Question about Lenovo Ideapad Z565 - 4311
Overheating and loud fan. (not a dust problem)
A few days ago, out of the blue it began overheating on me. It's done this in the passed before but after a day or so it no longer had problems with heating, and the fan was never this loud. I opened it up, there is no dust (I cleaned it out just a few weeks before this happened, as I do regularly.) and I cleaned it out anyway, taking out the fan completely. The heat seems to be gathering near the hard drive. Any help is greatly appreciated, thank you.
XPS 410 won't boot but CPU fan spins
A loud CPU fan will also equate with overheating and imminent failure. Can you reliably access your system BIOS? Can you run a memory test there? If so your CPU is functional (and your memory which is also subject to overheating and BSOD under XP. If those are good your prime suspect is your HDD. If you can afford it, now would be a good time to replace your system.
Jan 09, 2013 | Dell XPS Computers & Internet
2001 Montero Sport, 3.0, 4X4: New water pump and thermostat (170 deg). When accelerating from a stop, a (flowing) noise is heard: It is almost a 'trickling' sound, like the sound you hear in a...
if your sure the cooling system is full than i wouldn't be surprised if you had a head gasket that has failed.
This would explain the water noise, and overheating.
With the engine cold remove the radiator cap, start the vehicle and let it idle. continue to monitor the coolant level in the radiator. top it off if it gets low. If you see a constant perculation of air bubbles coming out of the radiator than the head gasket is bad.
Sometimes you can also smell the radiator or the overflow. If it smells like exhaust than the head gasket is leaking.
Jul 19, 2011 | Mitsubishi Montero Sport Cars & Trucks
My acer aspire 5315 shuts off suddenly and won't restart till it wants to. I replaced the battery, no difference....what's wrong?
This could be a sign that your laptop is overheating. If you touch the laptop while it is running & you find it too hot, make sure that the fan is running properly & that the air ways are not blocked.
You can blow compressed air into the cooling vents of the fan. If you notice clouds of dust coming out, then it might be a good idea to disassemble the laptop, clean the fan & air ways, & reassemble it back. If the fan has failed & is no longer running, it might need to be replaced
Oct 22, 2010 | Acer Computers & Internet
Fan always running
vacuum out air ports/power supply fan or use compressed air in a can to clean out dust.
yes this is bad, life is greatly reduced.
clean dust out once every other month or as needed.
Oct 02, 2009 | Computers & Internet
I've had a bad dust problem and my cpu fan began making a loud whirring noise and finally the computer shut down altogether. Took the cover off totally cleaned out the dust and turned the power back on....
If the computer detects overheating or fan failure it will shut down automatically. If you replace the fan you should be fine. Remove your old fan and try to get one that connects the same way, some of them connect directly to the heat sink, others to the motherboard.
Apr 16, 2009 | Sony CPU FAN CPU Fan
Computer fan is loud & computer running slow
There are a number of reasons might be affecting, some are dangerous while others not that serious. Learn why and how you can speed it up easily from: http://www.whyismypcsoslow.net/ hope this helps take your stress out!
Feb 09, 2008 | Dell Inspiron 9300 Notebook
Cpu overheating
It is possible that dust got lodged into the fan bearing area. Remove the fan again and inspect the area where the fan spins with a magnifying glass. You may need to use compressed air to get the dust out. This may be followed by lubricating it with special oil or grease.
Oct 29, 2007 | Intel (8W501B1M3G) CPU Fan, CPU Cooling...
Lenovo Ideapad Z565 - 4311 Logo
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
rey francis basa
rey francis basa
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
