Data Rack Hi I ran cat 5e cable to each point one for phone and one for data. A total of 20 points. I did a trade school copurse on data and phones but did no prac. How do I wire up data racks? regardsRobbie
  • 1 more comment
  • mr security Jan 26, 2009
    I have run the cable s to all points and fitted off the points I now have the cables all together ready to be patched into a rack and the connect to PC and phone line coming in.
    What data racks do I need ?
    Total of 10 point and phone outlets
    I have 2 phone lines coming in.
    Thanks
  • mr security Feb 16, 2009
    I havent brought a patch panel yet.
    I have phone on one cat 5 and data on the other
    thank you
  • Carl Navarro
    Carl Navarro May 11, 2010
    What do you mean? Did you buy a patch panel? Are you trying to terminate both the phone and data wires on a panel or only the data?
Cat 5e making networking cable setting. Please tell me setting pc to hub and how to networking cable connect the conector.
Posted on Feb 16, 2009
How to transferr pictures to computer
Send them to your email address instead of a phone number using picture messaging
Mar 17, 2015 | Samsung SCH-u540 Cellular Phone
What is the green cable called from the Arris NVG510 kit?
It would be classed as a cat5e cable with RJ11 connectors.
Might be something like this.
Amazon com Belkin High Speed Internet Modem Cable RJ11M 15ft Computers...
You will have to use the phone line filter to hook the cable to the phone socket.
Sep 25, 2014 | Arris Nvg510 At&t U-verse Modem Gateway...
No response from host error message display on mobile screen when i connect cell with data cable
cleaned both point of your connector of your data cable and phone it could be dirt that prevent data to communicate.Isolate cable by brand new cable. If it is doesn't work reset your mobile to default factory settings.
Sep 09, 2011 | Nokia 2626 Mobile Phone
How can i subscribed to packet data?
Packet data (EGPRS) Enhanced general packet radio service (EGPRS), packet data, is a network service ceive data over an Internet protocol which allows mobile phones to send and re (IP)-based network. It enables wireless access to data networks such as the Internet.77 . 2005 Nokia. All rights reserved © Copyright The applications that may use packet data are MMS, browsing sessions, Push to talk, e-mail, remote SyncML, Java application downloading, and the PC dial-up. Packet > Connectivity > Settings > Menu To define how to use the service, select Packet data connection > data . to set the packet data connection to be established when an When needed Select application needs it. The connection will be closed when the application is terminated. to set the phone to automatically connect to an packet data Always online Select network when it is switched on. indicates a packet data connection. Modem settings You can connect the phone using an IR or a data cable connection to a compatible PC, and use the phone as a modem to enable packet data connectivity from the PC. > Settings > Menu To define the settings for connections from the PC, select , activate Active access point > Packet data settings > Packet data > Connectivity Alias . Select Edit active access point the access point you want to use, and select , and enter a nick name for the currently selected access point. for access point , and enter the access point name (APN) to Packet data access point Select establish a connection to an EGPRS network. You can also set the dial-up service settings (access point name) on your PC using If you have set the 121 p. PC Suite the Nokia Modem Options software. See . settings both on the PC and on your phone, the PC settings are used.
Apr 14, 2011 | Nokia 6020 Cellular Phone
6300 Cellular Phone: i have nokia 2700.when i connect thgh data cable u...
firstly u conect with pc suite.after few min.its shows connected.change access point name
May 18, 2010 | Nokia 6300 Cellular Phone
MPt not detecting zn200
You need at least MOTOROLA PHONE TOOLS 5.0 version.Go to the Settings of this phone.Then go to USB option. Then select USB Modem.I think it will work. If not then I think you have a problem with Data Cable or the data cable point.
May 01, 2009 | Lands Phones
Cannot browse the internet i should subscribe to
Here is the procedure for subscribing to packet data:
Menu--settings--connectivity--packet data--packet data settings--edit active access point--packet data access point. Once you are at this point you will be required to type in a name for your access point: Type in "Internet" and then save your settings and exit back to standby screen.
