Question about LG WM-2077C Front Load Washer
DE code When I turn on my washer it give a DE code anlock the door but does not start wash. Please Help a repair special can and replace the board but it still does not work???
DOOR INTERLOCK IS FAULTY
Posted on Jul 17, 2007
What does the code de stands for
On front-load washers, it can stand for "door error", meaning the main control board thinks the door is open. If the door is actually closed and the de error won't clear, the electric door lock could be shorted, giving a false signal to the main control board. On the Samsung top-loader, it means a "child lock error" has happened. On that washer, you will see "CL" or "DE", the washer will auto-drain and an alarm will sound. To clear the error, close the door, turn off the power, then turn it back on.
Aug 21, 2015 | Washing Machines
DE error code on LG washing machine
Beyond that could just be the door latch itself.
Nov 23, 2013 | LG WM-2277HW Front Load Washer
LG WM1814CW Front load Washer dE error? I get the dE error everytime I push the start button. The door wont open or close. I can hear the latch moving inside but nothing will happen. The "Door...
A dE error code indicates that the washer door was unable to lock. This can normally be resolved by performing a simple reset on the washing machine.
How to reset the washing machine:
1.
Press POWER to turn the washer off.
2.
Unplug the washer from the power outlet or turn the circuit breaker to the unit off.
3.
With the power disabled, press and hold the START/PAUSE button for 5 seconds.
4.
Plug the washer back in, or turn the circuit breaker back on.
5.
For more information about how to reset your specific model, please refer to the owner's manual.
Press in on the door firmly and select any cycle. The washer door should lock, and the cycle should begin without an error code appearing on the display. If the cycle does not begin and the dE code appears again, repair service is required.
Feb 03, 2018 | LG WM1814CW
We get a de code
A "DE" is a drain error, but a "dE" is a door error. If it was in storage, I'd look for damaged wire(s) to the door lock switch caused by a mouse. It is less likely that the door latch itself needs replacing.
Apr 12, 2009 | LG WM-1832C Front Load Washer
Wont start has error DE
Error displayed table_1.gif Solution
n_de.gif table_2.gif i_1.gif Close the door.
n_4e.gif table_2.gif i_1.gif Make sure the source water faucet is turned on.
i_1.gif Check the water pressure.
n_5e.gif table_2.gif i_1.gif Clean the debris filter.
i_1.gif Make sure the drainage hose is installed correctly.
n_ue.gif table_2.gif i_1.gif Laundry load is unbalanced; loosen any tangled laundry. If only one item of clothing needs
washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an "UE"
error message will be shown in the display window.
n_3e.gif table_2.gif i_1.gif Call after-sa
Dec 07, 2008 | Washing Machines
LG Tromm washer constant DE door error problem
A DE Error Code is indicative of a “Door Error”. This indicates that the washing machine door is not shutting, locking or opening. This means that there is something faulty with the door switch and locking mechanism . You should get this replaced or you may have water where you do not want it. biigg53566
Dec 03, 2008 | LG WM-2277HW Front Load Washer
De is displayed when i turn machine on
You may have a door latch problem and it will need to be replaced.
Mar 12, 2008 | LG WM-1480FHD Front Load Washer
DE error code
That is a door switch error problem.  The door latch is not sensing the door closed.  You may need to replace the door latch assembly.
Oct 23, 2007 | LG WM-2032H Front Load Washer
LG WM-2077C Front Load Washer Logo
252 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Charles T Nevin
Charles T Nevin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
