Question about Canon imageRUNNER 5000 Copier
Error 061 sub 002 en canon ir 5000 - Canon imageRUNNER 5000 Copier
3 Suggested Answers
  • 199 Answers
SOURCE: CANON IR 5000 E-584-002
IN the finisher -
The shutter open sensor does not turn on when the No. 2 feed motor
has been rotated CCW for 1 sec.
check finisher
if you want, copier running without finisher.
Posted on Mar 08, 2009
  • 122 Answers
SOURCE: we have a problem with
enter service mode( * 28 * >copier>option>PO_cont> off> ok) and make copies if erroir code does not display, replace potential sensor.check dc controller.
Posted on Jan 02, 2011
Error code of E-002-0000 canon printer IR 2002
Here is a link that I hope addresses the fix you need by the error if is an issue with the temperature of the fixing unit
http://www.mytechtime.com/2011/10/canon-error-e001e002-e003-e007.html
Aug 24, 2016 | Canon Office Equipment & Supplies
How can i fix the error code 000001-00002
Assuming you have a copier or laser printer, this site:
Thread Canon IR 2200 error E000001 002
suggests:
Some errors can just come up and you can just clear them and if everything works fine you don't need to worry about calling a tech. However if clearing it doesn't make the error message go away or you have problems emerge with the copier then you do have a problem.
E001 is an Overheating detection error.
E001-002 - The sub thermistor detects about 295 degrees celsius or higher. You would have got E001-000 for a temperature above 250 degrees.
Jan 11, 2016 | Canon Office Equipment & Supplies
Error 003 in canon IR 5000
A E003 is a error code with the fixing unit. I would first try to reset the error code in service mode first. If that will not correct the problem, most likely the thermistor will need to be replace. The PCB connection break off. I would replace the sub thermistor at the same time. Good Luck
Dec 23, 2012 | Canon imageRUNNER 5000 Copier
IR 6570 Error occurs E804-002
This is an error for the DC power supply fan - there is an IH power supply cooling fan error. The book I have doesn't give the 002 part of the error but check that
Jun 21, 2011 | Canon imageRUNNER 5570 Copier
Copy of Canon ir c2550 service manual
This Canon ir c2550i has an error e000003-002 which requires shutdown.Appreciate any idea about this problem. Ron
Jan 17, 2011 | Canon imageRUNNER C2550 Color Copier
We have a problem with copier ir 5000 troble E 061 002 or E 061 001 What should I check and I do krn pre-exposure non-flame lamp
Dec 17, 2010 | Canon imageRUNNER 5000 Copier
Error code E00001-002
the sub thermistor detect 295 degre celces or higher the couse will be the fixing fillm unit is foulti (that is the thermistor is short circuit the main power suplay is foultiy the dc controler pcb may foultiy to clire the error you have to go copier -function-clear -err from the service mode , to inter the service mode * and pres 2and 8 key simultinusley and then*
May 20, 2010 | Canon imageRUNNER 2200
IN the finisher -
check finisher
Mar 07, 2009 | Canon imageRUNNER 400S Copier
CANON IR 5000i
Uh oh! You probably will need a new hard drive for your 5000. A new drive will have to be installed by a tech, then formatted and new system software installed. The E602 with the 000001 sub code indicates a hard disk drive failure.
Aug 15, 2008 | Canon imageRUNNER 5000 Copier
Canon imageRUNNER 5000 Copier Logo
61 people viewed this question
old marine
old marine