You should now be able to browse the internet.
Best wishes,
Graemevm
May 01, 2009 | Nokia 2680 Slide Cell Phone
I have bpl sim card,i want to know setting for using wap internet on my mobile 5300
Hi i was reading regarding WAP settings for BPL mobile...I have copied and pasted what i saw from different forums...see if it is of any help
you can manually conigure GPRS in your mobile phones.
BPL_WAP
homepage http://wap.mizone.bplmobile.om
Session mode permanent
connection security off
data bearer gprs
gprs access point mizone
IP address 10.0.0.10
authentication type normal
login type automatic
BPL_MMS
data bearer gprs
For those who are interested in using GPRS facility provided by BPL Mobile (Mumbai only) here are the brief n settings required for it. You can also use this for surfing Internet through you PC provided your PC is connected to your mobile using Data Cable or preferably BlueTooth.
Go to the main menu and open “Settings”
Select “Configuration” and then “Personal Configuration Settings”. Create a new configuration settings by selecting “Add New” from “Options”
The account fields should be filled as below:
Account Settings Account Name : bplweb
HomePage : http://wap.mizone.bplmobile.com
User Name : Your mobile number
Password : bplmmsc
Use Preferred access point : No
Access point settings : As given below
Access point settings Proxy : Enabled
Proxy Address : 10.0.0.10
Proxy port : 9401
Data bearer : Packet data
Bearer settings : As given below
Bearer settings Packet data access point : mizone
network type : IPv4
Authentication type : Normal
Password : bplmmsc
Now once you have done that get back to “Personal Configuration Settings” select the new account “Bplweb” that you have just created and go to “Options” and click on “Activate”
Go back to the main menu and open “Settings”
Select “Connectivity” and then “Packet Data”
Set the “Packet data connection” to “When needed” and then click on “Packet Data Settings” then “Edit active access point” and then set “Packet Data Access Point” to bplgprs.com
These instructions are according to the Nokia sets 3110c, 6085 and should not differ much for other sets and brands and in case of which you can always go to the customer care as did.
BPL WAP SETTINGS FOR MOBILE PHONES
Connection name:- BPL WAP
data bearer: packet data
Access point name: mizone
User name: 919821099800
Prompt password: no
Password: bplmssc
Authentication: normal
Homepage: http://wap.mizone.bplmobile.com/
ADVANCED SETTINGS
network type: IPv4
Phone IP address: automatic
DNS address: automatic
Proxy server address : 10.0.0.10
Proxy port address : 9401
Hope this helps !!!
Apr 17, 2009 | Cell Phones
What is UTP CAT 5e cabel?
This 1000 foot, spool-boxed roll of grey Cat5e bulk cable is a must-have for extensive networking. This unterminated and UTP (unshielded twisted pair) cable is perfect for a plethora of networking applications.
Cat-5e, enhanced Cat-5 cable, is the standard for modern networking - enabled for far end crosstalk and compliant with up to 1000BASE-T standards. This unshielded cable comes in its own spool box and is connector free, giving the user the freedom to customize the length, wiring, and application.
This cable is 1000 feet long and are marked at every foot (marked 0001 - 1000 at each foot).
Wire the cable as either a patch or a crossover cable, use it for Ethernet or any other data transfer applications. Sewell Direct works hard to bring you affordable Cat5e bulk cable solutions.
Jan 13, 2009 | Intellinet Active Networking CAT5e UTP...
Phone to Cat5e cabling - How do I wire the wall plate
Wire your phone box using your Cat5 cable, use 4 wires instead of 8 wires of Cat5.
Nov 20, 2008 | Cat5e Unshielded Twisted-Pair Patch Cable...
Computers & Internet Logo
117 people viewed this question
David Payne
David Payne
