Question about Whirlpool RBS305PD Electric Single Oven
RBS305 replaced thermal cutoff twice and again it won't come on bake or broil
Model #RBS305 single oven. Used the self cleaning feature and afterwards it would not come on bake or broil. So I had an eletricial fix it with the thermal cutoff. Then the oven worked. I again used the self cleaning feature and afterwards the bake or broil would not work. I had it repaired againj. Then again used the self cleaning feature and again it is not working on bake or broil. What is causing this to continously happen. does something else need to be replaced? thanks
    Dedicated:
    Visited the website for 20 consecutive days.
  • Whirlpool Expert
  • 84 Answers
Good Evening!
The self clean feature is causing your thermal fuses to fail or open. This is a safety mechanism that when open (bad) won't allow electricity to pass through any longer. The temperature in your oven exceeds what the components in your appliance can handle. If you want your oven to last it's longest, I would discontinue using that feature. If ever the control board or keypad on your oven by way of the self clean feature, we can help you with that. Fixyourboard.com can help. Send all inquiries to info@fixyourboard.com . Thank you!
Posted on Jun 06, 2017
2 Suggested Answers
SOURCE: used the auto clean feature on my oven. now the
sorry idk
Posted on Nov 21, 2009
Used the self cleaning electric oven and now can not use the oven the digtal shows door when bake or broil is pressed
what is your model number is then we can get started to fix your problem right away
Jan 22, 2013 | Ovens
The LOC on messsage appears on the screen when we go toturn the oven on. NEED the OVEN. What could we do to fi it?
The control lock has been activated. This feature is useful when you are cleaning the panel so that you don't accidently start the oven or the self-cleaning cycle. Try pressing Bake and Broil Hi/Lo together for 2 seconds (or a bit longer). SF should appear in the display. Then press Self Clean and Start. (When you press Self Clean the LOC message should disappear.)
Manuals for most GE appliances are available here: http://www.geappliances.com/service_and_support/literature/ . Enter the model number and click Submit. The direct link to the manual for the JTP18WWWW is: http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=981140017.PDF .
I hope this helps.
Jun 02, 2011 | GE Profile JTP18 Electric Single Oven
My heating elements are not heating for bake, broil or clean. just finished a round of self cleaning and now oven doesn't heat.
The self clean or self destruct mode has burnt a wire, the relay, or the control...
A tech with an electrical meter will need to check through the wiring and see what burnt up...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Dec 13, 2010 | Whirlpool RBS275PD Electric Single Oven
My oven wont heat up?
Hello there:
first chevck to see if the broil feature will work but if both the broil and bake feature does not work meaning it will not heat up if you have selected either the bake or broil follow these solutions that i have provided for you .
It won't bake or broil If neither the bake nor the broiler heating elements heat, but the range burners still work, the clock may be set for a timed or self-cleaning cycle. Check to be sure the clock buttons and knobs are set properly. If your clock has a knob that says "push for man(ual)", push the knob in and try the baking and broiling elements again. If it still does not operate properly, you probably have a defect in the thermostat, selector switch, or common wiring. If the oven does not have a separate bake/broil/etc. selector switch, the problem may be with the thermostat. But it's not easy to check the selector switch or thermostat for proper operation. If you suspect a problem in this area, call a qualified appliance repair technician.
Jul 13, 2010 | Hotpoint SY36 Style Line Stainless Steel...
My oven broiler does not seem to be working-I turned it on broil for about 15 minutes - no heat, nothing. On normal bake, it takes about a half hour to heat the oven to 350 degrees - my old stove took...
check the bake (lower) element, mine just went out. It was easy to spot the problem once I pulled the element out, the wire had burnt off the end. Please remember to turn the power off first.
Nov 28, 2009 | Whirlpool RBS275PD Electric Single Oven
Oven will not heat after self cleaning
We used the self cleaning feature on our RBS305 Built In Electric oven and afterwards it would not heat. replaced the Fuse-Thermal part Nr 9759243 (which is the new part number. (Shown as Nr 37 on the Parts list for the oven parts). Cut all Power to the oven off and it was very easy to pull oven out with help of my wife. Removed back, bought a new part for 49.55 plus tax. Put in new part, replaced back and oven works like new. I am a 73 year old senior so when I say it is fairly easy to replace you know it is. Hope this helps someone
Dec 11, 2008 | Whirlpool RBS305PD Electric Single Oven
Self-clean not cleaning
I was wrong (I think).  the baking element probably was burnt out as the repairman said.  He replaced it and I thought selfclean still wasn't working.  In fact, I think I just had to give the self-clean function more time.  Also, I was judging by smell.  We have become used to a bad odor during self clean which was missing when it was broken and still missing after the repair.  Bottom line, the oven was clean after the baking element was replaced, sans smell.
Apr 19, 2008 | GE Profile JTP18 Electric Single Oven
Whirlpool RBS305PD Electric Single Oven Logo
49 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
