Nideka t-8 set time and day - Office Equipment & Supplies
Nideka bundy clock
"manager confirm menu login" what seems to be the problem with this? i dont have any manager password
May 19, 2013 | Office Equipment & Supplies
Face of the timer doesn't indicate which numbers are a.m. and which are p.m., so how am I supposed to set the current time? There's an "8-4-12" that's not shaded and then an "8-4-12"...
You posted under Woods vacation timer:
See large image
This is a 7-day timer.
Days are printed on the dial.
Each day has night time with dark background and daytime in light background
If you want to set time for Monday at 12 noon, rotate dial clockwise until Monday 12 (in light background) line up with arrowhead located on inner dial.
After that, move switch to TIMER
Timer turns lights ON-and-OFF at random times throughout week
Jan 10, 2011 | Woods Indoor 7 Day Mechanical Vacation...
Are the 7 different programs for 7 different days or are they exclusive?
There are 7 ON events and 7 OFF events
http://waterheatertimer.org/pdf/Woods-59028-59018.pdf
When programming the timer, you select individual days or blocks of days.
For example program1 ON time
Set the Hour
Set the minutes
Press the day key to scroll through the possible choices.
Then you set program1 OFF time
Set the hour
Set the minute
And then press the day key to scroll through the possible choices.
The choices are:
Each individual day
Monday thru Friday
Sat-Sun
Monday thru Sat
Monday thru Sun
Monday-WED-FRI
Tues-Thurs-Sat
Mon-Wed
Thurs-Sat
The key is to set the ON and OFF times for the same days or blocks of days
For example program1 ON is 8:00 am Mon thru Friday
Set program1 OFF for 3:00 pm Mon thru Friday
and then program2 ON is 8:30am Sat-Sun
program2 OFF is 5:00pm Sat-Sun
Program 3 ON is 6:00pm Tues-Thurs-Sat
Program3 OFF is 9:00pm Tues-Thurs-Sat
Program4 ON is 6:00pm Sat
Program4 OFF is 11:00pm Sat
Programs5, 6 and 7 might not be needed
The key is to make a chart of times before setting timer.
The chart will prevent conflicts in programming where the timer does not operate as expected.
Nov 08, 2010 | Coleman Cable Woods 59018 InWall 7Day...
I have a Woods 24 hours indoor lighting timer. I have followed the instructions provided with the timer, but lamp won't come on. Can someone please provide EXACT step by step instructions. Thank you
If you have a different model number than the 59377, please re-post with exact model number
If you programmed conflicting on-off schedules, the timer will not perform correctly
Make a schedule of times before starting, and that will keep everything organized, just like a recipe
How to program Woods 59377
Timer has rechargeable battery.
Plug timer into wall to charge battery to see LCD display.
All the Woods manuals
Download Woods 59377 manual
Up to 8 ON/OFF programs per day >> program 1 program 2 ... program 8
Choice of individual days, or blocks of days
Image shows buttons:
Set time of day:
Hold down CLOCK button until settings are made
Use DAY button to choose current day MO - TU etc
HOUR button to set current hour
MIN button to set current minute
Release Clock button and time is set
Program preview
> Have your schedule ready to avoid conflicts in programming
Manual says:
>For each ON time, you set DAY HOUR and MIN
>For each OFF time, you set DAY HOUR MIN
> So Program1 has ON and OFF settings that require DAY HOUR and MINUTE
> Program2, 3 , 4 etc also have ON and OFF settings that require DAY HOUR and MINUTE
>Manual shows blocks of days to choose from > for example TH FR SA is one block; MO WE FR is another block ,,, there are 9 possible blocks of days to choose from ... including individual days.
> Each program requires you to select days for ON time, and then when setting OFF time for that program, make sure you have correct day or block of days.
Looking at the display while programming is critical for programming timer correctly
Look for the number 1 or 2 or 3 etc located on left of display > each program has a number
program 1 is #1, program 2 is #2 etc >>> look for the small number on display
Look for the word ON that indicates you are setting ON time for program 1 or program 2
Look for word OFF that indicates you are setting OFF time for program 1 or program 2
Program timer
Press PROG once and look at screen ... you will see '1' and 'ON' in tiny letters
You are ready to set ON time for program 1
Press DAY to choose block of day for program 1
Press HOUR to choose ON hour for program 1
Press MIN to choose ON minute for program 1
Press PROG button once to validate ON time for program 1
Before pressing any more buttons, look at the screen >>> screen shows '1' and 'OFF' in tiny letters
So you are ready to set OFF times for program 1
Press DAY >>look at your written schedule to make sure the correct block of days is chosen >> if you chose ON for TH FRI SAT, you probably want OFF on same block of days
Press Hour to choose OFF hour for program 1
Press MIN to choose OFF minute for program 1
Press PROG to validate OFF time
Before pressing any button, look at screen and '2' and 'ON' show on screen
You are ready to set ON time for program 2
Press PROG button to advance to program 3 through program 8
Press ON/Off button to exit programming, and timer is ready
Other features
Daylight savings time: Press HOUR & MIN buttons simultaneously and clock springs forward 1 hour ... press again and clock falls back 1 hour
Look for S in display to see if timer set for S summertime
Press reset to clear all programming
Up-vote if this information helped you. Thanks for the feedback
Oct 14, 2010 | Woods Industries 59377 Indoor Digital...
