Question about Dell 725 InkJet Printer
Cover open message
Every time I try to print anything, I get a "front cover open" message. I've tried all I can think of. The cover is not open but I keep getting the message. All connections were checked and are fine. Any ideas on anything else I can try?
  • 944 Answers
Here is the link to the user manual if you need it; http://support.dell.com/support/edocs/systems/725/en/index.htm Check the section about "ink cartridge maintenance" There is a picture of the access cover open. if you cannot see a small switch on the sides where the cover rests to indicate when it is closed, then it must be located just behind the back of the cover - There should be a small microswitch which is pressed in when the lid is closed, possibly with a lever instead of directly. The part of the lid/lever that presses against the switch could be worn or broken - if so try a small piece of tape on any worn bits. If anything is broken, please post back a photo and we may be able to help you fix or replace it. The switch itself could have come loose from its mounting. fixing this would depend on the type of mounting, but could be either a glueing job or just pushing it back into place. The switch may be stuck, disconnected or faulty. Try pushing the switch in manually, see if the plunger of the switch can move, and if the message goes away when the switch is pressed. You could possibly remove the switch and simply join the two wires, or short across them in order to complete the circuit - if this works, but pressing the switch doesn't, then the switch is faulty. You should be able to get a replacement from most hobby electronics stores, if you need help finding a replacement please ask. If the switch is soldered directly to a printed circuit board, then see if you can take a photo and post it back to us. replacement is probably the same, except a requirement to unsolder and solder the switches. If no luck with any of that, then try contacting Dell or using their online service chat; http://support.dell.com/support/topics/global.aspx/support/dellcare/en/contact_us_options?c=us&cs=19&l=en&s=dhs&~tab=1 They may let you know a quick fix, but will probably require you to get the printer serviced. Hope this helps :)
Posted on Jul 15, 2007
  • Nigel Ridehalgh
    Nigel Ridehalgh Jul 15, 2007
    PS the switch could also be next to the hinge axles, if they pass through into the main housing.
    President:
  • 2,961 Answers
Unless the mechanism on the lid is faulty, the only non mechanical thing you can do is go to add/remove programmes and uninstal the printer driver, then go to start or control panel>printers and faxes and look in the printers folder for your printer, if it is still there, right click and select cancel all documents, then right click again and select uninstal, if there is no icon dont worry. disconect the printer and restart your pc, then re instll te printer driver again and and reconnect the printer when prompted and it should re install, ensure the printer is aet as the default printer. See if your problem is resolved, if not the mechanical side of the printer will have to be looked at although it wil be cheaper to purchase a new printer.
SOURCE:
First of all I have a paper jam, one sheet got stuck after I tried to make a copy. Since then every time I turn on the printer it won't print or copy, of course the sheet is still stuck. I get the message:...
hello
first open the front cover remove the toner of the printer and remove the paper jam, and turn off the printer, unplug the power plug from wall outlet and at the back of the printer and after 2 minutes plug it back and turn on.
thank you
Mar 07, 2011 | Office Equipment & Supplies
Getting "inner cover is open" message
The inner cover is a flap on the inside in front of the carriage when it is at rest when the cover us open. You had to flip the inner cover down to access the ink cartridges.
Open the cover. The inner cover is in the center and need to be flipped up.
Good luck.
Dec 04, 2009 | Canon Pixma MP500 All-In-One InkJet...
Front cover dore open or cartridge missing
Try reseating the ink cartridge and see if the cover door is firmly closed.
Mar 27, 2009 | HP LaserJet 1020 Printer
Trying to print and printer says cover open, i have shut the cover several times but message wont go away
it looks like there is some kind of sensor that is not working (the cover sensor).
maybe you will need to check if anything is jammed.
Sep 03, 2008 | Lexmark Office Equipment & Supplies
X3480 cover open message
Ajkill is right, although his description isn`t very exact. Take off the complete scanner part: (back hinges first, then the blue arresting lever at the front), disconnect the flat band cable and the power supply for the scanner part and take off the complete scanner part. You´ll see a triangular part that goes in a slot of the dark grey cover which covers the rest. It should press againt a white lever which itself presses a little black switch sitting on the printed circuit board. If this white lever has fallen off the switch is always in "Cover open" position. To get it and reposition it (if it isn`t broken) you have to take off the dark grey cover which covers all the rest: take off the front screws and carefully lever out the sides with a small screw driver. Good luck with the repositioning, it is very fiddely and to see how and where it has to go you best use a magnifying glass!  But I could manage it and my printer is working now again. And good luck with fitting it all together again without breaking anything!
Mar 19, 2008 | Lexmark X3480 All-In-One Printer
Printer cover open error message
I had that problem too.
Unplug the printer.
Hold the printer cover open while you plug in the printer.
Then wait for the printer to power on while still holding the cover open.
Then close the cover.
The buttons should work and th error message should be gone.
It worked for me.
Nov 01, 2007 | Lexmark X2250 All-In-One InkJet Printer
CD printing
there is a small,square button near the right,front corner. think of it as the button for the refrigerator light. It must be depressed by the closed top or maybe something to wedge it down. Duh
Oct 30, 2007 | Canon PIXMA iP4300 InkJet Photo Printer
Brother DCP 330C
This COULD BE that there is some paper stuck in the dcp. Open cover and try to see if there is some paper left in the machine. I ve noticed, that -seeing from behind!- on the right side paperpieces are stuck and disturb the disk (foil) which give the printer info what to do. Open cover and try to look into the edges (seeing from the front: its the left side -where the modell name is printed) In some cases this means that the purgecamshaft is defective.
Aug 17, 2007 | Brother DCP-330C All-In-One InkJet Printer
HP1060 won't print
Have you looked at the front cover to see if the tab there is broken? (this will tell the PC that the front cover is still open) So you'll want to go around the edges of the printer cover to see if there's anything broken and a small hole in which the tab would insert into. If it is the case, and you don't want to spend money on fixing it, then do what I do...Rig up a paper clip and electrical tape to work as the tab, making the printer think that the front cover is always closed.
Mar 26, 2007 | HP LaserJet 1020 Printer
Dell 725 InkJet Printer Logo
44 people viewed this question
Top Dell Office Equipment & Supplies Experts
David Patricia James
Marvin
Marvin
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
