Question about PPI PCX-2200 Car Audio Amplifier
Problem in ppi pcx-2400
My amp powers on and the led light turns to green like always but i am not getting any sound from my subs i checked the wiring and nothing is dissconnected. It was weird because it was working and then i stopped by a friends house and turnded off my vechicle when i turned it back on i was not getting any sound from my subs but like i said the led light is on in green any help to a solution would be appreciated
  • 105 Answers
Check the amplifiers fuses. Some amps have speaker fuses that leave the LED on if blown. Check for continuity on the voice coils of both subs. Check for 12 volts on the remote turn on line from your receiver. If all of the above are good, the amp is probably toast.
Posted on Jul 15, 2007
SOURCE:
I HAVE A PPI PCX 2200 THAT IS NOT GETTING ANY POWER AT ALL I CHECKED ALL FUSES STILL NO POWER
1.verify connections...Make sure your ground wire is grounded to a location on the body where you will sand the paint away to make good metal to metal contact. 2.with a volt meter check for battery voltage on the red wire of the amp as close to the amp as possible.verify that your remote or trigger wire from the radio (blue wire) id connected to the remote terminal of the amp.. turn on key switch, turn on radio and see if amp powers up. if no then verify 12 vdc at the remote terminal of amp, very 12vdc at red power wire. verify ground. If all this is good i would suspect you have a faulty amp.
May 05, 2011 | PPI PCX-480 Car Audio Amplifier
I have a PPI PCX-2400 and want to power two TREO subs that handle 2500 watts apiece. What is the best way to ire the PPI to these subs so that I get as much power from the amp to the subs without causing...
That would depend on the impedance (resistance) of the subs. Your best bet would be to use the full power of the amp to one channel (i.e. bridged) instead of to two separate channels (i.e. stereo). Two 4 ohm subs wired in parallel would present a 2 ohm load to the amp, which should allow you to get all 1600w out of it.
This explains series vs parallel quite well:
http://www.termpro.com/articles/spkrz.html
Mar 03, 2011 | PPI PCX-2400 Car Audio Amplifier
Subs and amp sat in my garage for a year. I just
check your subs by connecting them straight from the stereo. If they work then there is an issue with the signal comming from the stereo through the rca cables to your amp, check those. Try another amp if you can with those rca's or test the amp with a friends car, either way try to rule out everything until it points to the problem.
Apr 17, 2010 | PPI PCX-2200 Car Audio Amplifier
My ppi 2200 power light flash's on and off
yes you have a internal fault of the amp. the circuit that puts it into safe mode is bad and that is a very small chip on the board know as a op amp. needs to be repaired.
Feb 03, 2010 | PPI PCX-2200 Car Audio Amplifier
Amp runs but then will just turn off and red light comes on
you may have fried the amp pre outs in the head deck, try the amps on another stereo
Jun 01, 2009 | Lightning Audio Bolt B2.150.2 Car Audio...
PPI AMPLIFIER NO SOUND PSX-280
make sure the remote wire from the deck is in the amp but move your ground wire to a new solid metal location you may have to scrape the paint surface where the ground is going to go but it will stop protect mode and run properly (make sure to bolt it down by its self no other wires just the ground from amp) also make sure the ground wire is bigger than the power wire
hope this helped
Mar 03, 2009 | PPI PCX-280 Car Audio Amplifier
Cant figure out where to connect the remote wire to
The Remote Wire Connects to the Blue Wire From the Stereo If you have an Aftermarket Stereo. This will control the Amps Power with the Ignition Start and Accessory Positions.
Jan 31, 2009 | PPI PCX-2125 Car Audio Amplifier
LED Light is on, but no sound from sub at all.. Have double backed on all wires but still nothing! HELP!!
if you change amps and it goes on protection the speakers are blown causing the amp to protect try changing speakers
Mar 24, 2008 | Car Audio & Video
Amp has Red LED light on.
Disconnect all speaker wires and signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp likely has blown output transistors.
Nov 05, 2007 | Soundstorm F2600 Car Audio Amplifier
PPI PCX-2200 Car Audio Amplifier Logo
193 people viewed this question
Top PPI Car Audio & Video Experts
Mike Duncan
Mike Duncan
Anthony Ward
Anthony Ward
Are you a PPI Car Audio and Video Expert? Answer questions, earn points and help others