Having Difficulty programing Woods Brand electrical timer !
Download Woods manuals
59377 manual
Set time of day:
Hold down CLOCK until settings are made
Use DAY button to choose MO - TU etc
Program preview
> First I suggest you write out your schedule to avoid conflicts in programming
Manual says:
>Manual shows blocks of days to choose from > for example TH FR SA is one choice; MO WE FR is another choice ,,, 9 possible blocks of days to choose from
Looking at display is critical for programming timer
Program timer
Do not hold down PROG button
Press PROG button once to finalize ON time for program 1
Press DAY >>look at your written schedule to make sure the correct block of days is chosen >> if you chose ON for TH FRI SAT, do you want OFF on same block of days?
Press Hour
Press MIN
Press PROG to confirm OFF time
Press PROG to advance to program 3 through program 8
Other features
Daylight savings time: Press HOUR & MIN simultaneously and clock springs forward 1 hour ... press again and clock falls back 1 hour
Oct 07, 2010 | Woods Industries 59377 Indoor Digital...
How to program a woods TD1000 indoor timer
Here's how to set Woods TD1000 timer
This is older timer with backup battery. Plug in timer to see if battery will work. Display shows when battery is charged. No display, then timer is no good.
TD-1000 timer has 8 on-off functions per 24-hour day ...newer timers each offer 7 day function with choices of each-day, week-day, or week-end programming. The wider choices with newer timers may explain why TD1000 instructions are hard to find
Timer has 5 buttons + reset:
TIME MODE PROG HOUR MIN
Set time
Press and hold TIME > use Hour to set hour, Min to set minute
Release Time button ... correct time should show
Program: Capacity for 8 on-off times per day
Press PROG to set first ON time
ON and number 1 are displayed on left
Use hour and minute button to set ON time
Now, OFF and number 1 are displayed
Use hour and min key to set OFF time
When 8 programs are set, Press MODE key.
Choose Manual OFF. Manual ON, Auto ON, Auto Off
To use programs, select Auto ON
DST daylight savings time has to be done manually.
Press HOUR MIN button simultaneously > timer set up one hour
Repeat again and timer goes back one hour
Do not plug timer into extension cord > must be plugged into wall
Oct 04, 2010 | Woods Indoor 24 Hour Digital Timer (59203)
This is older timer with backup battery. Plug in timer to see if battery will recharge. Display shows when battery is charged. No display, then timer is no good.
TD-1000 timer has 8 on-off functions per 24-hour day ...newer timers offer 7 day function with more programming choices... which may explain why TD1000 instructions are hard to find
Set time
Oct 04, 2010 | Woods INDUSTRIES 59112 INDOOR DIGITAL...
Where can I download instructions for utilitech timer
UTILITECH - Grounded in Quality
Digital 2-Outlet Timer (TE06WHBL)
Instruction Manual & Warranty
Before using your timer please read the following instructions carefully.
FEATURES
- Up to 8 ON/OFF events per day/56 ON/OFF events per week
- Option to program individual days or 8 different weekday groups
- Minimum switching period one minute
- Summertime/wintertime change over
- Easy to read LCD display
- Random automatic ON/OFF security feature
- Countdown feature
- Manual override button
- Rechargeable battery back-up (if there is no LCD display, plug
timer into a wall receptacle, this will recharge the battery)
SETTING TIME
Press and hold CLOCK key, then press DAY key to select correct day,
HOUR key to select correct hour, and MIN key to select minutes. When
MIN key is released, time will be set with seconds starting from 0.
Either holding down or repeatedly pressing appropriate button can
advance days, hours and minutes.
Do not set ON and OFF for same time.
PROGRAMMING EVENTS
The timer has the capacity for 8 ON/OFF events per day.
Save program capacity by using available blocks of days.
Blocks of days are:
1. M,T,W,Th,F,S,Su
2. Individual days of the week
3. M,T,W,Th,F
4. S,Su
5. M,T,W,Th,F,S
6. M,W,F
7. T,Th,S
8. M,T,W
9. Th,F,S
For each ON time and each OFF time--DAY, HOURS and MIN must
be set. Press PROG key onceto set first ON time--"ON" and number
"1" appear to left of LCD display indicating to enter first ON time.
