Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Hd52w27d no picture and arcing
When you take the back off, the card on the left rear(from the back) has a transformer that is arcing. Can this be replaced or can you replace the board?
  • RCA Master
  • 8,617 Answers
Thats called the flyback yes it easially replaced. the follwing link has replacement Flybacks and they provide free step by step instructions on how to do the repair. Your set should use the 259296 flyback if the tag on the rear says ITC222 chassis below the model number. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Jan 26, 2009
My rca p52926 picture cuts in and out
If model number is correct (on rear of set in small letters it should be a PTK 195 chassis) you have a high voltage lead somewhere that is arcing.
This set did have issues with the High Voltage transformer failing and also that High Voltage (well over 10,000 volts) gets distributed to each of the 3 picture tubes this model uses.
Sometimes the lead where it connects to one of the tubes begins to arc---it is coated with white silcone to prevent this.
If arcing around the entry point to any of the tubes sooner or later it will take the set down--destroy parts that are currently ok.
Usually we locate this by turning set on with back off and looking and listening when set is turned on---If a frying or pop is heard up above the main boards--one of the entry points (called the 2nd Anode) is arcing.
I have seen them arc hard enough and long enough to actually crack and break the glass wall of the picture tube.
May 16, 2012 | RCA P52926 52" Rear Projection Television
Have a HDTV, model number HD52W67 , has no picture. My wife informed me that she saw a spark come from the back bottom. Spoke with someone who told me that this TV does not have a lamp but a tube. Need...
Most of the time when I have seen this it was either caused by a high voltage component leg arcing where the solder joint has gone cold, or the high voltage transformer is arcing. Most all the parts for this set are no longer available including the high voltage transformer and the board it is on. If the set is working, I would see if the power/ high-voltage board has a bad solder connection that is arcing. If it goes too far, the board will be burnt beyond repair. When you take the back off the set, it will be the board on the left. It is important to remove all the screws holding the board in place and flexing the lock tabs. It is a little tricky to get out. Once it is out, inspect the bottom of the board for any arcs marks. If you see one, make sure you remove all the carbon trail and re solder the component leg. Reinstall and before powering it up be sure all the plug connectors are in their proper place.
I hope this helps,
Skyassoc
Dec 10, 2010 | RCA HD52W56 52" Rear Projection HDTV
Loud popping on jvc av56wp74
if the noise is from inside the tv in the back,the high voltage transformer that feeds the anode for the rgb tubes,28000volts probably is arcing.
May 23, 2009 | JVC AV-56WP74 56" Rear Projection...
Blurry picture with arcing
this is the the fly back transformer ,replace it or if you are not a repair man ,please contact the nearest repair shop.(risk of shock hazard -high voltage!!!).
Jul 31, 2008 | Toshiba 36A40 36" TV
Arcing in lower back left corner
Replace flyback transformer cost verys from 21.00 - 71.00
Jan 19, 2008 | RCA D52W19 52" Rear Projection Television
T.v. not coming on ,turned off by itself with an arc noise
The part is known as a flyback transformer.. it will have to be replaced.. also the horizontal ouput transistor will possible most likely be bad..
Dec 16, 2007 | RCA D52W19 52" Rear Projection Television
Red and Green picture with ghost images
sounds like the high voltage transformer arc or one of the picture tubes arc causing the convergance ic to go bad
you can try to replace the IC heres a site to help:
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
but you still may have a arcing problem.
Dec 11, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Sparking Sounds and the picture jumps momentarily.
You need to remove the back and observe where the spark is coming from while the set is on. Dimming the lights may help you. Sometimes you can see a blue glare accompanied by an ozone smell. You might even hear a sound such as a slow air leak in a tire. The most likely area is around the high voltage transformer or the picture tube anode. The transformer has the thick red wire or wires coming out of the top. Also follow the three red wires to the picture tube anode( the place where the red wire plugs into the tube) Use your senses, listen smell , and look for any blue glare or arcing to the metal frame. If you find the leak near or on the transformer use 100% silicone rubber to patch. Allow at least 12 hours to cure. If the arcing is coming from the picture tube contact me for detailed instructions. You must act promptly and find the source of the arcing before you have a dead set. In short, spark + flash = crash. Good luck
Nov 13, 2007 | JVC AV-48WP30 48" Rear Projection...
Arcing inside no picture
Most times arcing like this is from the Horiz. output transformer (flyback). The insulation has a break down and up to 30 KV will find the nearest path to ground. This would require a tech. to repair the unit. This repair will most likely cost around 250.00.
May 09, 2007 | Sony KP-51WS510 51" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
121 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
