Question about Reddy Heater-30-55,000 BTU Variable
My motor on my heater starts and shuts down three times in a row
It shuts down instantly three times in a row and then shuts down for good.
It need to be clean
Posted on Jan 26, 2009
Maytag MED5700TQ occasionally completely shuts down during cool down mode
Sure!
You may have a bad timer, that is turning off the electricity to the motor while the heater is still energized.
Long time ago, dryers had about 3 "automatic shut-off's" two on the heating element, and one on the motor.
Because of the lint that comes with drying clothes, fire is always a danger.
Today, the "thermostat shut-off's" are up to 5, 6, or 7 on some models!
Sounds like your dryer is getting hot enough to trip one of these. When the whole machine cools down, the thermostat resets, and the machine starts again.'
I had a dryer do the same thing. The problem with that one was nothing more than dust and lint in the motor, and all I had to do was vacuum out or blow out the motor about once or twice a year.
Be blessed
Jan 31, 2013 | Maytag MED5700TQ Electric Dryer
I have a gas Sunpak infrared heater in an out door room that is three years old. When I turn it on the ignitors sparks, gas is release and the burner lights up for a second or two then shuts off. This...
Steve, from what you have described. it sound like the Thermoplie and/or Thermocouple have failed. I suspect, it's the Thermocouple. Replacing it, should solve the problem.
I hope this helped you & thanks for choosing FixYa.
Aug 14, 2011 | Heating & Cooling
My Goodman model GMS90703BXA has a problem wherein after a cycle, the ventilator / discharge fan doesn't shut down properly. It stays on after the burner has shut off and after the main fan has shut off. ...
Hello, usually this happens when the pressure switch remains open, this could be due to a blocked flue pipe, water inside the tube between inducer motor and pressure switch, or the switch itself is going bad. Condensation can form and leak back to the pressure switch through the tubing and causing an intermittent problem with the inducer motor running continuously
Mar 01, 2011 | Goodman GMS90703BXA Heater
Goodman GMP075-3 not igniting. Everything cycles as it should but HSI does not glow. Thermostat is set to heat, temp approximately 10 to 15 degrees higher than room temp, blower motor starts, relay clicks...
The flash code is due to the furnace not proving flame 3 times in a row. If you have a multimeter you can ohm the ignitor out to see if it is good. Depending on the type (silicon Nitride or silicon Carbide) you can verify if it is good. A silicon Nitride ignitor looks like a small thin straight bar type will ohm @ 11 - 18 ohms, a carbide ignitor looks kinda like a tuning fork (sorta) will typically ohm @ 40 - 92 ohms. anything outside of those ranges will require a replacement.
Nov 02, 2010 | Goodman GMS90703BXA Heater
Hi, I have an LXi heaterthat keeps kicking off! On
This usually indicates an ignition lockout...The heater tried to fire but either didn't fire or a flame was not detected. Check and ,ake sure ignition is good, gas valve is opening and make sure all grounding is intact..
Jul 30, 2010 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Huskee 16 hp Tecumseh starts and runs great but
When it shuts down check it for spark. You sound like you may have a weak coil. OR
You might have water in your fuel and it only runs until it hits the water level in the carb. You can try draining your carb *(do this when mower is cold...never drain gas from a hot mower!) and see if the mower runs longer. While you are draining your fuel you can check the float level too. A float that closes too early or that is partially obstructed might only let in enough fuel to run for short periods. Then, your three minutes of sitting is just to let the carb bowl refill. When you remove the carb bowl let the float hang down and note the fuel flow. Is it fast? Or is it just a slow drip? If it seems slow you should work the float up and down a few times to see if the flow improves. If it does improve consider draining all the fuel out and cleaning the gas tank.
Good luck and be careful!
Jul 16, 2010 | Garden
Heater Burner ignites but main blower motor will not turn on.
it sound like the blower motor may be seizing up. try spining the blade by hand to see if it feels free or not. the motor could be trying to turn but can then tripping itself out on overload. (most motors have built in safety overloads which will trip during an overcurrant event. aka too many amps.) you may have to replace blower motor
Mar 16, 2009 | Mr. Heater Natural Gas Garage Heater -...
Kenmore Elite Dishwasher clean light ind flashing and won't start
That means the control sensed that the heater in the d/w did not operate 3 times in a row. so the unit locks out. First remove the kick plate and you may have to pull the unit out from under the cab, but check your heater. use a meter to see if it reads open, if so order a heater assy it will come with a new control replace it to. If your heater checks good press in sequence normal wash , heat dry ,normal wash,heat dry , normal wash , heat dry three times within 6 sec all the lights will come on then hit cancel. What that did is reset the control and clear that fault. Keep in mind that d/w does not heat it's own water your incoming water temp should be 120. the d/w will maintain that temp. when starting your d/w first turn on your hot water till it gets hot then start your d/w this insures your unit fills with hot water and not cold
Jan 09, 2009 | Kenmore 24 in. 15142 Built-in Dishwasher
Clean Light Flashes
Jan 04, 2009 | Dishwashers
Reddy Heater-30-55,000 BTU Variable Logo
65 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
