Question about Jl Audio 12W3v2-D2 Car Subwoofer
My tinsel leads to one woofer keep frying
I have had this prblem fixed twice and it happened again! the tinsel overheats and disconects within the cone! why is it it only happens to one and not the other?????????!!!!!!!!!!!
im workin with an alpine 800watt monoblock
  • blueextc3221
    blueextc3221 May 11, 2010
    Chances are it is not overheating - its that its being over-driven.
    Are the subwoofers in seperate or common enclosure?
    Sealed or vented?
    If they are contacting anywhere on the basket during play, it will cause a short and melt the wire.
    We have had many problems with JL and tinsel lead length.
    Inspect the basket and see if there are char marks.
    RePost so I may help you further investigate.
    Those subs are 300W RMS, and you're giving them close to 400W ea.
Check the impedences. How many ohms are you running each speaker at? Are they both wired the same?
Posted on Feb 20, 2009
  • 112 Answers
Also after repairing unless it's done by a true professional normal solder will not work.. it doesn't flex as well as it does from factory, and it's very hard to extend tinsle lead length, I would suggest returning to original store for swap or return to JL for swap.. (or get new ones.... not JL :) )
Posted on Jan 26, 2009
What keeps killing my power supply in my samsung lcd tv.
There is a short or ground some where that is frying your supply board
Dec 09, 2017 | Samsung Televison & Video
Reapir sony car speaker
Broken tinsel? Ripped cone? Peeling surround? We're not mind readers.
Jan 17, 2014 | Sony Car Audio & Video
Dx-9 series
check for burnt or broken tinsel leads
Mar 18, 2013 | Car Audio & Video
Hi i have a honda CM125C 1985 MODEL. it keeps blowing spark plugs. this caues it to flood and not start. when it does start it will die one me or move but very slowly and then die. i have cleaned the...
Check your standard factory specs for spark plugs, it sounds like ur bike getting OVERHEAT!
Did you happen to check the over head valve camshaft? Ussually that bike , w/ age happen to be more tha 10 yrs old, cam shaft, valve guide are worn out and out of clearance! Check it please!
Hope that make your bike be reliable again!
Nov 07, 2010 | 2000 Honda CM 125 C
My connection from my battery to computer is failing I've had this problem fixed twice and it keeps happening. Been told nothing is wrong with battery its the connection within the computer what can I do?
Well, if its been fixed twice already and doing it again, I would say its most likely over heating. Try using a Chill pad and on the processor clean off the old thermal compound and apply some Arctic Silver #. You can get the AS#5 at RadioShack for about $12 after tax. If your battery is getting hot enough to soften and break the solder connections i would suggest buying a new battery.
Jul 11, 2010 | Toshiba Satellite A100-S8111TD Notebook
The two wires that go from the terminals to the cone? if so its called the tinsel leads.
May 07, 2010 | Kenwood KFC-W3003 Car Subwoofer
The woofer on one of my speakers stopped working. The tweeter seems fine. My DMM shows that the resistance across the 2 internal leads that connect to the woofer continuously cycles from 0 through...
The voice coil is open, you can look real close at the spider wires that are soldered from the two terminals to the cone to see if they are bad, otherwise you will need new woofer, you can try getting the woofer from
Feb 14, 2010 | Boston Acoustics Micro90X Speaker
Turning on the green light comes on, then it beeps twice, then shuts down. Wont turn on again
Yes this is the YLOD the (Yellow light of death) it happens when the GPU and the CPU overheat and you will need to fix this by stopping the heat build up, you can sned it in and they will fix it for you for $130.
Or you can fix it yourself using a good PS3 Repair guide in under an hour!
Feb 07, 2010 | Sony Playstation 3 (PS3) Console
Why lanzar subwoffer keeps flaping when volume is raised
It could be the magnet slowley falling off or most commonly the tinsel leads hitting the spyder.
Dec 22, 2009 | Lanzar (Pair) MAXP104D Max Pro Series...
My wire got pulled off my sub how can i fix it
Hello gatmanfromda,
I'm assuming you mean the "tinsel" lead going from the connector to the sub cone. In many cases, the wire can be soldered back on. It takes care and patience and you need to be sparing with the solder and prevent it from stiffening the tinsel lead. Otherwise it will tear out again when the sub cones moves out. If the cone itself was damaged when the lead pulled off, you can use silicone sealant to repair it. Again, be sparing with the silicone and allow it 24 hours to set up before trying to operate the sub. If the wire pulled off from the connector terminal, just solder it back on.
Hope this helps.
Jul 11, 2009 | Kicker CVR12 Car Subwoofer
Jl Audio 12W3v2-D2 Car Subwoofer Logo
323 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
