Question about MSI Computers & Internet
Power button connector pins on msi 7309 - MSI Computers & Internet
SOURCE: Problem with motherboard MSI P35 Neo2-FR
I just bought a msi p7n sli platinum. my board is better than yours hahaha, j/k, all playing aside, I have the same problem with the 8pin power connection. A power supply rated v2.2 has the proper 8 pin connection, but 2.1 or lower doesn't, regardless, plugging in two 4 atx pin connectors wont work because you'll be taking 4pins away from the main 24 pin plug (even though my manual says 20 pins will work, it doesnt, they lied!!!). However, when I put the normal configuration of 24 then the 4 in place of the 8, it works fine. The only thing i would worry about is overclocking, thats when you need to be careful with your voltages, etc. Also, I read somewhere that the 8 pin is actually 2 four pins, each 4 pin is for each side of the cpu...
Posted on Aug 13, 2008
Daholk
  • 41 Answers
SOURCE: Sytem panel connectors LEDS
I have .pdf manual of many P5B-V depending on your series. If you want just the main build, go to
https://shop.phirents.ch/downloads/105549.pdf
You should find the pin-out there.
If you need a specific series (ie. P5B-VM) I can e-mail you the specific document.
Posted on Mar 25, 2009
  • 13 Answers
SOURCE: Using ECC ram in MSI MS-7309 board
That is correct as long as the rest of the specs match it will just disable the error checking.
Posted on Jan 22, 2010
  • 80 Answers
SOURCE: I Want to msi 7309
please find all your drivers at the following link:
http://www.msi.com/service/search/#/?kw=K9N6PGM2-V&type=download
Regards,
Posted on Jan 11, 2011
joecoolvette
  • 5660 Answers
SOURCE: msi mobo RS480m2 powers up on 20 pin connector occasionally,but wont power up on 24 pin connector at all. why?
What are the 'extra' 4 wires, Cyprian?
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20plus4
They are 2 Yellow, 1 Red, and 1 Black.
Red = 5 Volt wire
Yellow = 12 Volt wire
Black = Ground wire
You have a bad Power Supply, with a weak voltage power rail.
There are 3;
A) 3.3 Volt power rail, (Orange wires are 3.3 Volt)
B) 5 Volt power rail
C) 12 Volt power rail
http://en.wikipedia.org/wiki/Computer_power_supply#Wiring_diagrams
http://www.playtool.com/pages/psurailhistory/rails.html
1) If ALL of the LED lights were on at once, they would use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts of power.
3) A typical Processor can use 51 to 125 Watts of power. Just depends on what Processor it is.
MicroStar Intenational RS480M2 can use processors that take a LOT of Wattage,
http://www.msi.com/product/mb/RS480M2.html#/?div=Detail
With a weak voltage power rail you do not have enough power, to turn the Processor on, and keep it on.
Picture that.
Do you wish to test the Power Supply?
Or do you have a KNOWN to be good, Compatible power supply; that you can borrow for a test unit?
Post back in a Comment.
Regards,
joecoolvette
Posted on Nov 18, 2012
MSI K9N6SGM-V (7309-020(K9N6SGM-V)) Motherboard Manual
Cut and paste this into your browser. Then follow the prompts to download the manual.
http://www.msi.com/product/mb/K9N6SGM-V---K9N6PGM-FI---K9N6PGM-F.html#/?div=Manual
Jan 02, 2012 | MSI K9N6SGM-V (7309-020(K9N6SGM-V))...
I installed a msi k9n6pgm2-v2 motherboard - and when I plug it into power nothing happens. I have unplugged everything from the board and now only have the power switch connector and the reset connector,...
Have you checked the BIOS jumper? Sometimes it needs to be seeded as per the manual the other thing to check would be to make sure your start button functions, I have had a bad button on a tower before. You should be able to use a small screw driver or paper clip and jumper over the posts for the start button on the Mother board and see if you get anything. This might have already been checked, but are you sure the Power supply is ok? You may already know this as well but just verify your ram is in the "0" slot as well.
Apr 15, 2011 | MSI K9N6SGM-V (7309-020(K9N6SGM-V))...
I have need msi motherboard driver ms 7309 ver 1.3 nvdia and cpu drivers
You can download the drivers from MSI WEB support site,select your model motherboard to download :- http://www.msi.com/index.php?func=downloadindex
Jan 03, 2011 | MSI K9N6SGM-V (7309-020(K9N6SGM-V))...
Motherboard drivers msi ms-7309
Hi, every driver for that motherboard can be downloaded from this: Driver Update Software. Wish you best of luck. Brian
Jan 15, 2010 | MSI K9N6SGM-V (7309-020(K9N6SGM-V))...
I want msi 7309 v-1.0 k9 n6 sgm audio,lan,vga
i want drive for msi 7309 v-1.0 k9 n6 sgm audio,lan,vga
Jun 24, 2009 | MSI K9N6SGM-V (7309-020(K9N6SGM-V))...
Computers & Internet Logo
24 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
