Question about HP Pavilion a1220n (A1220NED904AA) PC Desktop
No connection from cd to board
Not sure i have the correct connections from cd and dvd to the motherboard or to sound card, dom\n't know right place to connect
    Problem Solver:
  • 12 Answers
It would be helpful if you had some pictures of the back of your CD. There are basically three connections on the back of a CD or DVD. one is the sound cable, which is usually two or three pins, and there is only one way to plug it in. The next cable is data, and that also plugs in one way only. Final cable is power, and that one also goes in one way only.
The problem you may be having is if you have a mismatch between the drive and motherboard. The old standard is IDE/ATA, the new standard is SATA. If the cables are mismatched, you can buy adapters to convert from one standard to the other.
Posted on Jan 26, 2009
I dont think iv put my dvd rw in proply i think
Yes, you will need a small audio cable that runs to your sound card or motherboard. Many computer repair shops will have a bunch laying around. Or eBay PC sound card to CD DVD drives internal audio cable 3 connectors 64cm...
Sep 10, 2014 | Computers & Internet
Creative sb 5.1 vx low volume on windows 7
click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers
right click on the speaker icon in the bottom taskbar you will see an array of options select playback devices make sure it has a green tick and the correct speakers are selected
be updated if you computer came with a motherboard disk the drivers could be on it although once speakers are connected widows 7 should automatically update the drivers
click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker
you might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down
list in the advanced tab select dvd quality or another then apply
right click on the speaker icon in the bottom toolbar select playback devices should be a green tick in the speakers if not right click select configure also check the communications tab make sure the are not muted
hope it helps
Jun 22, 2012 | Creative Sound Blaster 5.1 VX Sound Card -...
My computer sound is not come
Make sure you sound module is pluged into the right place on the board! and that you have your cd or dvd wire pluged into the board runing to your player! then make sure you have your sound card drivers installed also! I hope this helps!
Jun 01, 2011 | MSI K9MM-V Motherboard
I booted my PC, but there is no display in the monitor. Tried with the other monitor but it all seems the same. The board have power but no display.
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections needs its connections continue its cycle and to have an end so any faulty leads will end up with a computer error
hope this helps
Apr 25, 2011 | MSI K9N6SGM-V (7309-020(K9N6SGM-V))...
Problem with sound card AMD870 . I have configured 5.1 sound system and it works but suddenly it dissapears ... I mean disapears only center/ subs and rear speakers while front is still working....
click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
don
Feb 24, 2011 | Asrock ASUS M4A87TD EVO AM3 AMD 870 SATA...
Before booting 3 long beeps 10 sec silent then 3 long beeps and so on
This is an issue that one of the devices is not properly seated on the board or it is not detecting them correctly.
To fix:
1. Remove all devices from the board. All cables coming from Hard drive/CD-rom. Remove the RAM and processor. LEAVE TH E POWER SUPPLY CABLES CONNECTED TO THE BOARD.
2. Re-seat the processor on the board.
3. Re seat the memory on the board.
4. Now re-seat the video card making sure that you push it firmly in place. Connect a monitor to the video output.
Try and boot the computer. If it boots and you see output on the screen then the issue is fixed.
If if does not boot you have a problem with one of the following: RAM, Processor, Video Card, or motherboard.
Oct 30, 2010 | Asrock K7VT4A-Pro Motherboard
How do i change dvd rom unit?
  1. Locate where your CD or DVD ROM drive connects to the motherboard and make a note of this. Make sure you know exactly how the gray cable was connected.
  2. Have the new DVD ROM drive handy and unplug and/or slide out (depending on setup) the old one. Unplug the cables from the appropriate places. You do not have to unplug the one going to the DVD ROM. Wiggle back and forth gently and then pull out.
  3. Attach your new cables and reattach to motherboard and power supply where you removed the old ones.
  4. Reattach the power cord and cables, but do not close up the computer entirely yet.
  5. Test your new DVD player by placing a disc in the drive and ensuring the green light comes on and you hear it power on. If this happens without a problem, then close up the case. If not, then check to make sure cables are securely fastened in the correct motherboard slots and to the power supply
May 18, 2010 | Computers & Internet
Sound is coming when we play songs
make sure the connections are right and no loose connections,, and pc is earthed
Sep 29, 2009 | Creative Labs Sound Blaster Live! 5.1...
How can i make the audio out work on the Plextor px-708uf?
dependant on your Sound Card.
do you have the cable connected From The DVD Drive ( spdif digital ) Or analogue audio Cable ? this is a thin cable usually grey/white cable coloured red/black/ground or earth.
This connects from The DVD to the motherboard ( CD ) Or to your Sound Card ( CD Or IN ) If you don,t have this Cable connected you won,t get Sound from DVD To Sound card or on-board Sound from The motherboard. Also check your sound-cards drivers Are Installed correctly. Finally open the sound manager In My Computer, And check that a device is selected, Or Isn,t Muted.
This should Solve Your problem.
Mike @ compurepair.
Aug 19, 2009 | Plextor PX-750A DVD-RAM Burner
HP Pavilion a1220n (A1220NED904AA) PC Desktop Logo
51 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
