Question about Kitchen Ranges
Roper gas range-model # s8757x3 clock started clicking then went blank, now oven & clock won't work, but burners still work fine. any ideas?
Turned burner on one day & clock started clicking & flashing, then went blank, now oven & clock won't work, but burners still work fine. have any ideas what the problem is?
james klgr
  • 362 Answers
SOURCE: Kenmore Gas Range - burners won't ignite
its possible your gas regulator is bad or the gas line to the ignitor is stopped up look at the line and see if some type of food has blocked the outlet
Posted on Dec 08, 2007
localwonder
  • 6784 Answers
SOURCE: oven quit working
Hi. this is common in many old gas range ovens. There is a set of coils that are attached to the gas valve assembly. These coils , when activated and operational, open and close the main and secondary valves in this unit. They are controlled by the main ERC(clock/oven control board). I recommend checking these coils and there respective wiring harnesses. if the clips and wires are worn and corroded, simply replace the entire wire harness.
Now, if the wiring harness and wires that are connected to the coils look good and there are no signs of corrosion on the wires and connector clips, this will confirm that the coils have failed and you will need to replace them.
You can also preform an additional test with a multimeter. simply connect your multimeter or voltage meter to both terminal posts located on the coils. once your meter is connected, start the oven cycle. you should register some sort of current during this test at this time. if the current is sufficient and the coils do not initiated the valve action, this will confirm coil failure. if the meter dosen't register a current during oven operation, this will confirm ERC(control) failure. you will have to replace the Oven control board in this case.
The Most common issue in this situation will most defiantly be the coil assembly and not the control.
Please rate and god bless:)
Posted on Apr 21, 2009
EllaWatson25
  • 725 Answers
SOURCE: I have a frigidaire gas range model # fgf337ecc
This is your electronic control board that has gone out. When you order yourparts through us, we provide part removal/installation instructions for our customers.
We also ship overnight and would love to get you cooking again real soon.
Please contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
with your brand and model number. Thanks, Ella
Posted on Nov 18, 2009
SOURCE: oven igniter problem
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. Amperage should be 2.5-3A. If less than 2.5A - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Ignitor part numbers : WB2X9154, 4342528, SGR403, 5304401265;
Those ignitors are interchangeable, if you can splice the wires. If not comfortable splicing wires - replace it with the first one in the list, should be direct replacement.
Posted on Jul 15, 2010
fixyourboard
  • 310 Answers
SOURCE: I have a GE XL44
This is a failure with the clock module. You can replace it with a new one, or fixyourboard.com rebuild it to save you some cost.
Posted on Aug 14, 2010
Testimonial: "Great feedback, now I know part to get. Thanks"
Viking range burners won't light
from I review I found it might be this...Simple replacement of Glow Bar igniter requires removal of entire front panel with many screws
so sounds like your igniter might be shot - it heats up to ignite the burners - easy fix - get a long torch lighter and just light the gas after turning it on -
Nov 05, 2017 | Viking VGIC485-6G Gas Kitchen Range
Tappan 32-1272-10/07056-8509-4080 gas range/oven pilot light works,main oven burner won't come on
You will need to look and see if the igniter is glowing a bright red. If it is weak, the oven will not light. Here is the igniter if you need to order it.
Also check and make sure your getting 3.2-3.6 volts AC to the valve.
Dec 01, 2012 | Tappan TGF320 Gas Kitchen Range
Dacor Preference RSD30 Gas Range My wife put the
I don't see the make and model number of your unit. I only see part of your post. Please post the make and model number. It should be a simple fix. From what I do see in your post, it sounds like the control board will need to be replaced.
Regards,Richard
Oct 17, 2011 | Dacor Ovens
My gas oven won't work - it worked yesterday. The burners work fine. No clicking sound, no gas coming through. Checked plug in - fine; re-set all breakers; all electronics around it are working.
Which oven do you have? I need a model number to help you. There is a model that has a electronic ignition system that if the regulator in open (blown internal fuse) the oven will not work. So I need a model number to verify.
Get back to me when possible
Aug 28, 2011 | Kitchen Ranges
I have a Maytag gas stove model MGR5730BDW. The oven won't light. The broiler works just fine. The bottom ingiter glows orange and gets hot but the burner won't light.
Hello, Thank You for using FixYa. I will be helping you today.Just because the ignitor glows does not mean its good..switch the two around and see if the oven comes on. They still glow even when they start to go bad.
Thank You and please rate my answer if it was helpful..
Jun 16, 2011 | Maytag 30" Self-Cleaning Freestanding Gas...
Electrical panel went blank. Hence can't operate the oven. Stove works fine.
Hi. Interesting. My Figidaire Gallery Professional gas stainless went blank 2 days ago. Model FGF379WECS. So I'm googling...
Your Service Manual is located at (document #2 in link):
http://www.retrevo.com/support/Frigidaire-GLEFM397D-Ranges-manual/id/2367bh351/t/2/
Part Number
316418704
Description :
Clock/Timer, electronic, w/mini oven, ES510
Rick
May 15, 2010 | Frigidaire Gallery GLEFM397DS Electric...
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
