Question about Rug Doctor Mighty Pro X-3 Ready Pack Commercial Grade Deep Cleaner
Rug doctor stopped turning on - Rug Doctor Mighty Pro X-3 Ready Pack Commercial Grade Deep Cleaner
The switch on my machin will not go on what do i do their or whats wrong with that what do i do to fix it?I plug in the rug doctor then i flip the switch but it wont go on.
bad switch or broken wire in the cord . use a continuity tester to check from the plug to the switch. if the cord is good check the switch itself good luck
Apr 27, 2015 | Rug Doctor 95730 MP-C2D Mighty Pro Carpet...
Rug doctor will not spray what should I do?
check your spray pump is working a little pump inside machine is operating .check switch is working as well
Sep 02, 2014 | Rug Doctor Mighty Pro X-3 Ready Pack...
Rug doctor pro won't start
if you are renting it return it and be sure that they know of the problem if you bought it call the number in the label on the back of the cleaner and check your warrantee it will be able to cover it as long as you are still in the time period that they gave you if you are renting one they should give you your money back or rent you another one for the same time at no cost to you
Mar 21, 2014 | Rug Doctor Vacuums
Rug doctor shampooer sprayer quit, I think
You think ? If it did you will have to take it to a vacuum repair shop. That's not a DIY job typically.
Oct 19, 2013 | Rug Doctor Mighty Pro Carpet Cleaner
Rug doctor repair manual
<Consumer.Support@rugdoctor.com> said: "Thank you for your inquiry about a schematic for the Mighty Pro machine. The only place that can be acquired is through Rug Doctor's manufacturing facility. You can contact our manufacturing facility at 800-964-4362 and ask for Parts. They will be able to provide you with what you are requesting."
Rug Doctor Consumer Support
Rug Doctor, LLC ' 4701 Old Shepard Place ' Plano, TX 75093
http://www.rugdoctor.com
Sep 07, 2013 | Rug Doctor Mighty Pro X3 Value Pack - Blue
Find water pump rug doctor
is it your own machine or a hire machine?
Your best bet would be your nearest rug doctor distributor or try ebay.
Tony from DirtMaster
Feb 25, 2013 | Rug Doctor 95730 MP-C2D Mighty Pro Carpet...
Rug doctor won't spray water
I had the same thing happen to mine. I looked at the hose in the water tank and the screen at the end if the hose was slimy and clogged. I took the screen off and cleaned it up, put everything back together and it works like new again. Only 2 screws and a screen.
Oct 17, 2012 | Rug Doctor Mighty Pro X-3 Ready Pack...
BRUSH NOT WORKING ON RUG DOCTOR MIGHTY PRO
watch this help video there are on you tube!
Sep 25, 2012 | Rug Doctor Vacuums
Rug Doctor Mighty Pro X-3 Ready Pack Commercial Grade Deep Cleaner Logo
115 people viewed this question
Top Rug Doctor Vacuums Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Rug Doctor Vacuum Expert? Answer questions, earn points and help others
