Question about iLO DVD Recorder DVDR05
Will not read dvd+r
I already cleaned the player
  • 12 more comments
  • philbrickbyr Jan 26, 2009
    the lens was cleaned.the lens or driver cant be fauty because it plays dvds.it will not read a new recordable dvd disc of any brand.it shows no disk.
    already took it apart and cleaned with alcohol. the lens is reading new recorded dvds its not the lens.
    no it never would record.idont understand the question "what os are you using.
    the dvd player works fine. it just will not record onto a dvd of any brand. we tried 3 brands.
    the manual says +r. we tried +r and -r.
    im not on a computer connected dvd player. its a seperate unit.
    no window opens that ask that. the screen on the dvd player says loading then no disc. sometimes it says bypass on the dvd screen.
    it doesnt ever show error.when you press record it says"press source key first to select source of recording." then having selected the source of recording i press record and the window comes up "insert recordable disc." i do. it then says "no disc."
    thanks dr. joseph
    would the lens be faulty and it reads other disc ok
    no. im on a seperate dvd player than the computer. im tring to get it to record.
    alredy opened and cleaned.
    its an ilo dvd player it doesnt list a os.
    Genius:
  • 1,199 Answers
Will it read any kind of disk at all?
Posted on Jan 26, 2009
    Sergeant:
    Novelist:
  • 326 Answers
If its reading some disks but cannot read others that means the lens is working but its weak and is at the end of its life.it reads the disks recorded at higher X and cannot read lower X discs.its definately a weak lens problem.just get the lens replaced to solve this problem for sure. you can rate the solution if it helps u.
  • 50 Answers
If u open the dvd plaver and clean the inside of ur dvd player
  • 2,229 Answers
There are sometimes compatibility problems between DVD +R and -R. I assume you are trying to play something recorded on a computer. Very possibly you have run into that problem. I would suggest getting the recording either on a -R or recorded on a +r on a different computer.
  • 4,806 Answers
Hi there
Its a firmware fault that could be causing the problem, you can download latest firmware from the DVD's website, burn it to CD and flash the firmware of the DVD player.
If that doesn't work, then lens has a fault.
Good luck
  • 86 Answers
Sorry to break it to you, but this is not new.
there are many reported incidents like this, and it ends up with unit replacement with a more reliable one.
a good possibility as to the source of the problem, is a failure in the power circuits.
dont know how good are your skills with electronics, but i believe the best option is to aquire a new unit.
  • 916 Answers
Will the device record anything? will it record when on another setting? will it record wide screen? is there an error shown when you try to record?
  • machadojr_fe Jan 26, 2009
    If you are getting a no disc error with all the recordable discs you will need to replace the lens of the device.
  • 741 Answers
Your new blank disk has to be formatted before it will read it does a window come up when you insert the disk asking to format or copy files.
  • 177 Answers
Hello and welcome to FixYa!,
Try going into My Computer > right click on the CD DRIVE > Recording and ENABLE THIS DEVICE FOR RECORDING
Try this it DOES WORK
HOpe it works for you --P3NGYJ03
    Brigadier General:
  • 5,158 Answers
Some readers will not read +R only -R ... read the manual to confirm that.
Robert
  • 74 Answers
If you have already cleaned the player try different dvd. If not than probably the lens is not working.
Its better to call a technician and get the lens checked.
Regards
    President:
  • 1,214 Answers
Did it ever work?
What OS are you running?
  • Mark Egan Jan 26, 2009
    OS is Operating System
  • iLO Master
  • 19,396 Answers
If cleaning with a cd cleaner did not solve it , then you need to take apart the unit (with power unplugged) and access and clean the lens directly, using soft cotton tips and isopropyl alcohol.
If that still does not work, then you need to replace the lens pickup inside the unit.
  • iLO Master
  • 13,433 Answers
Sounds like you have a faulty lens, the lens would need to be replaced or the whole drive, its easyer and sometimes cheaper to buy a new drive.
The player will read dvd but will not play cd
Richard: This is what EHow.com said: "
  • Turn on the DVD player. It generally takes a few seconds to get going. Take out the DVD if there's one in the drive already.
  • 2 Make sure the disc isn't scratched or dirty. Use a soft rag to clean the disc if you see any smudges. Insert the CD into the DVD player's disc drive and close it.
  • 3 Press the "Play" button on the DVD player or remote control. Some DVD players will begin reading the disc automatically. Pushing the button works just as well.
