Question about Freezers
Magic chef chest freezer chirping noise
Magic chef mccf7w chest freezer making chirping noise and will not cool.
  • 19 Answers
SOURCE: freezer stopped working
make sure you are using the right freon for the right oil.eg...new gasses can not pump old mineral oil therfore you sould make sure you are using a poly-ester oil,otherwise get hold of some old cfc gas..goodluck.
Posted on Nov 06, 2007
hotuna
  • 288 Answers
SOURCE: Kenmore 23.1 cf Chest Freezer not cooling below 14F
Make sure everything is working, I.E. compressor, fans. Now I need to know if the freezer shuts off at 14 degrees, or does it continue to run without making temp. If it shuts off, then the first place to look is the thermostat. It may be out of calibration. If it continues to run, then the solution may be as simple as cleaning the condenser coil. or the defrost has malfunctioned somehow. Defrost probleams will cause excess ice on the inside coil. You may need to remove the panels to see how much ice is on it. It sounds like the compressor is good, as it is pretty cold. Just not cold enough. A deep freeze should be at least 0.
Posted on Feb 19, 2008
  • 31 Answers
SOURCE: freezer compressor running, but no cooling
If the compressor is running and there's no cooling, chances are you have a sealed system leak somewhere. Meaning the machine has lost it's refrigerant charge. Pretty much need a set of gages at this point and start checking for potential leaks.
Posted on Mar 14, 2009
SOURCE: Haier freezer chest not cooling. Green light is
Do not put a towel on your freezer or anything that could prevent a good seal from top of freezer.
jim
Posted on May 01, 2009
  • 1218 Answers
SOURCE: Chest Freezer MCCF7WBX.Magic Chef.. Worked fine
Good day,
Could be a tstat, but the machine should be running extremely cold.
Confused as to the age. You said it was 1 1/2 years old. If that is the case. the compressor,and all connecting tubing are under a 5 year factory warrant.
You could replace the tstat, and if within a few days the problem isn't solved, then the rest of the serious problems are covered by factory warranty.
Call your selling dealer for factory warranty service.
Posted on Feb 20, 2010
Magic Chef HMCF7WI is the green light suppose to go off ?
I not 100% sure but believe this is the power light so it should remain on when the freezer calls for cooling and go off when satisfied. If the chest wont stay cold then it sounds like the stat is gone. If it is digital, there may be a power card issue but most chest freezers are run on a standard thermostat with the capillary running up into the base of the unit.
May 17, 2014 | Magic Chef 7 cu. ft. / 198 liter Chest...
Magic Chef #HMCF7W1 should the green light go off?
same as last post... I not 100% sure but believe this is the power light so it should remain on when the freezer calls for cooling and go off when satisfied. If the chest wont stay cold then it sounds like the stat is gone. If it is digital, there may be a power card issue but most chest freezers are run on a standard thermostat with the capillary running up into the base of the unit.
Sounds like water running
According to the manual for that model, this is normal. It says "bubbling or gurgling noises" which indicate that the refrigerant is moving about the lines to cool the unit.
Oct 23, 2013 | Magic Chef Chest Freezer MCCF5WBX
Buzzing noise ft
Warning buzzer. Unplug and try resetting system
Oct 05, 2013 | Magic Chef Chest Freezer MCCF5WBX
Fast freeze light on all the time is this right new belling 100 ltr chest freezer
No check your settings. You may try to unplug it for about a minute and then restart. If that doesn't work, call the mfr. they should help since it is new.
Feb 02, 2013 | Magic Chef Chest Freezer MCCF5WBX
Magic Chief Freezer MCCF7W power light is flickering, but no problems with temperature
Most likely loose connections at the light. Try removing and checking. Usually can pry loose with a flatblade screwdriver.
Oct 15, 2011 | Avanti 5.3 cu. ft. / 150 liter Chest...
WHAT IS THE PRICE OF THIS MCCFFW CHEST FREEZER
spacer.gif 5.5 Cu. Ft. Chest Freezer bbd4a981-a436-4ad6-b98a-7249ef5d1d1a_300.jpg Click to Enlarge Lowest price:$179.00Description:
Food storage will be a snap with this roomy 5.5 cu. ft. chest freezer, featuring up-front temperature control, storage basket and defrost water drain.
Brand: Magic Chef
Category:
Appliances > Refrigerators & Freezers > Freezers > Chest
UPC: 665679002023
Model Number: MCCF5WBX
Dec 16, 2010 | Magic Chef Chest Freezer MCCF5WBX
MCCF7W Runs, but won't freeze....
Sounds like the refrigeratnt has leaked out. It is not worth repairing. The only other possibility is the cold control but I would not buy one until a servicer has looked at it.
Sep 05, 2009 | Magic Chef Chest Freezer MCCF5WBX
Freezers Logo
44 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
