Replacement bushing for dp-5 turntable
The bushing fits on the motor shaft directly under the turntable. The lower portion of it engages with a large gear
MicrowaveSvc
  • 9098 Answers
SOURCE: The turntable makes grinding niose when engaged
That model number doesn't ring a bell. Is that right? Is it foreign?
Chances are the coupler and/or turntable support will be damaged or warped.
Also on some brands, the "packing" (often a rubber grommet) must be replaced.
Posted on Oct 22, 2007
SOURCE: Lower Control Arm Bushing replacement
I just did this job on my 98 regal, and I own the service manuals also. The lower control arm bushing that usually goes, is the front one. The rear one doesn't usually go, it is horizontally mounted. The front one for some reason is vertical. The control arm must be removed, and put in a vise. The front bushings outer metal sleeve, must be driven out with a chisel. It comes out easily. The new bushing can be tapped in with a hammer. Hope this helps!
JOEVETTE
Posted on Mar 01, 2009
BTBG
  • 3 Answers
SOURCE: brass bushing on my popcorn maker
Nostalgia Electrics
The Helman Group, LTD.
1621 Beacon,CA,93033
(805)487-7772
fax(805)487-9975
www.helmangroup.com
Posted on Mar 27, 2009
  • 92 Answers
SOURCE: Gear after the motor is stripped
yes it can
Posted on Aug 28, 2009
wd4ity
  • 4565 Answers
SOURCE: starter drive gear wont engage on a HD fxrs
Sounds to me like the "overrunning clutch" is bad. You'll have to remove the starter and disassemble it. The starter drive is part #31663-90 according to the latest V-Twin book I have. It may have a different number on your 2000 model.
Posted on Sep 24, 2009
Belt location
1) Remove the platter - just lift up
2) Underneath the platter, you'll see a small lip section
3) Wrap the belt around this lip
4) Put platter back on turntable
5) Rotate platter until you see the motor shaft through the holes on the platter - a brass round looking piece
6) Pinch the belt around the motor shaft.
7) That's it.
- OPTiC
MasterTech
Digital Analog Therapy
Turntable Parts : Turntable Repairs
Jul 18, 2009 | Audio Technica USB Turntable
Tip
Replacing a Gearcase on Whirlpool Manufactured Top Loaders
This advice is for Kenmore, Estate & Whirlpool TOP LOADING DIRECT DRIVE type washing machines. Read the instructions thoroughly BEFORE attempting. This is a repair of MODERATE difficulty that can be accomplished easily if you follow the steps provided:
1. Unplug washing machine.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
7. Remove the water pump. This is a small pump located in the front of the washer directly under the wash tub. It has two hoses leading to it. LEAVE THE DRAIN HOSES IN PLACE and remove the two retaining clips. The front of the clip pops off with a gentle pry of a screwdriver, while the back is in a keyed slot. Once released from the pump, turn the clip to remove from the slot. Pull the pump off the motor shaft and push it aside while leaving the hoses attached.
8. Remove the Drive Motor. Remove the electrical connection(s) first using care not to break any of the wires. Loosen the two 1/4" hex bolts that hold the Drive Motor retaining clips in place. Now, place one hand under the motor and lift gently while prying the top retaining clip with a screwdriver. This will release some of the tension on the clip and make it slightly easier to remove. (WARNING: the motor has some weight to it, so be prepared to support it when you release it). Once the top clip is released, the bottom one should come out fairly easy. The clips are similar to the ones that hold the water pump in place. They are inserted into a keyed slot and are slightly longer.
9. Once the Drive Motor has been removed, the Motor Coupling is directly behind it. There are two plastic three-pronged pieces with a rubber bushing connecting the two. One plastic piece is inserted on the Drive Motor shaft, while the other piece is inserted on the transmission shaft. You may have to use a screwdriver to remove the old pieces. Inspect both halves of the coupling for signs of wear. Replace if necessary (part #285753A).
10. Uninstall the motor mounting plate from the gearcase by removing the two bolts.
11. Remove the agitator by removing the center cap. Locate the center nut under the cap and loosen with a socket and ratchet. Lift both portions of the agitator straight up, exposing the gearcase center shaft. Remove the agitator clip and agitator washer from the shaft. NOTE: If there is a recessed square slot under the agitator cap, use a 3/8 inch to ½ inch socket adapter with extender to remove.
