Question about Philips 32PT9005D TV
Ticking? When I plug the tv into the outlet it makes a ticking sound and will not turn on?
  • Jeanette Anderson Jul 15, 2007
    How much is it going to cost me to buy a new one?
If It's the L01.1 chassis first desolder one end of L5561. If the ticking stops i means that the problem is not in 'MAIN SUPPLY' load. Change Q7460. You should also change C2455 because Q7460 will blow soon after if you dont.
Posted on Jul 28, 2007
  • Philips Master
  • 12,061 Answers
When this happens it is invariably the SMPSU, (Switched Mode Power Supply Unit), Generally the "Chopper" transistor has faulted. o you could either simply buy a complete PSU OR fix, replace, the faulty part. Then ya should be good to go.
Posted on Jul 15, 2007
SOURCE:
Seiki tv ticking
Please post once and wait.
Jul 13, 2017 | Seiki Televison & Video
My speakers won't turn on at the outlet that my power strip is plugged into, nor when plugged into any of the outlets on the strip, however the computer and monitor are running off the power strip and...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar:
if his does not fix the problem
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
Jul 01, 2011 | Logitech X-530 Computer Speakers
PROSCAN TV
Hi
the ticking sound is coming out from the flyback that is high voltages!!! if you on the unit is there a picture coming out? or sounds coming out from speaker?
Thanks!
Jul 02, 2008 | Televison & Video
No power no lights good fuse...
Try a different power outlet? Possible shut down of DC supply due to short circuit can be heard if listen close at back of TV on plug in or power up with remote for a quick squeel then ticking sound or tick tick tick and nothing.
May 13, 2008 | Sony KP-43T90 43" Rear Projection...
Tv will not come on
Bad flyback transformer part # 257807 possible damage to horiz out xistor # 237470...change transformer first,then xistor if you
must.....no generic....OEM quality only........T.
Mar 10, 2008 | RCA 36F530T 36" TV
Our Syvania tv just stopped working. No sound, nothing. We checked the elctrical cords, and remote etc. It will not turn or click on at all.
You may have a blown fuse inside the TV. Also make sure your AC outlet is working by plugging in another lamp to the same outlet.
If your outlet is ok, your TV needs service and repair.
Feb 24, 2008 | Televison & Video
No picture, then no picture and no sound
if your could hear a slight ticking (tick-tick tick) or whining then some electronic component might have been damaged (shorted). if you have no experience repairing electronic equipments then i suggest you to send your TV to a service station!
Nov 14, 2007 | Toshiba 27AF42 27" TV
Philips 32PT9005D TV Logo
75 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
