Question about TruTech PLV16320 Television
Trutech sd tv 20". trying to program channels and screen is black and says " now scanning" and it will not stop
    President:
  • 814 Answers
Check your owners manual for instructions on how set-up your television for channel selection. This should tell you how to use you television with the antenna only, and how to use it with a cable set-up. If you are still having a problem, check the troubleshooting section and see if they have any solutions there. If all this does not work for you , then contact customer service for the television and cable companies for technical assistance with your problem. I hope this helps you with your problem.
Posted on May 17, 2009
Help. I got a used TruTech t200d for my nine year old. we were able to hook up and play on playstation 2, but are unable to get the tv to pick up the comcast channels. we do not have the trutech remote...
U able to go into the tv Menu?Yes,goto SETUP changes Pick CABLE and scan for channels for the Comcast CABLE channels.Or Try website like Remotes.com to buy an original tv remote.
Mar 04, 2011 | TruTech T2000D TV
17 in. trutech tv unable to get channels except 2-13
For channel setup you will need to;
1) Connect the signal source to the back of the set.(Antenna or Cable)
2) Go into the TV Menu and select the same signal source you connected to the back.(Antenna or Cable)
3) Go to the auto program/scan menu and run it. This may take a few minutes.
Now the channels may be watched.
Mar 16, 2009 | TruTech PVS31170S1W 17 in. LCD Television
Audio, but no picture.
Any luck getting this fixed?Please let me know.Thank You very much!
Tyler
Feb 09, 2009 | TruTech PLV16260 Television
Emerson 20 inch flat screen tv problem
i had the same problem with a 32 inch and i kept "clicking" the channel changer on the remote to force the tv to go to another channel (that had previously been selected during the initial auto scan) --- still trying to figure out why the tv locks onto the scanning for channel
Mar 26, 2008 | Televison & Video
Trutech dvd-r
Set it for antenna and use the single channel it sends to your TV, which is the only signal coming out of your cable box
Feb 18, 2008 | TruTech T650-DR DVD Recorder
Trutech TV
I bought a Trutech 20 inch Flat Screen TV about a week ago. All of a sudden the picture has reduced to about 15 inches, on some channels. Also the picture breaks up a little every time I run a DVD.
Feb 03, 2008 | Televison & Video
TruTech 20" Flat Panel CRT Television
Is there anyway you can lockout channel 5 or delete it and then scan again? If this do not work after it programs the 3 chan. then see if you can manually add the other and then try to surf throu with remote.
Aug 22, 2007 | TruTech PLV16320 Television
Trutech 35" LCD connecting to cable box
The official website for this item is http://1800customersupport.com/trutech. Try emailing them, or call them at 1-888-252-6252. Trutech is the store brand for Target stores. So many companies make their products. This website isn't the official site for all Trutech products,just some of them, like this 15" LCD TV.
Aug 15, 2007 | TruTech PLV1615T 15 in. LCD Television
Cannot set Cable Default Channel
I believe you are getting mixed up between channels and programs. Normally program 00 is used for VHS as it has slightly different parameters for colour and brightness. If the TV has about 39 or more programs which can be programmed in from the on screen menu, try using program 20 for the video and 30 for the cable. For this to work you must do the on screen frequency scanning from channels 22 to 69 (UK) and select VCR, CATV, VHF, UHF, etc. I have used program 00 and 20 for two VHS recorders, working on channel 33 and 35 for example, but you must tune them to 33 and 35 on the `Tune' screwdriver hole by the aerial input sockets of the recorders. I expect if your cable unit plugs into your aerial socket of the TV that it has an adjustment for what channel it is on. The TV on screen menu may be different in some countries, so it would help if I knew where you are.
Oct 21, 2006 | RCA F32632SB 32" TV
TruTech PLV16320 Television Logo
77 people viewed this question
Top TruTech Televison & Video Experts
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
