Question about Samsung Syncmaster 730B 17" Flat Panel LCD Monitor
Monitor Light comes on but shows no screen?
Hi, I just moved and my monitor is not coming up, The PC comes up on another screen but I can't get this monitor to show life. Thank You.
  • james605s Jan 26, 2009
    The power light does come on. I am wonsering if it may have something to do with the lock on the back of the screen. Thank You.
    Problem Solver:
  • 10 Answers
Check your monitor cable if power light comes on
Posted on Jan 26, 2009
  • Janaka Sanjaya Jan 29, 2009
    if power light comes with some massege on screen (check your cable) that mean your monitor is ok
    you have to check your monitor video cable is broke (if yes change monitor video cable) or change your VGA
    or if not comes screen masage, you have to check your cercuite board (advance users only) loos conection and check H-Out
    or if not come on your monitor that mean your flyback is burn
    flyback is 2nd expencive part of the monitor
    if you have flyback problem i sugess buy a used monitor
    GOOD Luck ! and wish you'r monitor work
Wavy diag lines moving on monitor?
First, try a different monitor to eliminate that its just the monitor
If the other monitor comes on fine, that will show your monitor may need replacing.
You can also try the degauss button on your monitor screen (icon looks like a magnet)
Sep 01, 2013 | E-Machines eMachines Desktop PC
Laptop screen keeps flickering
Changing the refresh rate might help.
Right click on the screen. In the box that comes up select Graphic Properties. In the window that comes up click information. Box that comes up select monitor tab. Will have a list of display sizes and refresh rates that are supported by your monitor. Once you have that information you can make changes.
FYI: Acer says max resolution 1920 X 1080 with 75 HZ refresh rate.
Also if you have a tube light or speaker system close to the monitor then try moving it further away.
Apr 30, 2012 | Acer Computers & Internet
When i boot up my pc , the monitor light comes on but flashes and the screen doesnt come on for anything from 1 hour to 4 hours
You need to establish if this is a monitor problem or a problem with the graphics card in the PC. Can you try another monitor or have you tried turning the monitor off (for a long time) separately, leaving the PC Base running, then turn monitor back on again? If it takes time to come back on while the PC is running, it is likely to be the monitor at fault.
Feb 27, 2011 | Acer Aspireā„¢ T180 PC Desktop
Monitor does not come on
  • try to toggle FN key and F5 key..
  • try to plug in to an external monitor screen, if it works on external monitor, there is a problem on the laptop LCD screen
  • call your manufacturer for warranty or local service technician for LCD screen replacement
Apr 28, 2009 | Computers & Internet
No Picture or PC Display
Sounds like either your Monitor is giving up or your Graphics card.
I would suspect your monitor. However, do double check the physical connection of the monitor to your PC, that usually does come loose - just tighten that and see how it goes.
I hope this helps,
Thanks,
Mar 15, 2009 | Samsung 192MP SyncMaster 19" LCD Monitor
Booting
Press the FN F5 screen to see if you can toggle the screen on. If you have a external monitor plug it in to the notebook and see if you have video. If it show in the external monitor your LCD screen has gone out.
I hope this helps.
Feb 19, 2009 | Acer Aspire One PC Notebook
Monitor displays breifly then goes to blank screen
If tried the monitor on two other computers with the same result -- definitly your monitor is faulty. Take it to the repair shop. To make double sure, run your computer with another monitor. If everything is fine now; you can blame the monitor.
Dec 17, 2008 | Dell Dimension 4600 PC Desktop
Acer AL1912 Monitor - Screen to black and light on yellow
I found some solutions other posted that didn't come up the first time I looked. I did a reboot and I'm good to go!
Dec 07, 2008 | Acer Computers & Internet
Monitor problem
Hi...there,
It's turns blue to power safe mode (yellow) it's prevent futher damaged to your monitor. It's seems you got a busted backlight inverter. Need to replaced a new one...Since you only got it for a few months, send it back to Acer for a replacement of a new backlight inverter... Have a nice day!
Oct 17, 2008 | Acer AL1916W 19" LCD Monitor
Compaq fp7317
I suspect that when you reattached the monitor back you might have moved the agp card out of her slot. Check if you have connected properly your monitor to the pc And if the agp is in it's slot properly attached. Hope it helps, good luck!!
Feb 14, 2006 | HP Compaq FP 7317 17" Flat Panel LCD...
Samsung Syncmaster 730B 17" Flat Panel LCD Monitor Logo
158 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
