Question about Microsoft Xbox 360 Console
The colors on all the games or now red and green. All are also faded.What do I need to do?
    Scholar:
  • 51 Answers
  • Make sure all the component video cables are properly plugged in,
  • perhaps you may have mistaken one of the inputs for video as the audio connector (red one) also
  • if you're using a VGA cable,sometimes the pins come a little loose, and the the connector needs
  • to be reseated and jiggled until you get the full colored output signal. (rare, unless it is disconnected and reconnected a lot.)
I hope This Helps. Just Double check the inputs and makes sure everything is hooked up correctly.
This same result happened to me when I tried to connect my component cable to the back of my tv with out looking back there to make sure I did it right.
Posted on Jan 26, 2009
My grandfather has a Hitachi 50ux58b and is having double vision or shadowing -- whatever it's called and redness color fading-like. Was told it was a convergence IC that needs replaced -- uncle looked...
try not to do repair yourself. the tv holds high voltage even when unplugged. you could KILL yourself. If red is fading the convergence ic will not help. you need to replace all the guns. red, blue, and green. usually each tube or gun is around 300 dollars each.
Mar 21, 2011 | Televison & Video
I saw an answer up above regarding the green hue on the projector, is there anyway to remedy this problem? This is really annoying to me and I would like to fix the issue. Thanks,
Three LCD block in the Panasonic projector PT-L735 green,blue and red and two polarizer use with each LCD (as show in picture below) when polarizers faded due to age or any other reason then screen show the color. In your cause the green polarizers faded and need to be replaced good_help_9.png
Jan 08, 2011 | Panasonic PT L735U Multimedia Projector
Still, bright images on my PS3 change the color of my TV in areas
hi verifies if you are connecting good the video cable i mean the red, the yellow, and the white, if this dont serve you, is because your tv is to old.
Sep 19, 2009 | RCA TruFlat 27F520T 27" TV
Red color faded and red color is mis-aligned.
Hi We've been seeing alot of the HP Color Laserjet range of laser printers coming through with a "prints lightly with red" or "red is faded" fault report, we've been able to resolve the problem mostly by cleaning the scanner. Misalignment is normally resolved therafter by calibrating the machine using its calibration function. (if it has one) Wouldnt suggest this gets tried unless one is familiar with stripping and reassembling these machines though. Hope this helps.
Mar 23, 2009 | HP Office Equipment & Supplies
Faded color display
replace the colorwheel.
Jan 27, 2009 | Eiki EIP-3500 DLP Projector
Guns on their last leg- color fading
If you are asking about Guns in rear projection tv then answer is No.
Rear projection TV has 3 Guns (CRTs), red-green and blue and each gun has its unique color phosphorus coating to produce its mono color (red /green /blue) and these are not interchangeable.
Need further info, let me know.
Oct 23, 2008 | Televison & Video
JVC I'Art Pro, Color Fade
sounds like two separate problems. color fade ?
green gun/band = bad convergence ic
Dec 18, 2007 | JVC AV-56WP30 56" Rear Projection...
Poor color
You may need fluid change. CRT gets dirty fluid, must be changed after long time of use.
Nov 26, 2007 | Philips 55P8341 55" Rear Projection...
Color fade
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Oct 11, 2007 | Hitachi 51F500 51" Rear Projection...
Faded colors
If the picture is dark or messed up too bad, the magic focus will not function, are all the primary colors faded? RED GREEN BLUE? You might have a bad CRT, would call a service man to check out.
May 21, 2007 | Samsung HCN5527W 55" Rear Projection...
Microsoft Xbox 360 Console Logo
50 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Troy Gorman
Troy Gorman
marley mcelhinney
Pablo Gonzalez
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
