I want to scan a form and save it, and be able to fill in the blanks later. I can save it as a pdf document, but can't edit it.
    Problem Solver:
  • 12 Answers
When you scan it, the original manufacurer's software should allow you to save it as a Word document or some other editable format. PDF, JPG, TIF, and other image formats probably won't work.
Posted on Jan 26, 2009
Word docs sent as email attachments are arriving in my inbox as png files - useless. How do I change this please
.PNG stands for "Portable Network Graphics". Sounds like the sender may have scanned the document, and sent the scanned document to you? Scans will come out as either .png, .jpg, or .pdf formats.
If the file is a .png, you won't be able to edit in MS Word.
Another thing to check - Make sure when you are working on a Word Document, you are saving it as a .doc file.
  • Open MS Word Document
  • Do your editing
  • Click on the "Fille" button, and then select "save as" option
  • In the window that appears, next to the "save as type" wording click on the down triangle to see different formats to save. Select ".doc"
Bottom line... tell whomever is sending the emails with attachments, to send you the MS Word file, not a scanned file.
Jul 26, 2014 | Dell Inspiron Computers & Internet
How can I edit an existing form?
you could scan the document and save it to my documents for further editing
lift the lid on your scanner lay the document face down then select scan document it will ask what
format you want to scan it then it will ask where you want to save it browse select the file/folder where you want to save it (my documents) most common
to make a folder right click in my documents select new folder and name it
once you have saved it you should be able to edit it
hope this helps
Jun 24, 2012 | Computers & Internet
I now have office2010 how do u scan a form in to be able to type on the form?
what you want to do, is not possible. Only way to properly write on a form, is that you have the original digital computer version of it, sure you can scan it, but you can not use / write on the same way. Sure you can use the computer to ADD text into the form, if you scan it as a picture, and then use the Microsoft paint program to add text on the fields. But its not the same as having the original digital form to write on.
Or then I'm not informed on how to Scan a form, to turn it into a form and then to fill out that form on your pc.
Sep 28, 2011 | Microsoft Office Home and Student 2010
How to change scanning from picture to pdf
once you have scanned the picture and saved it . right click on the picture icon. click edit. it should take you into a editing tool like paint . then click file . save as and then the bottom option you can change it to save as a pdf or png or jif, anything your heart desires
May 05, 2011 | Computers & Internet
I own canoscan Lide-25. I want to scan forms and fill in the blanks of the form from my computer then print for my use. How to do this? Am I to buy any splecial software other than OCR already provided.
I wouldn't use OCR, too difficult. I would save your scanned document as a jpeg and edit in Photoshop. From Photoshop thay can be printed or saved as a pdf file.
Mar 31, 2010 | Canon CanoScan LiDE 25 Flatbed Scanner
Can't save Adobe Acrobat 9 fillable forms
Fill in an interactive pdf form After you fill in the form fields, do any of the following:
  • Click the submit form button. Clicking this button sends the form data to a database across the web or over your company intranet.
  • In Acrobat, choose File > Save As, and rename the file to save the form with the data you entered.
  • In Reader, choose File > Save A Copy, and specify a location for the copy. Note: If the form author gave Reader users extended rights, the saved copy will include the entries you made in the form. Otherwise, the saved copy will be blank.
Enable Adobe Acrobat Reader users to save form data Ordinarily, Reader users can’t save filled-in copies of forms that they complete. However, you can extend rights to users of Reader 8 and later so they can do so. In Acrobat Pro and Pro Extended, these rights also include the ability to add comments, use the Typewriter tool, and digitally sign the PDF.
  1. Open a single PDF, or preview a component PDF in a PDF Portfolio.
  2. If you are editing the form, click Close Form Editing in the upper-right corner of the form.
  3. Do one of the following:
    • (Acrobat Pro and Pro Extended) Choose Advanced > Extend Features In Adobe Reader.
    • (Acrobat Standard only) Choose Advanced > Extend Forms Fill-In & Save In Adobe Reader.
    These extended privileges are limited to the current PDF. When you create a different PDF form, you must perform this task again to enable Reader users to save their own filled-in copies of that PDF.
If you don’t want recipients to overwrite the blank form template by saving form data, do not extend rights in the copy you send to them.
Limitations on saving filled-in forms locally
Acrobat Standard, Acrobat Pro, and Acrobat Pro Extended each allow Adobe Reader 8 or later users to fill in and save PDF forms locally. The use of the Reader Extensions capability for local saving of PDF forms (called extended documents) is limited in two ways:
Number of deployed extended documents An Acrobat Standard, Acrobat Pro, or Acrobat Pro Extended customer can send an extended document to an unlimited number of recipients for them to fill in. For example, an Acrobat customer can post an empty form template on a web page that allows users to fill in and save PDF forms locally. An unlimited number of people can access the template. However, the Acrobat customer can collect only 500 responses from the filled-in form. This limitation includes both hardcopy (paper form submission) and electronic representations of the filled-in form.
