Question about Hussmann HUS-HGL2TS Double Section Low Temp Vertical Merchandiser Self Contained Top Mount 208V
Need location of, and part number for ballasts for freezer lights
This is for Hussman model HGL-2-TSSA
2 Suggested Answers
  • 1230 Answers
SOURCE: ballast location in a hussman NRFV5 freezer
http://hussmann.ingersollrand.com/Discontinued%20Tech%20Info/NRFV_NRCV_NRDV_NRFLV_0345913_E.pdf
check out his web site. Has manual and instructions.
Posted on Jan 16, 2010
I bought an Insta Flame model FSDV 30 direct vent wall furnace, need a natural gas conversion kit. It currently is set up for propane and could use some help in finding the parts and installing them.
There is a ban on that particular furnace as they can explode!
You won't find parts or anyone that will work on it.
[PDF]TSSA Bans Series of Insta-Flame and Northern Flame Fireplaces www.dunnheating.com/.../TSSA%20Bans%20Series%20of%20Insta_Flame%20and%...
  1. Cached
  2. Similar
Oct 23, 2012 - (TSSA) has banned a series of natural gas and propane-fired direct vent ... 'FSDV22' or 'FSDV30' or 'FSDV32' in the model name or number.
TSSA Bans Series of Insta-Flame and Northern Flame ... - CNW Group
www.newswire.ca/.../tssa-bans-series-of-insta-flame-and-northern-flame-fireplaces-51...
  1. Cached
  2. Similar
Oct 23, 2012 - All Insta-Flame and Northern Flame natural gas or propane-fired direct vent freestanding fireplaces with 'FSDV22' or 'FSDV30' or 'FSDV32' in ...
[PDF]Fuels Safety Program DIRECTOR'S ORDER - TSSA
https://www.tssa.org/corplibrary/ArticleFile.asp?Instance=136&ID...
  1. Cached
  2. Similar
Mar 25, 2016 - Natural Gas Fired Direct Vent Free Standing Fireplace - Model ... Insta-flame or Northern Flame: Models FSDV22, FSDV30, FSDV32, D222.
Majestic Fireplace - - Recalls & alerts - Healthy Canadians Website
www.healthycanadians.gc.ca/recall-alert-rappel-avis/hc-sc/2012/15058a-eng.php
  1. Cached
  2. Similar
Nov 9, 2012 - Natural gas and propane-fired direct vent free-standing fireplaces ... Insta-flame or Northern Flame (Models FSDV22, FSDV30 and FSDV32, ...
TSSA Safety Order Ban of Majestic FSDV22, FSDV30 and FSDV32
www.fireplacegroup.ca/tssa-safety-order-ban-of-majestic-fsdv22-fsdv30-and-fsdv32/
  1. Cached
  2. Similar
Dec 21, 2012 - TSSA Safety Order Ban of Majestic FSDV22, FSDV30 and FSDV32 ... CFM Inc. (Majestic Fireplace) and bear the trade names Insta-Flame or Northern Flame ... (a) Natural Gas Fired Direct Vent Free Standing Fireplace - Model FSDV22, FSDV30 ... -Stove shipped as natural gas; LP Conversion Kit included
http://www.healthycanadians.gc.ca/recall-alert-rappel-avis/hc-sc/2012/15058a-eng.php
Dec 11, 2016 | Kitchen Ranges
BALLAST PART No FOR A SAMSUNG SP50L6HX PLEASE HELP
Google that model number with ballast or lamp ballast to locate the part and its number. Usually the color wheel will not operate if ballast is not working---Lamp comes on and stays on the Ballast is good.
Nov 06, 2012 | Samsung SP50L6HX 50" DLP HDTV
I have a Hussman 6x9 walkin freezer and it will not work when temp outside gets above 80 degrees i need to find out if it has the right or a big enough unit for that size freezer. the only numbers i can...
Assuming the compressor is sized correctly( and usually they are) There are a couple of fairly easy things to check.
1.) The compressor unit.
Are the fan(or fans ) operating. Some units have two condenser fans and will operate with only one until the temperature gets too high for it to keep up.
Is the coil clean. A dirty coil can cause unit to fail too keep up in high temperatures.
2.) The evaporator unit .
Same as condenser unit . Are the fans all working
Are the coils clean.
3.) Defrost Timer. Is the time set correctly .
Is the unit defrosting during low usage time periods.
Hope this helps
Bob
Jan 26, 2018 | Hussmann Refrigerators
How do you replace the fog light bulb on 2008 avalanche
    • 1 Open the hood and reach down into the engine bay for the fog light assembly. If you cannot reach the fog light assembly from the top you may need to get underneath the truck to reach it. Remove the electrical plug running to the fog light ballast.
    • 2 Remove the bulb. Unlock the fog light bulb by turning it counterclockwise and pulling it straight out of the assembly.
    • 3 Slide a new bulb into the fog light assembly. The part number you will need for the new bulb will be located on the ballast or base of the old bulb.
    • 4 Turn the bulb clockwise to lock it into the fog light housing.
    • 5 Reconnect the electrical connector to the bulb ballast.
Jan 23, 2011 | 2007 Chevrolet Avalanche LTZ
I need to replace the ballast on my GDM 12 freezer and I need to know where the balast is located
The ballast is located on the bottom inside wall where the compressor is located. Its usaually mounted, and can be easily removed and replaced. The ballast is rectangular in shape and has a few wires protruding from each end. To replace simply dismount the bad ballast and clip the wires. Match the ballast to a new one, reattach the wires using wire nuts, and remount ballast.
Jul 24, 2009 | True GDM-12 Refrigerator Commercial
Hussman DCCG Freezer
are they the florescent tube type?? i suspect that the ballast went bad
Apr 15, 2008 | Hussmann Commercial Freezer DCCG-12
Cannot play .HGL files once files have been downloaded to my computer
Unless you have specific software to play the .hgl files (you could do an internet search for "hgl player"+"audio" to try and find a standalone .hgl player if you want to try this route) then you'll need the program Converter 1.4 that comes on the CD shipped with the product. This software is a program that decodes the compressed recording file (the .hgl) and converts it into a .wav file that can be played using most any PC media player; from there, you can listen to it or recode it as an .mp3 or whatever you want to do with it.
Hope that helps.
Aug 25, 2007 | Denpa mp-36 128MB Handheld Digital Voice...
Hussmann HUS-HGL2TS Double Section Low Temp Vertical Merchandiser Self Contained Top Mount 208V Logo
75 people viewed this question
Top Hussmann Refrigerators Experts
Dennis Boxerman
bobalix
Andy
Are you a Hussmann Refrigerator Expert? Answer questions, earn points and help others
