Question about RTO Bodyguard T300 Commercial Treadmill
Bodyguard t300 treadmill. belt will not turn
Treadmill come on. belt will not move. all I did is move it from 1 room to another. check connection, seem fine. error 12 speed sensor problems. any ideals.
  • 4 more comments
  • Kevin Butler SR. Jan 26, 2009
    yes,belt move seem like no power to the motor and incline motor.
  • Kevin Butler SR. Jan 27, 2009
    problem resolved. Smashed harness, created short
  • blueextc3221
    blueextc3221 May 11, 2010
    You may need to open it up. Locate the motor and be sure the connector has not been jarred loose. While its open , and you have a multimeter, ensure there is voltage at the motor power lead.
    If there is power, the motor has failed. If there is no power, you may have damaged the mainboard
  • blueextc3221
    if you get on, can you manually move it with your feet?
  • Anonymous Mar 22, 2014
    belt moves slow will not get to the required speed
  • Anonymous Mar 24, 2014
    treadmill powers on but low speed comes on display and motor does not run the belt.
Smashed harness created short.
Posted on Jan 27, 2009
Treadmill belt doesn't run smoothly
First of all lubricate the treadmill. If it didn't workout then try to tension the walking belt.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Dec 27, 2015 | Bodyguard T240 Treadmill
The belt has shifted to the left, how do I move it back over? And it sounds louder than normal.
Check the rear endcaps for damage. If they are OK, find the allen key that came with the treadmill (you used it to assemble the machine) and go to the back of the machine. If the belt is rubbing, find the left adjustment bolt and turn the screw 1/2 turn clockwise. Now, by hand move the belt a couple revolutions. If it still rubs, repeat the procedure till the belt stops rubbing. Now run the treadmill about 3MPH and fine adjust the belt by turning the screw 1/4 turn until straight.
If the belt is not rubbing, run the machine (3MPH) and adjust the left bolt clockwise 1/8 - 1/4 turn watching closely till the belt is centered.
Feb 27, 2011 | Epic View 550 Treadmill
Where can i get a replacement safety clip/magnet for a bodyguard T300 treadmill
Call them directly @ 1-800-373-2639 and ask for service department. This is a French Canadian company all prompts will be in French first then English. Very professional and knowlegable people
Sep 28, 2010 | RTO Bodyguard T300 Commercial Treadmill
My bodyguard t240 says i need to calibrate it. its a slightly older modle and i cant seem to find the maual
Turn the on/off switch to off.
Hold down the "speed increase" and "speed decrease" buttons while turning on the switch at the same time. You will be in the "diagnostics" menu. Scroll to the "elevation calibration" option.
I know, it is an older post.
Aug 10, 2010 | NRS Bodyguard® T240 Treadmill
Bodyguard T240 wont start
To use these instructions, you need to have a familiarity with electricity and a working knowledge of a voltage multimeter. With all of these tests, USE EXTREME CAUTION!!! Never let the voltage ground directly to any part of the treadmill or your leads ground while you are testing voltage.
1) To begin, set your volt meter to AC volts. We are going to trace the power from the wall outlet through the treadmill to see where it ends.
2) With the treadmill unplugged, test the wall outlet. You should have from 115 to 125 VAC. Optimally, you will have at least 120 VAC.
3) Follow the power leads from the power cord to the lead ends. With the treadmill unplugged, connect your meter to the lead ends. Plug the treadmill in and check your reading. It should be the same as your reading from the wall outlet.
4) Continue this process with the electrical system, following the leads, as they pass through, breakers, fuses, and the like.
5) Where the power flow ends is where your problem is. Sometimes it will be in a bad connection, sometimes it will be in a shorted breaker or blown fuse, at times it may be as simple as a safety switch not working properly, or it may be a major problem with a component.
6) In some cases, components work in tandem (i.e.- a controller may need a signal from the console computer to release voltage to the motor.
1) One of the most common problems with power outages is problems with fuses, breakers, wiring, or switches.
2) If your treadmill is equipped with a safety switch, set your volt meter to continuity. Touch your test leads together to make sure you are getting a closed circuit. With the treadmill unplugged, back the leads off the safety switch, usually near the upper display computer. With the safety key out, test the switch. It should be open. Push the safety key in. Your circuit should be closed. If this tests ok, move to the next step.
3) While testing for voltage, you can unplug your treadmill and test the fuses, breakers, and wiring harnesses. Sometimes a breaker may have shorted open and not tripped. Test these components individually. You want a closed circuit on all of them
Jul 10, 2010 | Bodyguard T240 Treadmill
Belt shifting/crooked and frayed on Proform 725 TL
in the back of the manual, it describes the adjustment for this. on the end of the platform (near where your belt is crooked) there is a hex nut. the manual says to turn the machine off before adjusting, i find it is much easier to do while the tread is still moving. turn it about a quarter or half turn one way or the other until the tread is aligned.
May 09, 2009 | RTO Bodyguard T200 Treadmill
Pro-form treadmill belt binds
May need to be tightened
Mar 27, 2009 | RTO Bodyguard T200 Treadmill
Treadbelt not alligned
Hi, Most all treadmills use the same type of belt tracking, which is an allen screw adjustment on the rear tension bar. One on either side. You should have been provided an allen wrench with your treadmill, if not then use one of your own the proper size. Make the adjustment with the unit running at its slowest speed. Clockwise tightens the tension and will draw the belt. Good Luck, this should Fixya!
Mar 04, 2009 | RTO Bodyguard T200 Treadmill
RTO Bodyguard T300 Commercial Treadmill Logo
1,064 people viewed this question
Top RTO Exercise & Fitness Experts
Jim London
Jim London
Jax Planet
Jax Planet
Are you a RTO Exercise and Fitnes Expert? Answer questions, earn points and help others
