Question about Bowflex Treadmill Series 7
Bowflex series 3 stops after 10 min
Treadmill will stop after about 10 min motor is not hot but belt and motor feel bound up. After about 10-15 min it will start again
  • Anonymous Mar 18, 2014
    stops running about every quarter mile. I turn it off and on and it will run for another quarter mile then cut off again.
  • Anonymous Mar 23, 2014
    belt will not move and no elevation
    Problem Solver:
  • 12 Answers
To much electrical draw on motor control board
Lubricate, lubricate, lubricate
Posted on Mar 16, 2009
Avanti 928 Treadmill U8 error
try to LUBE the deck belt, with silicones or wax, . If the problem persist TIME to replace the old deck board.
However, adjust The REED switch + speed sensor.. See the owner manual for to locatea. otherwise download free from
www.fitnessmanualsonline.com
God bless you
May 20, 2013 | Bowflex Treadmill Series 7
Bowflex series 7 treadmill Calibration fail. Next indicated action?
It looks like the main circuit board is damaged and needs to be replaced unless there are separate modules in it.
Jan 22, 2013 | Bowflex Series 7 Treadmill Folding Pro...
My bowflex treadclimber just stopped working. The control board workers bu the belt will not move.
1) Lube the deck belt, this is problem by lack of maintenance.
2) Test the input voltage motor, if there are voltage, the motor need repair.
3)Test the outputv voltage board, for input voltage motor, if there are NOT the board is faulty.
See the diagram attached. God bless you
May 15, 2012 | Bowflex Treadclimber
Who can repair my bowflex treadmill 5 series in toronto
There are four typical causes for this problem :
1) The walking belt and/or deck are worn. (85% of the time)
2) The walking belt and/or motor belt are too tight- if you have adjusted either recently. (8% of the time)
3) The motor has lost torque and needs brushes or has demagnetized. (5% of the time)
4) The controller board is dropping output. (2% of the time) . You can do it foryourlsef. However i will give some websites FOR TO CONTACT THEM:
www.unitedassemblers.com + www.treadmildoctor.com
Sincerely. Merry Christmas.
ERNESTO CUADRA
MANAGUA, NICARAGUA.
Dec 16, 2011 | Bowflex Treadclimber
My Bowman treadmill 7 series stopped working. It just shows 2 words: safe out. Please help.
Make sure the magnetic safety key ('safety pull' or 'emergency stop magnet') is in place. SAFE OUT indicates that the safety key is not in position or is otherwise not working properly.
For more information consult the following manuals:
http://download.dfxi.com/supportdocs/OM/Bowflex/BFX_TM3-5-7_OM_RevD_web.pdf
http://www.pdfstock.com/bowflex-3-5-7-series-treadmills-assembly-manual-pdf.html
May 05, 2011 | Bowflex Treadmill Series 7
My question is, last night, I set the speed to 5mile/hr, the treadmill automatically stopped after 12mins( the belt stop, power was on). and I can not restart it immediately, Then after 5 mins, the belt...
A treadmill will shut down from to much friction which is due to high motor current because the walkbelt and deck are not properly lubricated. I would recommend replacing the motor controller,walkbelt,deck and applying .5 oz of lubricant on the deck every 3-6 months or 100 hours of use. This will extend your treadmill's life many years.
Jul 08, 2010 | Nordic Track /proform Treadmill...
I have a Nautilus Bowflex 5 series treadmill. After 10 to 15 minutes running it suddenly stops and Er 5 shows up.
I will have to check the error code but sounds like a heat problem. When you get too much friction between the walk belt and the deck it builds a lot of heat which creates more drag on the motor. This causes the motor to overheat which in turn usually shuts the machine off. You can let it cool and go back exercising until the cycle repeats. If this sounds like your issue, try lubricating the walking belt. If it's not in bad shape it should make a difference. The machine should run longer. 10-15 is pretty quick though so it make take a couple of application of lubricant. The belt may need replacing if the need for lubricant becomes too regular.
Nov 16, 2009 | Nautilus Exercise & Fitness
Bowflex tc 1000 treadclimber
TC1000 from Bowflex, works okay for 15 mins then the speed surges ahead and stops dead with error E1
Jun 28, 2009 | Bowflex TC1000 Treadclimber
Bowflex Treadmill Series 7 Logo
342 people viewed this question
Top Bowflex Exercise & Fitness Experts
Howard
Howard
Glenn Mayer
Glenn Mayer
Shehu Pro
Shehu Pro
Are you a Bowflex Exercise and Fitnes Expert? Answer questions, earn points and help others
