Question about Refrigerators
My samsung srs631np fridge keeps freezing and not cooling ?
Maanita
  • 1142 Answers
SOURCE: refrigerator not cooling
see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
Posted on Aug 07, 2008
tborn6
  • 700 Answers
SOURCE: the fridge wont cool down
check to see if the freezewr evaportor is frozen up. you have to take the panel off inside of the freezer to see that all of the ice is gone,. but be carefull becaquse theres stryofoam inside that acts like a air duct to channel thee air across the coil the right way.
Posted on Mar 27, 2009
  • 10865 Answers
SOURCE: frige light on not cooling,freezer fan working but not freezing
Hello there. Let me see if I can assist you.
A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
Posted on May 27, 2009
  • 1891 Answers
SOURCE: my fridge keeps cooling and
this may be a bad air damper but it could also be a cold control / to help more i need the brand and the model # located inside the frig .. ( do not use the book one .) most units with this problem have bad control ... mm peed back pls / hopw this helps ..
Posted on Feb 26, 2011
heatman101
  • 43501 Answers
SOURCE: my samsung fridge freezer wont
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Sep 09, 2011
My refrigerator keeps freezing things...,.changed the gaskets around door and still have the freezing probkem
Most fridges have a cooling vent above or on the side of the top shelf. This is where most of the cold air comes from, so keeping food away from here may preventfreezing. ... Some side-by-side refrigerators (particularly older models) feature a vent that funnels cold air from the freezer into the fridge.4 Aug 2015
How to Prevent Your Refrigerator From Accidentally Freezing Food ...
refrigerators.reviewed.com/features/how-to-prevent-accidental-food-freezing-in-fridge...or try this link... refrigerator keeps freezing things Google Search
Oct 23, 2017 | Refrigerators
Hi i am having samsung fridge cooltsech plus silver nano i have a prob;em in my fridge that in winter the cooling in the refrigerator is very sytrong i have increased the temperatire to 7 degress which is...
If your veg is freezing you need to RAISE the temp in the fridge,if #7 is coldest,then #1 is warmest.SET IT TO #3.You should keep a fridge at +5C for best storage of CHILLED food.you should also adjust your fridge for summer and winter ambient temperatures.a fridge/FREEZER thermometer is ESSENTIAL.OTHERWISE YOUR WASTING MONEY/ENERGY.
Nov 12, 2010 | Samsung CoolTech Plus / Basic Bottom Mount...
NO WATER COMING OUT OF WATER DISPENSER ON MY SAMSUNG RS21DCNS/XEU
you either have a kinked water line, or a frozen one. There is a possibility that the solenoid isn't working.
Nov 08, 2009 | Samsung Refrigerators
I AM HAVING A PROBLEM WITH MY SAMSUNG FRIDGE FREEZER THE TEMP INDICATOR KEEPS FLASHING AND ITS NOT FREEZING?
Oct 22, 2009 | Samsung Refrigerators
Fridge side not cool and freezer side cooling like a fridge
Most likely a defrost problem. Are you sure your model is the model posted above your post? RS2630SH If not please let me know the correct model number. I have most of the manuals on the Samsung..............Sea Breeze
Jun 20, 2009 | Samsung RS2630SH Side by Side Refrigerator
Freezing eggs in fridge area and freezing produce in crisper
HI,
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Mar 29, 2009 | Samsung RB1955VQ Bottom Freezer...
Power Cool button works on freezer , but not fridge
He Alisonki! I was having the same problem. On mine the water coil inside the refrigerator keeps freezing which keeps the water from circulating and my refridge won't stay cold. I was told by one repairman that it was a computer problem and you have to order parts from the Samsung Manufactuer which takes about 2 - 3 weeks to get. I am tossing mine and buying a more reliable brand. One repairman came yesterday and left without fixing anything or charging me. Larry
Aug 09, 2007 | Samsung RS2534 Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
