Question about Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System
Spa drains when turned on
My spa drains when I put the controls in spa mode. What could be the problem?
  • 11 Answers
The problem is in your plumbing. Someone put a valve in an incorrect position. I would have to see a picture of your plumbing but if you can follow the flow of water. When you put it in spa mode, look at which valves turn and which ports open up. If it is doing anything other then sucking water from the spa and returning it only to the spa, then that is why it is draining. Again it would be great if you had a picture. What I have seen before is somebody plumbing in the pipe for a pool cleaner after the valve that send water to the spa. This would result in water from the spa slowly draining out of the pool sweep line. Good luck.
Posted on Jan 28, 2009
I have a Jandy Aqualink pool system. When I turn on the spa and heater, the spa drains..I've never had this happen but don't use the spa much. What should I check?
His is not typically a control panel issue but more likely a valve issue.
Your valves are set as follows wih a few minor variations.....
Pool mode- sucks from pool skimmer and or pool vac line and returns water to both the pool and spa.
Spa mode - self contains the spa , meaning water is sucked from the spa and returned only to the spa.
If your spa is draining then most likely one of your electronic valves is failing...most likely it's the return valve so what is happening is the water is sucked from the spa and returned to the pool instead of self containing the spa.
Easy check is to be next to the equip when spa mode is selected and two valves should move and align properly, the return side valve is most likely not moving or it is not moving into the correct position.
The fix is either adjusting the valve acuator or buying a new valve acuator.
Another thing to check is on the main panel circuit board to ensure the return and auction 3 pin plug ins are still connected.
Apr 05, 2015 | Jandy Aqualink Rs4 One Touch Control...
Actuator/Valves are not in Sync with the control panel
You may have to open the valves and reset the cams. Not too tricky, just a lot of trial and error to get it just right
FYI when you decide to replace the actuators, Intermatic now makes a direct replacement for both Compool (Pentair) and Jandy models. They are significantly cheaper.
Mar 26, 2014 | Pool & Spa
How to drain the spa
if pool spa combo put in service and switch right side button to spa drain or turn the actuator for the to spa and return to pool it should drain then put back for operation
Feb 18, 2014 | Jandy Pool & Spa
Control panel for spa and pool and spa heaters reads "SEr". cannot turn the temp up or down. Spa will not come on.
This sounds like the spa has been put in the Standard Economy mode.
When your spa is in this mode almost nothing works as it is in a freeze protection mode.
Change the operating mode back to standard and it should work just fine in the future.
US Parts Center
Sep 24, 2013 | Hayward Pool & Spa
Spa goes to drain mode when in spa mode
make sure actuators are on and on the correct number and that the handles are locked in
Nov 02, 2012 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
I have an older sta rite pump. All of a sudden when I turn the system to spa mode, it drains the spa
it shouldnt be the pump check your JVAs make sure you didn't bump one working on the pump both should be on same number switch position 1 or 2
Oct 16, 2012 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Just bought house with aqualink pool spa, one of our teenagers pushed the buttons, we dont know which one and the spa has emptied and the pool is full and we dont know how to get the water back in the spa...
You cannot drain the spa using the indoor controller, unless the valves out at the equipment are set wrong. go to the outside pannel and put the system in" service mode"(using the button on the left). then push the button on the right till it says "spa fill".There are 2 "accuators" (or automated valve turners) They are black rectangular boxes connected to the water valves. Use the toggle switches on the side to turn the vales to the correct positions. You want the pump to **** from the pool and return to the spa. Now turn on the filter pump and let it run till the spa is full. Put the system back in "auto mode" and you are done.
Oct 28, 2010 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
SPA Filter on while Spa is Heating
If it has motorized valves the stop positions have to be adjusted so that the water coming back is equal to what it drains to stop the spill over process unless you want to add more valves but the pool pump does the job of heating and filtering the spa
Jul 04, 2009 | Jandy Aqualink Rs4 One Touch Control...
Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System Logo
886 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Ian Kime
Ian Kime
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
