Question about Dell Inspiron Core i7 640GB HDD
Windows 7 doesn't recogize new ink cartridge on HP C6280
Replaced an ink cartridge on my HP C6280 printer and test page prints fine from the printer, but not from the computer. The HP solution center recognizes the new cartridge, but when I try to print something, the computer says the cartridge is empty. Windows 7 and the inks are new HP cartridges
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 101 Answers
I would go to HP and update the C6280 printers drivers. It sounds like there is an issue with the driver. It there is not an update then I would uninstall the driver and reinstall.
Posted on Jan 19, 2013
3 Suggested Answers
SOURCE: windows 7 and Linksys wireless print server
Step for installing Network print server in windows 7.
Click Windows "Start button"
Select "Devices and Printers"
Click "Add a Printer" button
Select "Add a Network, Wireless or Bluetooth Printer"
Printer wizard will searhc for all network printer including wireless.
Select "The printer that i want is not listed"
Select "Select a shared printer by name"   (Make sure you have shared the printer you want to connect)
Type the IP address of the printer if it ia a printer.
If it is printer that is connected to a PC then type like this below
\192.168.0.50printer shared name where 192.168.0.50 is the IP address of the PC where the printer is connected.
Click Next and if you want to Send a test print you can try that too,otherwise click "Finish".
That's it.
Posted on Jan 02, 2010
  • 84 Answers
SOURCE: my printer deskjet840c fail to print after
The printer is quite old. Yes I know you have gotten used to it but it's time for an upgrade. You can get a decent printer under $50 here: http://www.newegg.com/Store/SubCategory.aspx?SubCategory=38&name=Printer-Inkjet-Printers
Posted on Mar 18, 2010
Replaced empty ink cartridges in hp c6280 printer but computer says they're empty. help?
Did you remove the protective cover / tape, you re put the cartridge.
Jul 25, 2012 | HP Photosmart C6280 Printer
My C6280 was working fine then all at once it started to print very light. I have not got any error messages. I cleaned the printhead and it was pretty good on the first page I printed, the second page...
Hi.
The machine does not monitor the pressure of the ink. If there is a problem due to blockage of ink nozzles or defective print-head or cartridge it will not be detected by the main control. When instead the problem is the ink delivery system that transports ink from supply station to carriage print head, the problem will usually get spotted by main controller board and you get a "ink delivery system failure" error.
If the ink is fading is generally either cartridges or print-head. If you have already tested the cartridges by replacing them with cartridges from a different lot (make sure they are not refilled but new ones), then the problem is usually the print-head.
Cleaning the print-head with the option available in HP software will rarely help to solve this kind problem. You can try removing the whole ink carriage and soaking the part in isopropyl alcohol for about two day. The assembly is held to the rail and gets released using a gray tab on top back and disconnecting the cable at the back. Removal of the upper cover is usually needed. Printhead is HP part number 5069-7161.
Here the print head for this printer.
Here you can purchase parts and service manual for your printer.
Regards.
Ginko
Aug 08, 2011 | HP Photosmart C6280 Printer
My HP Deskjet F380 will only print blank pages. There is plenty of ink left in both cartridges. I've been on the HP help site. It didn't help. It won't photocopy either. It printed the top part...
the body of text of the test page is black ink. From what you describe, the print heads are clogged. Most HPs use cartridges that have the head built in, but if not used for an externded period they can dry up and clog.
Try repeated head cleanings (10 or more) see if any change. If none, try new HP ink cartridges
Jul 12, 2011 | HP DeskJet F380 All-In-One Printer
My hp photosmart C6280 prints but no ink comes out on the page at all. It thinks it is printing fine.
This is due to either dry or clogged printer cartridges. You can try removing the cartridges from the printer and cleaning the metal contacts with alcohol and a Q-tip, but more than likely they will need to be replaced. This can happen if the printer has not been used in a while.
Mar 15, 2011 | HP Photosmart C6280 Printer
Black wont print,whereas all colours are okay. Supposed it was as I had been in hospital for 3 months and ink had dried up, changed ink cartridge but to no avail.
1. The printer head is clogged.
2. What happens when you try to print the Windows Test page? Does it only print the Windows Flag and nothing else?
Does the copy option work on the printer? (can you copy something or does it come out blank as well)
Jan 05, 2011 | HP Photosmart C6280 Printer
Windows Ink Cartridge Empty false error message.
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Oct 28, 2009 | HP C6280 All-in-One Printer
HP C6280 Error Oxc18a0305
Step one: Remove the cartridges
  1. Make sure that the product is turned on and then disconnect the USB cable from the back of the product.
  2. Open the product cover and remove the cartridges.
  3. Close the cover and wait for a message to insert the cartridges to appear on the control panel display.
  4. Disconnect the power cord from the back of the product.
  5. Disconnect the power cord from the wall outlet and wait for one minute.
Step two: Reinstall the cartridges
  1. Reconnect the power cord to the wall, reconnect the other end of the power cord to the product, and then turn on the product if it is not already on.
  2. Open the product cover and reinstall the cartridges.
  3. Close the cover and print a calibration page, if prompted.
  4. Print a self test report to make sure that the product can print.
  5. Reconnect the USB cable between the product and the computer.
  6. Try to print a document from an application on the computer.
This should work
Jun 16, 2009 | HP Photosmart C6280 Printer
False error empty cartridge
Jun 01, 2009 | HP Photosmart C6280 Printer
Cannot print with new ink cartridge
Sounds like a non genuine, aftermarket ink that is dodgy.
if not ensure it is indicating the same colour that you replaced
Dec 12, 2008 | HP Photosmart C6280 Printer
Dell Inspiron Core i7 640GB HDD Logo
78 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
