Question about Nakamichi Audio Players & Recorders
Can an old nakamichi 730 receiver be repaired these days
Had it working years went by now needs cleaning and service repair work done to it
SOURCE: Nakamichi receiver AV500
Did you make sure your Speaker A or B switch is pushed in? This happened to me a few times where I thought the receiver was broke, but someone had accidentally turned of the speaker A switch...
Posted on May 02, 2008
SOURCE: Sony Receiver STR-D550Z
I would open it up and look for large capacitors that have a bulged top, I've fixed several receivers that were buzzing or had static by replacing a couple of cheap capacitors that had blown.
Posted on Sep 17, 2008
smarthome2
  • 1114 Answers
SOURCE: Display panel does not light; sound is ok
It may not need repair. if you have it hooked up to a TV, by video, s-video, or component. Press the menu button on the remote and you can see the main menu of the unit on the TV. Navigate the menu up/down/left/right/enter until you get to "display". You should be able to turn the display of the receiver on/off. If you don't have the manual. http://www.yamaha.com/yamahavgn/Documents/YEC/Stereo_Receivers/Manual/RX-797_e_U_p.pdf That's the PDF from Yamaha. I haven't used this particular unit, but that's the way it's done on all the other series. ie. RX-V or RX-Z. Hope this helps
Posted on Jun 03, 2009
  • 6771 Answers
SOURCE: Good morning! I have a
Yes! it can be repaired, the technician will need to replace the audio output ic and maybe some drivers.
Posted on Jan 10, 2011
SOURCE: Need repair work on a
You can mail on gsmusicmakers@yahoo.co.in for options
Posted on Feb 13, 2011
Cd-s start-and-stop play intermittently
Hi, you have one of 2 possible problems, either the laser is dirty and needs cleaning, this can be done by going into any computer hardware store and buy a lens cleaning cd, its like a cd with brushes on it that you put in and when it spins round it removes any dust,
or the other problem is going to be that the laser is coming to the end of its life, now as its 8 years old then chances are the problem is with the laser or the motor that spins the cd, these only have a certain life span and dont last for ever, so if cleaning dont work then this means the laser unit needs replacing, so you would have to work out repair costs, and thats even if the parts can be bought and replaced as its 8 years old so you might struggle to get it repaired
May 18, 2012 | Pioneer Premier Cdx-p686 - Cd Changer -...
Nakamichi Soundspace 5 will not turn on with the remote or the power button
The main fuse, or power transformer is open, or the audio output ic has failed. Since you were having trouble with the remote and power button I recommend replacing the item, cost to repair will be high.
Apr 14, 2012 | Nakamichi SoundSpace 5 Shelf System
Remote controller for Nakamichi AV 10 amp. stopped working last night despite replacing new batteries. Red LED not illuminating when 'power' button depressed. Any suggestions for repair/replacent of...
I got the Nakamichi Av-10 i too face the same problem i just tap the remote with my palm and it starts working...:) just try this am sure it should work
Jan 07, 2011 | Nakamichi AV-10 Receiver
While playing a CD, my Nakamichi Receiver 2 made a ''pop'' noise and lost the signal, with some smoke coming from the top vent near the front. It was in a confined area, and I believe it overheated and...
The output section has a problem. The receiver is in "protect" mode and wioll not turn on the speakers. This unit needs service. In all likelyhood, one or more of the output transistors has shorted and hte smoke came from a resistor that fried. This is a relatively simple repair for an audio repair shop. Figure around $40 for parts for this repair.
Dan
Oct 05, 2009 | Nakamichi Audio Players & Recorders
Nakamichi TA2A gone dead
This unit needs an overhaul. There are defective capacitors and poor solder connections that need repair. I have done a number of these and the repair is straightforward.
Dan
Jul 22, 2009 | Nakamichi Audio Players & Recorders
Service manual
These are not generally available outside of authorized service centers. What is your specific problem with the unit? Perhaps we can guide you on the repair.
Dan
Jan 22, 2009 | Nakamichi AV-10 Receiver
Nakamichi TM-1 Clock Radio
OK YOUR UNIT IS BAD YOU NEED TO TAKE IT TO A RADIO REPAIR SHOP TO FIX THIS I DON'T KNOW OF ANYONE IN MY AREA THAT STILL HAS THESE...
SORRY FOR THIS..
BUT LOOK UP RADIOS IN THE YELLOW PAGES THAT'S ALL I HAVE TO OFFER I WORK ON RADIOS MYSELF AS A HOBBIE ALSO COMPUTERS..
Please do not open it...
VOLTAGES INSIDE...
SHOCK HAZARD...
TAKE IN SOMEWHERE AND GET IT FIXED.
Nov 01, 2008 | Audio Players & Recorders
Our Nakamichi CD player has frozen up on us. Our Nakamichi Cassette Deck door won't close and prior to that it tangled a cassette tape and quit working. Both were purchased in 1991 along with a...
The CD player muigt be able to rescue by a reset top factory settings, mostly available in your manual, the cassette deck i think needs to be repaired.
Aug 05, 2008 | Nakamichi CD-35z CD Changer
1990 Lexus LS400 Nakamichi Car Stero Amp problems
if the amp is damage it needs to be repaired or replace but the age of any amp doesn't matter, all are compatible to work.
Jun 18, 2007 | Nakamichi PA-2002 Car Audio Amplifier
46 people viewed this question
Top Nakamichi Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
ELECTRICLAW
Level 1 Expert
da surgen
Are you a Nakamichi Audio Player and Recorder Expert? Answer questions, earn points and help others