  • 4 Use the "Scene Selection" buttons on your remote to select a track. Some DVD players have odd ways of ordering the buttons on the remote. You might have to play around a bit before you find all the right buttons to work the CD playing function of your machine.
  • 5 Crank it up and enjoy your music. The DVD player will act just like a CD player and play the tracks of the CD through the TV.
  • Read more : http://www.ehow.com/how_2036285_use-dvd-cd.html
    May 28, 2015 | Televison & Video
    Lg dvd recorder dr1f9h won't read dvds
    About the only thing left is the optical pickup is BAD.
    Jun 11, 2012 | LG DR1F9H DVD Recorder
    Sony dvd player dvp- ns 90v does not read the dvd or cd
    Good day. If your dvd player cannot read the dvd you can do these steps:
    1. Check wires and connection. ( but i guess you already know this )
    2. Check if the dvd has some scratch or lines
    3. Try to clean the dvd with a smooth cloth. ( works for me all the time )
    4. Check if other dvd is working to isolate if this is a dvd issue or a dvd player issue.
    5. If you have a dvd lens cleaner you can use that as well.( This one of the best way to resolve your issue )
    Note: if other dvd are working fine then we might conclude that specifc dvd is already been damage. But if all dvd is not working you might have it check up by a sony tech for proper diagnosis.
    Hope this information will be helpful to you. Thanks for using Fixya and have a great day
    Jun 27, 2011 | Sony DVP-NS90V DVD Player
    DVD player will not recognize any DVDs I put into player. I even took top off and cleaned laser eye and still does not play. Now red light is on in place of green power light. What's up with this thing?...
    No disc error can be a DIY like the following steps.
    Assuming that the disc is good.
    Since you've already done the #1 now proceed to #2.
    1.Cleaning the lens. - Sometimes because of dust the lens can't read any disc.
    Try clean the lens by soft cotton buds. Be careful while doing this.
    2.Replacing the ribbon - Check the ribbon connected to the lens from the main board for scratch, damage. Once it has an open line then of course the lens can't read the disc. Also try to erase the contact by pencil eraser.
    If you've done the steps above and the symptoms still there then the next step requires you a little knowledge in soldering technique and reading the ohmmeter.
    3.Checked the motor - Check the motor that spin the disc with an ohmmeter. You can test it using the ohmmeter (x1) even it is connected on the lens assembly.
    Good motor - reading should be fairly high and it will spin.
    Bad motor - reading will drop to low resistance and will not spin.
    Hint : 50% of my repaired unit the above parts are commonly caused of the problem.
    If you confirmed that you have a defective motor then replace it with a new one. Before replacing the new motor you have to check the clearance of the disc holder with the old one. The clearance should be the same as the old because if not the lens will not read the disc if it is too far or too close.
    If you already cleaned the lens, and confirmed that the ribbon is good as well as the motor then I
    Jan 24, 2011 | Oritron DVD600 DVD Player
    Panasonic DVD-S35 Player H02 problem
    Hi, this is an unfortunate error. this is referring to the lens assembly. it is unable to scan and read at this moment. it could be because the lens is dead or, it could be that the lens is simply dirty and will need to be cleaned. i would try cleaning it with a non brush type cleaning process. Once cleaned and you still have the same issue, i recommend replacing the lens assembly.
    Mar 11, 2009 | Panasonic DVD-S35 DVD Player
    Nakamichi soundspace 11 dvd
    The problem you have is that of the roller of the dvd player.The roller is one the moving back and port bringing the lense set,the roller is dirt already the grease thier is hardened already.Its needs to clean so that performance will come again.By using a lighter fluid to clean and lense is wipe by a cotton with no chemical use.When you do this your player will read again.
    Jun 17, 2008 | Nakamichi SoundSpace 11 System
    Not reading disc
    First Clean the lens:
    http://www.ehow.com/how_2036275_clean-lens-dvd.html
    Feb 26, 2008 | Televison & Video
    Toshiba RD-XS35 DVD Recorder
    Toshiba tech support for this one. If it is not accepting the cleaner disk - you have to wonder if something is already intere or do you mean will not rune the disk? Inwhich case it is a drive failure and needs replacement[of drive if available] or whole machine. Contact Toshiba first though it may be a known issue.
    Jul 05, 2007 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
    iLO DVD Recorder DVDR05 Logo
    216 people viewed this question
    Top iLO Televison & Video Experts
    Jerry Greenberg
    Jerry Greenberg
    Jaime Hernandez
    Jason Morris
    Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
