Question about Acer MF35 MP3 Player
When i try to start the music it says disk error
  • 4 Answers
The reason is: the software cant read data from the storage medium. When the software built in looks at the command to get data and executes it the storage medium (hard disk) isnt responding. It is likely a hardware error. If the item is new than try returning it to the store it came from or exchanging it. Also check the manufacturer as they may replace it under warranty.
If you do not have these options than try to search google for a FirmWare update specific to your model of player. This is usually available from ACER or whoever made the unit. If that doesnt fix the problem than it is a hardware problem for sure and probably is destined to meet the trashcan.
Good luck
Posted on Mar 15, 2009
What do I need to do to resolve errors on my Superstore PSD330 CD-RW?
Try using a laser lens cleaning disk. If that doesn't do it check you data cable from the drive to the motherboard.
Bob
Nov 18, 2014 | Computers & Internet
DISK ERROR IS POPPING UP WHEN I TRY TO PLAY MUSIC
The processor can't access the memory chip because either its corrupted or has died. Connect it to a pc and try to format it and then add some music files.
If you can't format it or you get the same error after it then it's dead, get a new one.
Jan 09, 2011 | Mach Speed Eclipse 180SL 4GB MP4 ...
My Boss br-8 keeps saying medium error. It's not reading any disc. It ask me to initialize disc that already have music on them.
If the disk had music that was not CREATED on the BR-8 you will get the error. The format is incompatible with computer formats.
If the files were created on the same BR-8, then you probably have a disk drive failure.
Try initializing a blank disk. If it will not, then you have a drive failure.
Also is it possible you are trying to read a 250Mb disk on a 100Mb drive? That won't work either.
Jul 25, 2010 | Boss Micro BR Digital Recorder
Down loaded msn explorer 8 pc will not start up TMGR missing
The "TMGR" is a Windows Operating System component file.
This error might occur if the TMGR file is corrupted or missing.
However, as this is a Operating System Component file, you may resolve the issue by performing the below steps.
First, you may try performing the SFC Scan.
Performing the SFC Scan will automatically fix any damaged files or any errors in the Registry.
Steps to initiate the SFC Scan:
1) Open the RUN command window.
2) In the RUN command window, type "cmd" and press Enter.
3) In the Command prompt, type cd
4) Then. type cd Windows and press Enter.
5) Then type sfc /scannow and press Enter.
6) This will start the SFC Scan process.
The Computer might also ask for the Windows Operating System Disc.
Peforming the SFC Scan should resolve the issue with the TMGR file.
If the issue still persists, initiate the Disc checking process.
For Windows XP:
support.microsoft.com/kb/315265
For Windows Vista:
http://windows.microsoft.com/en-US/windows-vista/Check-your-hard-disk-for-errors
For Windows 7:
Jul 05, 2010 | Acer Aspire One PC Notebook
MP4 disk error!!
FORMAT your player in Windows to see if that helps resolve the problem. Either a problem with the memory or a possible memory hack. Take a look here: http://mympx.org/forum/support-how/35010-how-removing-memory-hack.html.
Hope that helps.
Jun 27, 2009 | Dane-Elec Music One MP3 Player
DVD player is unable to read any disk to initialize play
Laser is probebly goin bad and can't read. try putting a music Cd in. If it can play the music CD but not the DVD it's the laser.
Apr 10, 2009 | Panasonic DVD-RV26 DVD Player
Disk is Locked Error
If the My Music folder is in the wrong location or incorrectly assigned in the Windows registry, you may see one of the following error messages:
  • "The folder iTunes is on a locked disk or you do not have write permissions for this folder."
  • "The folder iTunes cannot be found or created and is required. The default location for this folder is inside the Music folder."
If you see one of the above errors, follow these steps to troubleshoot this:
  1. Verify the location of your Windows XP My Music folder. The default location for this folder is
    C:\Documents and Settings\username\My Documents\My Music
    If you do not have this folder at the default location and have not moved it to another location, consider creating one inside your My Documents folder.
  2. Download and install Tweak UI from the Microsoft PowerToys website at http://www.microsoft.com/windowsxp/downloads/powertoys/xppowertoys.mspx Note: This utility is for Windows XP only. Please review the system requirements before installing.
  3. Once you have installed Tweak UI, open it from the Start menu.
  4. In the column on the left, click on the plus symbol (+) next to My Computer and select Special Folders. ht1866_01.jpg
  5. In the right pane on the Folderlist, click My Music.
  6. Click the Change Location button. You may see a warning message appear with precautions for changing this setting; after reviewing the message, click Yes. ht1866_02.jpg
  7. In the resulting window, browse for the My Music folder as described in step 1, and click OK. ht1866_03.jpg
  8. Reinstall or open iTunes.
Oct 13, 2008 | Apple iTunes
Error disk help cant remove
im trying to got to music bet it keeps on going to disk error
May 01, 2008 | Audio Players & Recorders
Mp3 space
Try starting from scratch.
Right click the drive and choose Format-> FAT32,->QUICK Format->Start. This will only take a few seconds.
Reload your music.
Feb 22, 2008 | iLO MP3 Player
Insufficient Temporary Disk Space Error
Find out where it wants to store the temp files, it may need to be changed tc c:\my documents for example.
Dec 19, 2006 | Harmonic Vision Music Ace for PC, Mac
Acer MF35 MP3 Player Logo
61 people viewed this question
Top Acer Audio Players & Recorders Experts
NOEL
NOEL
Are you an Acer Audio Player and Recorder Expert? Answer questions, earn points and help others
