Question about UC-Logic WP8060U (689076313025)
Driver for mac
Greetings from mexico. I have a 1.83 ghz Mac mini intel core duo with mac os 10.4.10 Last year I bought a pen Tablet WP8060(U) The installation disk didnt come with a driver for mac, PLEASE I need a driver so I can use it with my mac. can anybody help me?
  • 3 more comments
  • elias diaz Jul 19, 2007
    thank you very much Noggin for your advice. I wrote uc-logic and they sent me the driver. Iappreciate your help. Lias
  • Anonymous Feb 14, 2008
    I got the same problem, only I use OS X 10.5.2.
    Anyone with any suggestions?
    The tablet register clicks, but not movement...
    The driver is installed, but I can't use the software.
    Any ideas?
  • Robbieman Apr 09, 2008
    I had the same problem using this tablet with an iMac 2.8 ghz Intel Core 2 Duo running OSX 10.5.2, using PSD CS3. I went here:http://www.uc-logic.com/download/downloa...
    I downloaded the appropriate driver and presto! Everything seems ok so far. The driver was updated recently, so perhaps an older version was there when the other users commented that it didn't work. I'm not technical - at all, I fiddled with that Ink setting in the Preferences (not sure if that helped or not), opened Photoshop, and I've been working with it now for some time. Of course, yes a Wacom would be much better, but for a tablet on a budget, it's working great! Keep in mind you'll have to adjust some settings in your brushes settings (for recognizing pressure and such) as these will respond different that with a mouse. Took some getting used to, some glitches when scrolling off and over top of other apps. I suggest hidding all other apps while drawing with this. Hope this helps.
  • Anonymous Apr 09, 2008
    necesito instalar el programa
  • morennabr Dec 12, 2008
    i have a la pazz tablet..
    and the 2 pens no work more
    i changed the batteries and nothing..
    i am near to fill my bin ..
I struggled with this tablet on my mac for a while now. Yesterday, I contacted [email protected] and got a prompt reply. Here is a link to the latest driver. Seems to work with Photoshop CS4.
http://www.uc-logic.com/download/driver/OS%20X_PenTablet_%20Driver1.24.1.zip
Please kindly uninstall the previous driver (GO-->Applications-->PenTablet Setting-->Uninstall
PenTablet Driver) before you install the new driver.  Thank you.
Besides, please do not plug the tablet into pc before the driver installation is done.
No restart is necessary, at least for me.
Posted on Feb 17, 2009
    New Friend:
I did (they did too apparently) e-mail UC-Logic.  They sent me a link to the drivers, but as 'Guest posted on Feb 14, 2008), the driver does NOT work, at least not with Tiger 10.4.11 or 10.5.2 (I've tried both).  The funny thing is even without the driver, the 3-button mouse it comes with works on the tablet.  But the pen on the tablet only clicks.  There is no movement with the pen.  Adding the driver does not help.  In fact, it appears here that the driver is not working correctly at all because when I try to access their little utility they included, it says it's not working even and that I need to reboot or something, but when I reboot it says it fails or something to that effect (it's been awhile since I tried it; I was looking again to see if there has been an update since I just happened to try it again and noticed the tablet mouse works since the last Tiger update.
System Prefs brings up Ink, but it doesn't appear to function.  Ink itself suggests the pen might not work without a proper driver for it (shrug).
On the other hand, while it works on my WindowsXP machine, I've never been able to get Photoshop7 to recognize/use it for pressure painting/editing so overall, I've been extremely disappointed in the unit.  I guess that teaches me not to buy something on sale at a computer show when I don't know anything about it.  I would have been better off just dishing out the big bucks for a Wacom.
Posted on Feb 16, 2008
  • 944 Answers
For mac drivers you need to e-mail UC-logic on this link; http://www.uc-logic.com/support/faq_M01_E.htm Hope this helps :)
Posted on Jul 15, 2007
    New Friend:
You can downloaded an updated driver from here : http://www.uc-logic.com/en/index.php?ParentMenuID=4
I was up till 3am last night trying to get my Trust branded tablet to work and found out that in fact it was manufactured by UC-Locig. However, trust do not support this tablet for Mac usage and just say its not compatible. UC-Logic however provide a generic Mac driver for all their tablets (on the link I provided above), which is the exact same driver provided by Trust for a Mac compatible tablet they were selling in the past, however UC-Logic have since updated the driver on their site but Trust have not.
I was messing around with different drivers, installing and uninstalling. Installing over already uninstalled drivers etc. It was easy to get the pen to respond and everything works well except the buttons on the pen, they do not respond at all and I also cant get the tip to double click, ecxept white trying to close a finder window. I have tried to configure it in the config prog that gets installed after running the driver and just cant get the buttons to work.
Also, if you have a Trust branded tablet, forget about the user manual provided, its worthless. Download the UC-Logic UM, its detailed and comprehensive. After reading it again today I have notices that I did not follow the correct procedure while installing the driver because I had the tablet plugged in to my iMac (G5 1.8Ghz running OSX Leopard 10.5.8 with 2GB RAM) during the install and according to UC-Logic, that is a mistake that will probably result in problems. I can't wait to get back home tonight to rerun the whole process again and hope for the best (that the buttons on the pen will work and I will be able to double click usinf the tip).
Hope this helps!
