Question about Averatec 3200 Notebook
Trying to open back of lap top avertech 3200
The input for the power adapter is lose on the inside, to where the computer will no longer turn on. So I am trying to remove the back in order to hopefully fix the problem. I have taken all the screws out that I can find, but there seems to be one hiddden and its not allowing me to open it,(it is opening but not enough) but I have no clue where to look, any ideas would be appreciated. thanks.
  • Averatec Master
  • 32,281 Answers
Not sure with this laptop. Remove the keyboard, there may be a screw that holds the top plastic cover.
Posted on Jan 26, 2009
Lap top will not turn on. receives power from the cord and power supply, but has no indicating lights on the lower left part of laptop. was able to get the lap top to operate after removing and...
Measure the voltage at the terminals of the battery in the laptop. If there is no supply then the power section in the lap tops main board is faulty and needs a check.
However if there is voltage then the battery must be checked if this has failed to charge and is defective. check if the cord from the adapter is not short as it will result in DC power cut off.
Mar 24, 2011 | HP Computers & Internet
Computer doesn't recognize Maxtor 3200
There are a number of possible solutions to this problem and these are itemized elsewhere in this forum. I had the same problem and nothing worked so with nothing to lose I prised open the case and removed the USB adapter and unplugged the power light. This leaves a normal HDD with standard connections. I installed this in a PC and it now works. The problem must have been in either the adapter or the power supply. Not the perfect answer but possibly a way out to retrieve data.
Feb 21, 2011 | Maxtor Personal Storage 3200 (U01E200) 200...
My averatec lap top os stuck in sleep mode
Hi. I suggest you try pressing the power button to wake it up or you could also try power draining it and turting it on. To powerdrain your computer you must remove first the battery and unplug the ac adapter then press and hold the power button for 20 seconds, after that you must place back the battery and plugin the ac adapter then turn on your computer. Hope This Helps
Jun 02, 2010 | Toshiba Satellite M100 Notebook
Maxtor 3200 was working fine. Suddenly my
Try connecting it to another computer.
If it is not detected, then either the disk-drive "inside" the unit is dead, or the "adapter" (USB-to-Disk-Drive) inside the unit is dead.
If the latter, disassemble the case, remove the disk-drive, and attach it as an "internal" hard-drive to your computer.
Nov 01, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
My Gateway shuts off, I don't think it has to do with the power
You are infected with a virus or something. Try re-installing the OS and see if this eliminates the problem. If it doesn't help then you have something physically defective.
Sep 20, 2009 | Acer Ferrari 3200 Notebook
Dropped lap top now wont boot up
press the fn key on laptop hold it down and then press the power key on the laptop. once u see any display on the screen you will get some tests running on the screen. The system will show you the error message which u need to note down. else you can do a Flea Power on your laptop. Remove the adapter and the battery and then press the power button and hold it down for 30 seconds then connect the battery and adapter back and try to turn on the laptop. See if the magic works for you
Jul 16, 2009 | Dell Latitude D600 Notebook
Averatec driver problems
In order to up date your drivers, go to the avertech web site and go to driver downloads you will need to put in the model # of your computer in order to get the proper driver downloads. hope this was helpful.
Jan 25, 2009 | Averatec 3200 Notebook
Toshiba Satellite AC Adapter?
You can use an adapter with a lower or the same voltage, but not higher voltage. Also it should have similar amperes. Also it needs the same polarity. That's the +/- indicator. This page has a positive polarity symbol:
There's no need to pay ridiculous amounts of money for an exact brand name adapter.
Jun 18, 2008 | Toshiba Satellite A65-S126 Notebook
Averatec 3200 Notebook Logo
29 people viewed this question
Top Averatec Computers & Internet Experts
Rommel Balcita
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
