Question about Garden
I have a Ryobi 790 R trimmer and the upper drive shaft broke right above the center connecting hub and I was wondering if the hub came with the upper dirive shaft or if it was part of the upper drive shaft. If so I think that the part number is 75304344. Thanks
boscia
  • 163 Answers
SOURCE: Ryobi TP30 straight shaft line trimmer convertible - drive shaft disconnected from motor
check both ends of shaft, they're usually a hex or torx head. sometimes the can strip or even snap off. if you find noticable damage replace the shaft
Posted on Nov 29, 2008
  • 376 Answers
SOURCE: Replacing Drive Shaft for a Ryobi 725r
The lower flex shaft should cost around $40, unless you order it online and have to pay shipping. You should be able to get one from your local MTD dealer. (Ryobi is owned by MTD)
Posted on May 25, 2009
SOURCE: Engine/shaft stopped working. Need to fix Ryobi trimmer.
Hi, I have a Ryobi brush cutter and the engine has a tendency to move up and down the shaft. It also rotates around the shaft
Posted on Apr 11, 2010
SOURCE: Ryobi 700r how do you replace flexible drive shaft
I have an Expandit Trimmer and i think the flexible drive shaft has become detached from the trimmer head ,isit possible to re -engage it
Posted on Jun 14, 2010
SOURCE: ryobi 2 cycle gas trimmer 705r/725r
The gas nipple that come out I have...whats goes in the other hole?
Posted on Sep 04, 2010
Ryobi weed eater upper and lower shaft spins, but head doesn't spin, why?
If not a clutched model, likely the flexible drive shaft is broken. Check 1st to insure the engine head is firmly positioned into the aluminum shaft case. If it is remove at the engine, disconnect the cable as necessary and pull out the shaft for close inspection.
May 02, 2014 | Ryobi Garden
Trimmer head not functioning right
sounds like the inner drive cable has broke inside the shaft that drives the trimmer head.
Apr 30, 2010 | Husqvarna Forest & Garden 125c 17"...
Ryobi 825r trimmer turns very slowly
The connection between the two shaft has a molded lead piece that the upper half is suppose to match with the attachment. If it not square you will need to replace the lower shaft.
Merry Christmas
Dec 22, 2009 | Ryobi Garden
I have a 790r and the detent pin on the lower
That pin should be the same as other Ryobi trimmers. Find one for one of them and compare. Lee
Sep 15, 2009 | Garden
I broke the flex drive shaft but can't remove the head to get out the broken shaft piece. I got the big part of the shaft out from the top. the bump head has been replaced by the kind that you cut 2 pieces...
The flex shaft drive you are referring to is only sold as a assy that I am aware of. You can try www.partstree.com for the replacement shaft assy. you are refering to, however you may find out by the time you buy a new shaft assy you may be money ahead just buying a new trimmer.
Sorry
Aug 08, 2009 | Ryobi Garden
My shaft broke
Well it sounds like you have already done the homework. now the choice really is yours. either buy the part and install it or get a different trimmer.
if everything else is still good I would buy the part, lube it up and use it.
Jun 22, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
May 25, 2009 | Ryobi Garden
The pull rope broke on my ryobi 705r/725r gas trimmer. I have all the screws off but it seems to be held on by the center shaft that spins. What do I do now?
I have the same issue of clutch removal on a Ryobi 725r. Actually the clutch finally died after many years of use.
Instead of using a screwdriver to hold the piston I recommend using a piece of clothesline rope. It will be easier on the internal components and won't scratch up the cylinder walls or piston. Just be sure to leave a small amount hanging out of the spark plug hole so you can pull it out afterward.
Apr 15, 2009 | Garden
Garden Logo
51 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
