Question about Dell TrueMobile 2300 Router (000001)
Dell Truemobile 2300 - cannot connect to internet
I recently moved from a home with cable internet through Time Warner.
Everything worked properly before the move. Now, I am trying to set up my Dell Truemobile 2300 router for my home using the Dell router and Dell Inspiron 8600 running Windows XP (yes, ancient). I am able to connect to the internet using DSL (by Embarq) without the router. When I add in the router, I cannot get online. Everything looks like it's working properly and using the installation CD has not helped. Sometimes, I can get to the my.router page to choose settings, but I cannot get the internet connect to work (wired or wireless) with the router hooked up.
  • Anonymous Jan 27, 2009
    I have the same problem. It used to work with my old linksys before I had to reinstall the OS with everything else. I am now using a new modem and it worked fine when connected directly but when I try to connect the router to the modem and connect to the internet, doesn't work anymore.
  • 73 Answers
This is usually a router configuration issue. The router has to be configured to match your new broadband settings.
For example, your old DSL may have required some kind of login which was entered into the router. For most broadband cable connections, you set the router to get an IP address automatically.
Re-run the router Setup Wizard. You can download it here:
http://ftp.us.dell.com/network/R74885.EXE
Posted on Feb 06, 2009
I entered a WEP encryption key onto my Dell TrueMobile 2300 router, but when I try to connect to it wirelessly (and put in the correct key), I don't get any connection to the internet. It works fine when...
Dear Friend,
You must be trying the WEP -OPEN.
try WPA-PSK and put in your customized password.
Before making any changes in the system remove all the cables from the router and reset the router once and try to configure the network with WPA- PSK.
It should work.
If negative plz contact your ISP
Thank You
Prasanth83
May 11, 2010 | Dell TrueMobile 2300 Wireless Broadband...
Dell Truemobile 2300: Staying Connected Trouble
well try moving ur router away from (phone, microwave, etc...) u can also upgrade the firmware of the router and then reconfigure it ... if it still the same then may be u would have to get a new one.
Best of luck
Jan 10, 2010 | Dell TrueMobile 2300 Wireless Router...
Dell TrueMobile 2300 Router wont connect to My cable modem
You are most likely making a mistake in the setup instructions.
Jun 20, 2017 | Computers & Internet
Router Won't connect to internet
The cable modem sometimes register the hardware MAC address of the connected device. So your PC may be registered and it won't accept the router now. Connect the WAN port of the router to your cable modem and power the modem off and on again. It should re-register the connected device and now your router should work.
Jul 30, 2009 | Dell TrueMobile 2300 Router (000001)
Router not speaking to modem
you need to change dhcp from the modem to the router to be a different network than what your router hands out via dhcp. you will also need to set dns up in the router to forward to the upstream modem.
Jun 03, 2009 | Dell TrueMobile 2300 Wireless Broadband...
All the lights are on, but no internet
Hi there you can try this locate your router in your internet connections and rightclick on it and look for repair and click on it now the comoputer will try to renew the ipconfiguration and address and hopefully this will get you going again once it is done you should be able to go to the router and click status and see if it says aquiring network address and wait to see if it does ok please let me know how this goes for you
regards mike
Jan 24, 2009 | Dell TrueMobile 2300 Wireless Broadband...
2300 router not sending signal or allowing flow to computer
First unplug router, turn off computer. Then plug ethernet into router then power up. Allow time for router to recognise internet connection and boot up completely. Then plug second ethernet into computer then power up computer. Allow enough time for the router to recognise computer and the computer to recognise router. You should be able to access internet within a few minutes. If not you might want to verify that the router is not outdated and fully functioning.
Oct 13, 2008 | Dell TrueMobile 2300 Wireless Router...
Before you throw it, save all the settings in router and try a re-start or there is normally a re-set button somewhere to press and set it back to factory settings. If the wireless re starts re-load previous settings. Please rate solution.
Nov 15, 2006 | Dell TrueMobile 2300 Wireless Broadband...
Dell TrueMobile 2300 Router (000001) Logo
633 people viewed this question
Alun Cox