Number of recipients of the extended document An Acrobat Standard, Acrobat Pro, or Acrobat Pro Extended customer can send an extended document to no more than 500 unique recipients. For example, an Acrobat customer belongs to an organization with 500 people or less. The Acrobat customer can send an unlimited number of copies of the extended document to those 500 recipients and collect unlimited responses from the filled-in form.
Both limitations apply per entity/company, and multiple users in an entity cannot abuse this feature. Obtaining additional licenses to use Acrobat Standard, Acrobat Pro, and Acrobat Pro Extended does not increase the above restrictions. For example, five Acrobat Standard 9 users in a company cannot send out the same extended document to receive and extract data collectively more than 500 times.
Acrobat Standard, Acrobat Pro, and Acrobat Pro Extended include technology that can enable PDF documents with certain features by using a digital credential. This credential is located within the Software (“Key”). You agree not to access, attempt to access, control, disable, remove, distribute the Key for any purpose.
I hope it helps.
Regards
Mar 16, 2010 | HP Computers & Internet
I AM TRYING TO FILL IN AN APPLICATION FORM IN A PDF FILE AND I DON'T GET ANY OPTIONS TO HIGHLIGHT TEXTS. IS IT BECAUSE THE COMPUTER I'M USING DOESN'T HAVE MICROSOFT WORD INSTALLED?
What program did you use to open the PDF? If you opened it with the default program, you probably used Adobe Reader which does not allow you to edit PDFs. You can import PDFs into several Office suites with add-ons. For example, Open Office 3 has a PDF add-on that lets the PDF be opened and modified in Draw and Impress. There are also online PDF editors and some low cost alternatives to Adobe Acrobat is the full program that makes PDFs. PDFill PDF Editor gets some good reviews
http://download.cnet.com/PDFill-PDF-Editor/3000-6675_4-10295757.html
as does www.pdfescape.com/ (an on-line option). Please note that most will put their logo on your document as a footer or somewhere unless you use a paid version.
I hope this helps.
(word does the PDF import more easily as I recall (possibly with an add-on) but there are alternatives.)
Feb 19, 2010 | Microsoft Windows Vista Home Premium...
Help with adobe 7.1.0
In order to edit a PDF document, you will need either one of Adobe's commercial Acrobat products or a similar third-party application.
You can often copy the contents of a PDF document to a word processor or text editor program (e.g., Microsoft Word or Notepad) and then edit them, but in this case you cannot resave the document as PDF (unless your word processor specifically has the ability to create PDF files).
To copy the document's contents:
from the Adobe Reader Edit menu,
choose Save as Text.
Alternatively, from the Edit menu, choose Select All; then, from the same menu, choose Copy, and then paste the text into your word processing program using that program's paste function.
May 07, 2008 | Adobe Acrobat 7.0 for PC
Need to scan a form to be filled out to computer
If you scan a form onto a computer, it won't behave as a form by default. This is because the computer is just storing a picture of the form, and doesn't see it as a form.
To make a scanned form into an electronic version, you will need some software that lets you define the regions of the form that can be filled in by the user. the full version of Adobe Acrobat lets you do this, as do the less expensive programs CutePDF Professional or PDfill.
Basically, you scan your document into a pdf format and use the aforementioned software to define which regions on the form should have typable text, checkboxes, etc., then you re-save it as a fillable pdf.
This works well, I do this with all my rental applications, etc.
There is a little bit of learning required to do this, but if you spend some time with the program and its helpfile you'll be creating forms with the best of them!
Apr 22, 2008 | Office Equipment & Supplies
Editable forms with Adobe reader?
With adobe profesional you can make a PDF form, and send to the recipients. They can fill the form with Adobe reader and send it to you back, but only the data will be sent to you, not all with the pdf.
You can collect the data with your adobe profesional. Your programmer of medical paperless system can make the program to put that data in your database.
Here is the simple procedure:
1. Create form: Open adobe prof, menu advance --> Form --> create new form. You will go to Adobe design to create the form, there you can also retrieve your scanned document.
Don't forget to put "submit button" and your email address.
2. Then save as pdf form. It is ready to be send to your recipients.
3. The recipients will fill the data and send to you by pushing the "submit button".
4. You will receive the data in your mailbox, as an attachment of email. You can use adobe prof to collect it, example to put it in Microsoft Excel.
Go to menu advance --> form --> Create Spreadsheet from data files. A dialog box will come out, put in the files you received from your recipients. then go on, you will have the Excel data.
For put it in your database of your system, your programmer should create a program/ included in your system's program.
For Guest, to fill up is easy, just open the pdf form with Adobe REader, fill it and click the submit button.
Apr 15, 2008 | Adobe Acrobat Professional 7.0 for PC
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
