Question about Vacuums
Hyla power head wont work - Vacuums
I have a DC41. The power head wont turn and is making a squealing noise.
Sounds like your power head is seized or almost seized. Possibly real dirty. take apart and lubricate ends and replace the belt I feel is slipping Hence the squealing.. Clean all parts thoroughly.
Dec 02, 2016 | Dyson DC41
How do I remove hose from end that goes into vacuum cleaner?
if it is a convulated hose then it is screwed in to the fitting as if it is a left hand thread
the end section in the fitting is normally glued in to the fitting as well, so you will have to use a small flat bladed screw driver and pass it along side of the hose to break the glue
whenyou have the hose out cut off the bad bit or fit the new hose in after you put a small bit of contact cement in the thread of the fitting
Oct 31, 2015 | Hyla NST Vacuum Cleaner NST
Compact electra C9 vacuum power head wont turn on
Have you checked the electricity is getting to the motor? You can replace the motor if necessary.
Jan 17, 2014 | Electrolux Epic 6500 Vacuum
Power head brush wont run
Could have a loos belt, check and replace if necessary.
Nov 23, 2013 | Vacuums
Kirby G10D wont power on
head or bag system not fitted correctly refit both
May 26, 2012 | Kirby G5 Bagged Upright Vacuum
Can you wash canister and vortex assembly in Dyson DC17
you need a Hyla they use water as a filter and the smell goes down the drain
Jan 22, 2012 | Dyson DC17 Animal Bagless Upright Cyclonic...
My machine wont pick up the dirty water. If I take the cover off the recovery tank there is a lot of suction but it wont **** up the water. my carpet is soaked. What can I do
at power head clean out area before power head also look for small hose and clean out and look at rollers,i hope this works if you have directions still they should be able to help you out some more.thanks
Nov 29, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Dyson slim upright has lost suction via the power head , floor wand is working normal
its either the power head is clogged up with debree or the belt is broken. if the belt is broken it wont wisp everything up. Take it to a shop to fix. DONT TRY TO FIX IT YOURSELF~!!! dysons are very expensive and arent made to just be taken apart
Sep 11, 2009 | Dyson Vacuums
Hyla electric brush won't work
Where can I get a Hyla vacuum instruction manual?
Jul 28, 2008 | Vacuums
Vacums
check belt not broken - could have happened when you caught tassle in head
Apr 18, 2007 | Kenmore 23313 Whispertone Bagged Canister...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