12. Now take the washer and lean it backwards so that you have full access to underside of the washer. Loosen the three bolts holding the gearcase in place. When you get the last bolt, loosen slowly as the gearcase will begin to drop from under the washer. Slide the entire gearcase and shaft out of the washer.
13. Remove the clutch and brake assembly from the top of the gearcase by removing the retaining clip. Do not forget to retain the washer that is under the clutch.
14. Inspect new gearcase assembly. Open the breather hole (covered by a dab of paint) using an awl or similar tool. Install washer on gearcase shaft and install clutch and brake assembly. Slide gearcase shaft up through the agitator shaft from under the washer. Hold in place and get one bolt started. Insert remaining bolts and tighten them all evenly.
15. Insert new coupling by tapping one piece onto the transmission shaft with a hammer. Use a dowel or something solid to tap the center portion of the coupling until the opening of the coupling is flush with the shaft. DO NOT hit the prongs or they will break. Do the same for the Drive Motor. Make sure you place the coupling on the correct side of the motor. If you forget, remember that the electrical connections are on the RIGHT HAND SIDE of the motor and that the coupling goes on the REAR shaft of the motor.
16. Place the rubber bushing over the side of the coupler that is connected to the transmission. Rotate the bushing so one empty hole is facing up and the other two are facing down. Now, rotate the coupler on the motor so the prongs will line up with these holes. It's a little tricky trying to get them to line of sometimes. I usually place the lower retaining clip in its keyed slot so that it is resting on the floor. That way, when you get the motor in place, you can reach down while holding the motor up and snap the lower bracket in. You will still need to support the weight of the motor until you get the top bracket keyed into its slot and snapped back into place.
17. Reinstall electrical connector to the Drive Motor.
18. Reinstall Water pump. You may have to rotate the motor shaft slightly to get the slot on the water pump to line up correctly. Make sure you re-install retaining clips.
19. Re-install agitator washer and retaining clip on the gearcase drive shaft and then re-install agitator. NOTE: DO NOT over-tighten center nut. You can crack or break the agitator.
20. Re-install washer case. With the lid of the washer open, grasp the case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
21. Make sure the back of the washer fits into the washer casing on each side by leaning over the front of the washer and grasping the back panel and pull towards you. Reinsert the brass clips by placing the clips into the slot on the back of the washer first, and then forcefully push then down into the opening on top of the washer.
22. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
23. Reinstall console.
It seems like a rather lengthy process, but it is a simple repair if you follow the instructions step-by-step. Read through everything thoroughly before beginning any repairs. I hope this information helpful.
on Dec 05, 2009 | Washing Machines
Tip
Replacing a Motor Coupling
This advice is for Whirlpool manufactured TOP LOADING DIRECT DRIVE type washing machines. This is NOT for older models equipped with a wig-wag transmission that are BELT driven. Read the instructions thoroughly BEFORE attempting. Just follow the steps provided:
9. Once the Drive Motor has been removed, the Motor Coupling is directly behind it. There are two plastic three-pronged pieces with a rubber bushing connecting the two. One plastic piece is inserted on the Drive Motor shaft, while the other piece is inserted on the transmission shaft. You may have to use a screwdriver to remove the old pieces. Make sure you replace BOTH halves of the coupling even if one side appears good.
10. Insert new coupling by tapping one piece onto the transmission shaft with a hammer. Use a dowel or something solid to tap the center portion of the coupling until the opening of the coupling is flush with the shaft. DO NOT hit the prongs or they will break. Do the same for the Drive Motor. Make sure you place the coupling on the correct side of the motor. If you forget, remember that the electrical connections are on the RIGHT HAND SIDE of the motor and that the coupling goes on the REAR shaft of the motor.
11. Place the rubber bushing over the side of the coupler that is connected to the transmission. Rotate the bushing so one empty hole is facing up and the other two are facing down. Now, rotate the coupler on the motor so the prongs will line up with these holes. It's a little tricky trying to get them to line of sometimes. I usually place the lower retaining clip in its keyed slot so that it is resting on the floor. That way, when you get the motor in place, you can reach down while holding the motor up and snap the lower bracket in. You will still need to support the weight of the motor until you get the top bracket keyed into its slot and snapped back into place.
12. Reinstall electrical connector to the Drive Motor.
13. Reinstall Water pump. You may have to rotate the motor shaft slightly to get the slot on the water pump to line up correctly. Make sure you re-install retaining clips.