Press DAY button to choose required day or blocks of days, then set
hour and minutes using HOURS and MIN buttons. After setting required
ON time, press PROG button to validate entry and move onto first
OFF time--"OFF" and number "1" appear to left of LCD display
indicating to enter first OFF time by using DAY, HOURS and MIN
buttons as above. Press PROG button to validate this entry. Repeat
remaining 7 ON/OFF settings as required. After setting required
ON/OFF settings, press CLOCK button to return display to clock. Timer
is now ready to operate. Check programmed settings by pressing
PROG button repeatedly--each setting will appear on screen.
MANUAL OVERRIDE
To choose permanent Manual ON, permanent Manual OFF,
Auto ON or Auto OFF, press Manual button. Each mode will be
displayed on screen. When choosing Auto ON, timer turns ON until
next programmed OFF time. The programmed settings will only work
on Auto mode. When Auto mode OFF is chosen, timer is OFF until
next programmed activity. (Inverted black triangle on LCD points
to either AUTO or MANUAL indicating which is selected)
COUNT DOWN FEATURE
To enter count down feature, press CLOCK and PROG buttons
simultaneously. Using HOURS and MIN buttons, set count down time.
(Maximum selection is 9 hours 59 minutes, minimum is 1 minute.)
Press MANUAL button to start countdown. Output will turn ON until
end of count down. Count down may be paused at any time during
period by pressing MANUAL button. To re-start, press MANUAL button
again. To review time during count down period, press and hold
CLOCK button. Release CLOCK button to return to count down display.
Note: To return to timer mode, press CLOCK and PROG buttons
simultaneously.
RANDOM AUTOMATIC ON/OFF SECURITY FEATURE
With this option selected, timer will switch ON and OFF in a random
pattern at least once in every 8 hours. (This may mean timer will
switch OFF within a set ON period, or vice versa.) Ideal for use with
a light--switching it ON and OFF automatically gives appearance of an
occupied home, but not at exactly the same time every day. To enter
Random mode, press DAY and HOURS buttons simultaneously.
An "R" will appear on display and unit will start random switching.
If no programmed times are set, timer will switch ON or OFF
approximately 1 minute after entering Random mode, then continue
randomly. To turn Random mode OFF, press DAY and HOURS buttons
together again.
SWITCH OVER SUMMERTIME/WINTERTIME ZONE CHANGE
To change from wintertime to summertime, press HOURS and MIN
buttons simultaneously. Clock will be set forward one hour and
"S" will appear on display. Repeat same procedure to return to
wintertime.
Note: if unit is purchased during summer, set clock time for one hour
less than correct time, select Auto mode and press HOUR and MIN
keys simultaneously. The unit will then adjust to correct summertime
and "S" will appear on LCD.
RESET
To reset unit for time and programmed ON/OFF settings,
press RESET button.
IMPORTANT SAFETY PRECAUTIONS and
RATINGS
[Contact the manufacturer; I've already wasted too much time typing
this in:
AmerTac
Saddle River Executive Centre,
One Route 17 South, Saddle River, NJ 07458
800-777-0802
www.amertac.com
Made in China
May 05, 2010 | Kitchen Appliances - Others
Model 25942EJ3-C
Try this:
1.) Make sure the answering system is on.
2.) Press flash/answerer/call waiting button on the handset to enter answerer remote mode.
3.) Press key (8) to enter Time/Day set menu using the handset.
4.) To set the Hour, key in (00)-(12), like 08 for 8 o'clock.
5.) To set Minutes, key in (00)-(59), like 15 for 15 minutes after the hour.
6.) To set AM/PM, press the CALLER ID-VOLUME up or down buttons.
7.) To set the day of the week, press the CALLER ID-VOLUME up or down buttons.
8.) Press #PAUSE/ringer button to confirm the setting.
Hope this helps you out! Hal
Apr 16, 2009 | GE 26938GE1 Cordless Phone
How to set date and time
Voice Time/Day Stamp
1. Make sure the answering system is ON.
2. Press flash/answerer/call waiting button on the handset to enter answerer remote mode.
3. Press key [8] to enter Time/Day set menu on handset.
4. To set Hour, key in [00]-[12].
5. To set Minutes, key in [00]-[59].
6. To set AM/PM, press the CALLER ID-VOLUME (5or6) button.
7. Press #PAUSE/ringer button to confirm the setting.
8. Press Caller ID-Volume to set Day
9. Press #Pause to Confirm
10. Phone will then Announce the Day & Time
Feb 02, 2009 | GE 25932 Cordless Phone
27 people viewed this question
jasbo
jasbo
