Question about Hitachi DS18DMR 18V 1/2" Driver Drill
Keyless Chick will not Release - Hitachi DS18DMR
This drill, Hitachi DS18DMR, will not release the bit in the keyless chuck. I just finished using a spade bit and had no problems. When attempting to free/release the bit the chuck will not budge. It almost rips the skin off your hands.
Any help would be appreciated, Dave
  • Anonymous Feb 14, 2009
    I have had the same problem and have still not figured it out.
  • blueextc3221
    blueextc3221 May 11, 2010
    The bit may have wedged in the jaws.
    Have you tried to use a channel lock pliers to hold the chuck?
    Or stick it in a vise?
    Re-Post your results if you need more help.
    Scholar:
  • 74 Answers
It's best not to use the drill power and your hand to try and release. Or tighten for that matter.
Set the drill down, and try using both hands on the clutch.
If that don't work, try using vise-grips or channel locks.
If that don't work, whip out of the WD-40 and let soak and then try again.
Posted on Feb 10, 2009
How do I load the drill bits in the keyles chuck of my Metabo impact drill Model SBE 561?
Keyless chucks work one of two ways
1: Simply turn the chuck by hand to loosen or tighten drill bit, once it grips the drill bit you will not be able to turn it anymore
2: Some keyless chucks operate by pulling the chuck back towards the body of the drill, placing the drill bit in and then releasing the chuck back to its original position
Sep 08, 2014 | Drills
Ryobi 18v drill keyless chuck stuck
Try holding the bit in a vice and gently tap the chuck off of the bit and see it it releases the pressure on the jaws.
Jun 20, 2012 | Ryobi 18v Cordless Drill - P206 18 Volt V
Keyless chuck has bit stuck in it
use some kind of lube like liquid wrench or wd40 and let it set for a bit. Then tap it with anything like a wrench, hammer, etc.
Feb 12, 2012 | Drills
How do you release the bits to change sizes
It is a keyless chuck. You should be able to grab the main body of the chuck and turn it to the left to release the bit. You can also hold the main body of the chuck and run the tool slowly in reverse whcih will also release the bit.
Jul 10, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
Cannot get the chuck to release the bit it is a dewalt and yes I am in reverse
On some of the DeWalt drills I have owned with keyless chucks, the chuck has a locking mechanism.
You have to grip the chuck and slide the outer sleeve forward to release the lock, then you can tighten or loosen the chuck.
Apr 14, 2011 | Drills
A bit is stuck in my cordless Hitachi DS18DFL keyless drill chuck. How can I get it to release?
There are always 2 different rings to the chuck grip surface, you always hold the back one and turn the front one counter clockwise.
You should be able to do this by hand.
But if it is really tight for some reason, you could use a channel lock pliers or even a pipe wrench if you had to, but both might leave some marks.
Feb 27, 2011 | Hitachi DS18DFL 18V 1.5Ah Lithium Ion...
I have a drill bit stuck in my drill and I can not get it out of the chuck How can it be released from the chuck that I can change to an other drill bit.
By stuck do you mean that you can not release the chuck? if so then you can use 2 channel lock pliers to grip the chuck and the base to break it free. i have done the same on a keyed chuck and a keyless chuck .
Oct 03, 2010 | Garden
Keyless drill has locked in a closed position with the drill bit
I just put mine in reverse and grasp the chuck with a pair of channel locks. Pull the trigger and hold the channel locks tightly. The chuck will release the bit.
Jun 04, 2010 | Craftsman 3/8" Corded Drill
Trying to remove a jacobs key less chuck 500 series fitted to a DS18DL Hitachi drill
It twists off counter clock wise. The best way I have found to remove the chuck is to stick a screw driver into the chuck, tighten the chuck, hold the screw driver in some type of vise and run it all full speed in reverse
Jan 02, 2010 | Hitachi DS18DMR 18V 1/2" Driver Drill
Hitachi DS18DMR 18V 1/2" Driver Drill Logo
626 people viewed this question
Top Hitachi Drills Experts
John Trevino
Are you a Hitachi Drill Expert? Answer questions, earn points and help others
