/MANUALS/Bosch-ProTankless_AM.pdf
http://www.bosch-climate.us/files/201009031238250.GWH715ES_English_12.2008.pdf
Above are the manuals required to diagnose and service your error code.
EA: No flame ionization detected with water flow.
Verify that all manual gas shut off valves are open. Check gas type. Reset error code and open a water tap to cycle the heater in an effort to purge air on new installations. Cycling hot water tap on and off multiple times may be necessary. If heater still faults with EA error code, have a licensed gas technician properly purge air out of the gas line leading to the water heater. Check three wire connections to ignition group on the lower front of the heat exchanger are secure. Check gas pressure. Check venting specifications are met. Improper venting may cause premature failure of the flame sensor rod. Check that the minimum power fan speed has been adjusted to the proper value. Observe inside the viewing window of the heat exchanger when a hot water tap is opened. Sparking should be followed by a steady blue flame. If flame is unstable or yellow with proper gas pressure.
Jul 07, 2011 | Bosch & Tankless LP Hot Water Heater
Pilot OK main burner does not flare when hot tap turned on
If you are not getting error code, then problem could be plumbing.
Many internal and external factors can also cause tankless problems without error code.
Circuit board failure, sensor failure, incoming air, venting, gas flow, water pressure, water flow, or combination of factors.
Open following link for Bosch troubleshooting resources.
Add a comment with your experience to help others with same-similar problem.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 25, 2011 | Bosch & Tankless LP Hot Water Heater
Model Aquastar 250 is not running and is showing an error code of EA. What can be the problem?
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/250SXTechSupport/Troubleshoot/tabid/563/Default.aspx
Feb 03, 2011 | Bosch Water Heaters
the A3 & E3 codes are for the back flow sensor on the heater. Could be disconnected or a bad sensor. Call bosch tech support and they will help you with this.
Dec 30, 2008 | Bosch AquaStar 2400ES-NG
Water Heaters Logo
20 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