Posted on Apr 04, 2012
I had similar problems using a La Pazz tablet on an iMac running 10.4.11. I could 'click' with the pen but the cursor would not move. The drivers would not load from the CD but I eventually found this site www.superpen.com You can download Mac drivers from there - there are three of them and I finally got the .bin to load. It will not load from the startup folder but double clicking the driver icon to open it manually worked for me.
Posted on Aug 08, 2008
The documentation says nothing about this, but when you install the driver it also installs an application in your Applications folder. The application is called PenTablet Setting. You are supposed to be able to go in there and change settings to make this work. However, it tells me that the driver is not loaded on mine. Try messing with PenTablet Setting and see if that makes it work for you.
Posted on Jun 21, 2008
  • Anonymous Jun 23, 2008
    I was unable to get on the web site at www.uc-logic.com from my Mac, but could get on there from my PC. I got the new driver. Please let me know if you need the driver. I'll email it to you. I'm at jim-at-winski-dot-com. Here is what you need to do.
    1. Uninstall old driver using the install program.
    2. Install new driver
    3. Go into Application folder and open PenTablet Settings app to make any necessary changes to settings.
    4. Plug in your tablet and use any app.
    It works well. I downloaded TabletDraw from Macupdate.com and it works well. I even found that you will see a new System Preference called Ink that will allow you to do handwriting recognition once you install this.
SOURCE:
I've been sending and receiving emails for several years. All of of sudden, many people are NOT RECEIVING the emails I send. Why the sudden change and what can I do about it time sure my email
Go to your Mail program, then in the top left corner, click on "Mail" then "Preferences" that will bring up your email accounts. Check the settings there to make sure everything is correct.
Dec 17, 2014 | Apple Computers & Internet
Mac serial numbers C07M3AV8DWYL
According to the serial number, the late 2012 Mac mini's maximum Resolution: Up to 2560 by 1600 (Thunderbolt) or 1920 by 1200 (HDMI). However, this mini does not have a slot loading DVD drive.
The last mini with a slot loading drive was made in 2010. That model's maximum resolution is Up to 2560 by 1600 (Mini DisplayPort) or 1920 by 1200 (HDMI)
Aug 20, 2014 | Apple MAC MINI 266GHz Intel Core 2 Duo 8...
Zte drivers download
While Android phones already have Android File Manager as an option for transferring data, ZTE offers its own suite at http://joinme.ztems.com/ which will install ZTE-specific drivers on your Mac. JoinMe Mini is a simple file manager while the Mac version of JoinMe PC also offers synchronization with the address book and other data.
May 11, 2014 | Apple MacBook Pro Silver 13.3" Ultrabook...
How can I boost up mac mini 2007
Your best bet beyond maxing out memory will be upgrading to an SSD. Depending on your operating system and versions of installed software, try using a program like XSlimmer to remove any powerpc files included in universal bundles.
Oct 09, 2012 | Apple MAC MINI 266GHz Intel Core 2 Duo 8...
Driver needed for a mac----where can I get it please? WP8060 tablet
Hi Was facing the same problem with my iball wp8060 tablet and macbook. After a lot of searching....the mac driver from xp-pen is working.
http://www.xp-pen.com/download/xpc.htm Mukul
Sep 11, 2010 | UC-Logic WP8060U (689076313025)
USB to serial converter will not link to Macbook
the mac is still a mac but running windows, is sewing machine pc/mac compatible? if it is then boot under osx if u cant its not osx compatible only pc
Apr 24, 2010 | Apple 13-inch MacBook - Intel 2.0GHz Intel...
Cannot use the scanner with Apple Macintosh - no driver!
Hello, I had the same problem.
The thing is the printer is compatible with the mac the scanner isnt.
Pretty dumb but sadly true.
Hope this helps you!!
May 24, 2009 | Canon CanoScan 3200F Flatbed Scanner
Driver for mac
Hi, this is Erik Thau-Knudsen (from Silkeborg, Denmark, by the way) back again. The problem was with the local importer (AGK Nordic), not with the tablet itself. Some googling brought me to the Mac OS X file itself, located at http://www.uc-logic.com/download/driver/OS%20X_PenTablet_Driver1.24.zip.  On the download page http://www.uc-logic.com/download/download_driver.htm, you can find device drivers, written for the following operating systems:
  • Microsoft Windows 98
  • Microsoft Windows ME
  • Microsoft Windows NT
  • Microsoft Windows 2000
  • Microsoft Windows XP
  • Microsoft Windows XP64
  • Microsoft Windows Vista
  • Apple Macintosh OS 9
  • Apple Macintosh OS X
Thank you for your tips, notably about the manufacturer.
Erik Thau-Knudsen
Jul 08, 2008 | UC-Logic WP5540U (689076312929)
Driver for mac
Google for: PF1209 Mac driver (you may add UC-Logic, Genius, Pentagram, Trust)  and find the OLDEST available driver. It should be a .pkg file after extracting.
Install it (it should be the v.1.0 control panel) and then you may install the recent v.1.24.2 driver over it.
It is still a bad written chinese PPC code conflicting with some applications but it works in the meantime.
 While the whole planet slides down on the windoze-****  - I'm waiting for a real Mac driver too ;o)
Apr 01, 2008 | UC-Logic WP8060U (689076313025)
UC-Logic WP8060U (689076313025) Logo
5,015 people viewed this question
Top UC-Logic Computers & Internet Experts
Jerry Greenberg
Jerry Greenberg
Julian Wainwright
Are you an UC-Logic Computer and Internet Expert? Answer questions, earn points and help others
