Hello? I have a new Eclipse Kenmore being installed Tuesday 12/23. What do I need to provide for a water supply?
I see your installation date has come and gone, but if you still need to hook up the water you can find an "ice-maker kit" from almost any home improvement store (such as Lowes, Ace, Home Depot etc....) This includes 1/4" bendable copper tubing and a valve that will tap a near by cold water supply pipe. If you find a kit with plastic tubing, I would steer clear and find the bendable copper. Plastic tubing kits are notorious for springing leaks. Buy some extra compression nuts and washers for the tubing while you are there, it may take more than one try to get a waterproof seal if this is your first time hooking up water and ice dispenser.
When hooking up the tubing to the back of the refridgerator, leave a couple coils of slack to allow the refridgerator to be pushed in or pulled out without straining the connection. There is usually a small clamp on the refridgerator back to hold the tubing steady, make sure you use this. This will help ensure a leak free connection. After you have the tube hooked up, push the refridgerator all the way back, then pull it back out and check for leaks. Sometimes the tube will start dripping a bit after the refridgerator is moved, so this step helps ensure you won't have leak problems.
