Question about Oster Kitchen Appliances - Others
Oster kettle flashing power button
Why is the power button flashing?
Will not heat water
Ultimately, how I ended up fixing my Oster 5965 and Hamilton Beach Cool Touch Electric 40898 kettles that had the same problems as you (Nothing would work; no heat, no buttons would light up) was by taking apart the bottom screws (Be warned, for only one screw I needed a "Spanner Insert Bit"). I jiggled the connectors as I rang them out with my multimeter and everything seemed to work. Leaving the bottom off I retested the kettle and it just worked. I reassembled the parts and made my happy wife a cup of English Tea. Just one thing though. There's no Numerals that ever lit up on my kettle so not sure what you meant by that, sorry.
Jan 24, 2014 | Oster 5965 Electric Kettle
How do i replace thermal fuse on an oster 5965 tea kettle?
This unit is discontinued and I doubt it would be cheaper than buying new and that's IF you can find it, sorry.
You might get by with a $10 "Digital Power Timer", though. That will shut your kettle off after whatever amount of minutes and seconds you program it for.
Dec 02, 2013 | Oster 5965 Electric Kettle
Oster kettle not working
Oct 18, 2012 | Oster 5965 Electric Kettle
Oster water kettle leaking from bottom of unit when pouring?
If you're not just simply missing the opening a little as you're pouring then I'd assume it's cheaper to replace than to repair, sorry.
If it's leaking from the side-glass you might get by with filling your kettle just under the lower end of the side-glass.
May 29, 2012 | Oster 5965 Electric Kettle
The warming button is stuck in the "on" position.
Push down on it toggles it on and off. Push down on it and it will release back up. Hope this helped...
Jan 11, 2011 | Oster 5965 Electric Kettle
It won't turn on when I push down the switch. It worked perfectly minutes before.
Sep 28, 2010 | Oster 5965 Electric Kettle
A black ant got stuck under see through window WATER gauge on the body of kettle how to get it out? 1.5 L OSTER ELECTRIC KETTLE.
Fill Up Your unit full of Water and Emty it . Do it few time and Garanty your Ant will Go for Ride..Then Invite her for Coffee ...Bye
Sep 23, 2010 | Oster 5965 Electric Kettle
Kitchen Appliances - Others Logo
42 people viewed this question
Top Oster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Ben Eng
Level 1 Expert
Are you an Oster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
