Question about GE GTS16BBSL Top Freezer Refrigerator
Cooling problems We just moved and had the ref. in storage for a month, then moved. We always kept it upright in the truck and storage. The compressor runs as normal but it wont cool very well, the freezer gets cold enough to freeze ice but its soft but the kids freezer pops wont freeze in the door, the refrigerator dont cool very much at all, but does seem to get cooler at times. Everything was working fine before the move and storage of the unit. It seems to be a sealed system from what I can tell and I did clean out the coils that are on the bottom of the refrigerator to see if that was the problem but nothing has changed. We would appreciate any help or suggestions.
  • Tom Snyder Jul 15, 2007
    If the evaporator fan is the one at the bottom with the back cover removed then yes it is working. Im not sure where really to check for ice on the evaporator? if that is the coils on the bottom of the fridge then no they are not iced up, but even though I can figure out mechanical problems, plumbing, electrical and carpentry...refrigerators are not my thing. If I know where to check and what to do I can fix the problem so if you could let me know where the items you refer to are then Ill check it out in more detail.
    I appreciate it so very much!
    Thank you,
    Tom
    Novelist:
  • 159 Answers
Did you make sure the evaporator fan is working? I would check that and also make sure the evaporator is not all iced up. If it is iced you have a defrost problem and not with the sealed system. so check that out and get back if you can. Thanks
Posted on Jul 15, 2007
SOURCE:
How-to check a Lamp Ballast board on a Sony KDF-55e2000 TV for proper operation
You cant test them unfortunately. The only reliable way is to swap it out with a known good ballast. They can and do go bad sitting as the capacitors start to dry out from not using them. Sitting is bad for electronics. Buy a ballast from ebay(used known good) and try it. Thats your best bet honestly.
Aug 20, 2016 | Sony KDF-55E2000
Tip
Tips of Repairing your Refrigerator
For prevent highrepair bill and the expense of replacing all your lost food. This article willprovide some useful tips that how to manually repair your refrigerator andfreezer yourself. Let's star with some basic information.
What you have to Do-
- Always maintain temperature range between 36 degrees Fahrenheit for the fridge, and between 0 to 5 degrees for the freezer.
- Keep clear and clean the coils with a vacuum or duster every 6 months to maintain efficiency and for reduce operating cost.
- During a power outage fridge will stay cold for about 7 to 8 hour and freezer can stay cold about 50 hour. Do not open door unnecessary.
- Daily defrost your manual defrost freezer and do not chip away the frost.
- Full filled fridge is more efficient than a half empty, but do not overfill.
- While moving and storage keep your refrigerator upright.
- After moving the refrigerator wait 24 hours before plugging it in.
- Keep at least 2 inches or air space behind your refrigerator and 6 inches above it.
What you have not to Do-
  • Overfill would not cool as well, so don't overfill your refrigerator.
  • Do not chip away the frost in manual defrost freezer.
  • Do not store your refrigerator unplugged for extended time. Some units or refrigerator require continuous use to ensure proper lubrication of compressor. If possible, plug in it once in a month and keep it run for a couple hours.
By using these tips you willkeep your refrigerator well.
on Dec 24, 2010 | Refrigerators
Frigidaire Upright Freezer No Longer Freezing...Again
Get another freezer. They are shooting you a lie and taking your money, Sea Breeze
Jun 11, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
JENN-AIR Freezer and refrigerator not cooling
good day,
hope this link below will solve your problem.
ref
Jan 10, 2009 | Jenn-Air JCD2389G Side by Side...
Freezer
hi thanks for the question first is the compressor running if it is & not cooling . your freezer has lost its refrigerant if so not worth repairing worstthing people do is not use a freezer for a long period of time its ok for fridges as they are built different thanks the appliance doc
Sep 26, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
GE GTS16BBSL Top Freezer Refrigerator Logo
158 people viewed this question
Top Refrigerators Experts
Brad Goodale
Peter Taylor
Tmik
Tmik
Level 1 Expert