14. Re-install washer case. With the lid of the washer open, grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
15. Make the back of the washer fits into the washer casing on each side and reinsert the brass clips. Place the clip into the slot on the back of the washer first, and then forcefully push it into the opening on top of the washer. It will snap back into to place.
16. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
17. Reinstall console.
I know it seems like a lot, but it is an easy process if you take your time and follow the steps as written. A new motor coupling should cost less that than $20. The part number is 285753A.
on Dec 04, 2009 | Washing Machines
Ion turntable
7) That's it.
- OPTiC
MasterTech
May 09, 2009 | Technics SL-1200MK2 Turntable
Top load kenmore elite washer model 110.23032102
Sounds like you could have a bad motor coupling. When they go bad they usually shear off and will cause the drive motor to simply free spin and the tub will remain idle. The pump still works because it is driven by the front shaft of the drive motor. Here's how to check and replace:
14. Re-install washer case. With the lid of the washer open, place grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
I know it seems like a lot, but it is an easy process if you take your time and follow the steps as written. The part is available at repairclinic.com. Just type in your model number in the Search Menu and it's located on the first page as item #1195967. Can't beat the price. Only $14 if you do it yourself!
Apr 01, 2008 | Washing Machines
Tip
This advice is for Estate TOP LOADING DIRECT DRIVE type washing machines. This is NOT for older models equipped with a wig-wag transmission that are BELT driven. Read the instructions thoroughly BEFORE attempting. This is a repair of MODERATE difficulty that can be accomplished easily if you follow the steps provided:
on Feb 15, 2008 | Estate TAWS800JQ Top Load Washer
Not spinning
The problem could be a attributed to a broken motor coupling and/or defective gear case (transmission). Since the motor coupling is the easier of the two repairs and least expensive, I would recommend checking the motor coupling first. Here's the steps required to check and replace a bad motor coupling:
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a ***** under each end cap that You will need to remove.
b. If the console does not have removable end caps, You will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
4. Under the console will be two large brass colored clips. Take a large flat blade *****driver and place it in the groove of the clip on the washer top. With the *****driver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
7. Remove the water pump. This is a small pump located in the front of the washer directly under the wash tub. It has two hoses leading to it. LEAVE THE DRAIN HOSES in place and remove the two retaining clips. The front of the clip pops off with a gentle pry of a *****driver, while the back is in a keyed slot. Once released from the pump, turn the clip to remove from the slot. Pull the pump off the motor shaft and push it aside while leaving the hoses attached.
8. Remove the Drive Motor. Remove the electrical connection(s) first using care not to break any of the wires. Loosen the two 1/4" hex bolts that hold the Drive Motor retaining clips in place. Now, place one hand under the motor and lift gently while prying the top retaining clip with a *****driver. This will release some of the tension on the clip and make it slightly easier to remove. (WARNING: the motor has some weight to it, so be prepared to support it when you release it). Once the top clip is released, the bottom one should come out fairly easy. The clips are similar to the ones that hold the water pump in place. They are inserted into a keyed slot and are slightly longer.
9. Once the Drive Motor has been removed, the motor Coupling is directly behind it. There are two plastic three-pronged pieces with a rubber bushing connecting the two. One plastic piece is inserted on the Drive Motor shaft, while the other piece is inserted on the transmission shaft. Often, the plastic tines shear off, the rubber bushing rips, or the center hole on the drive shaft rounds out causing the coupling to slip. Replace the coupling if this is the case. You may have to use a *****driver to remove the old pieces. Make sure you replace BOTH halves of the coupling even if one side appears good.
I know it seems like a lot, but it is an easy process if you take your time and follow the steps as written. A new motor coupling should cost less that than $20. Post back if you need further assistance.
Mar 09, 2008 | Estate TAWX700JQ Top Load Washer
Help~~ the belt fall off
Most turntables have the belt wrapped around the bottom of the turntable platter, and then around the motor. You'll have to remove the rubber mat, to expose some holes on the platter, where you can squeeze your fingers in to pinch/wrap the belt around the motor shaft - generally on the lower left side. You can't miss it. Also, for future reference, here is the operating manual for your unit, and it has instructions on replacement the belt - it is on page 6: http://usa.denon.com/DP29F_DFU_ownersmanual.pdf
Aug 02, 2007 | Denon DP-29F Turntable
24 people viewed this question
 Grubhead
Grubhead
