Question about Lands Phones
Instruction manual for Sonivox Pulse - Lands Phones
I have a Serene CL-60AP phone. It receives calls but I can't get it to dial out. I hear it dialing like an old rotary phone but then the dial tone comes back.
You need to change the dialing mode to tone rather than pulse.
If you would like to know how to do this refer to page 26 of the instruction manual
50. DIALING MODE SETTING (TONE OR PULSE)
page 15 on the pdf file below
http://hearinglosshelp.com/store/wp-content/uploads/sites/2/2015/02/CL60Ausermanual.pdf
Depends on what your telephone exchange accepts as a dialing signal. Strange thing is phone is factory set to tone but it seems to sound like your phone is on pulse.
Mar 11, 2017 | Lands Phones
I have a GE cordless phone model # 26928GE2-D and would like to know how to change the setting from pulse to rotary dial
The phone is pre-set for touch-tone use. To set to tone or pulse dialing:
1. Press and hold the Program button until you hear a beep.
2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing.
3. Press the Program button again. You will hear a confirmation tone.
For more details, kindly download the instruction manual by clicking this link
You'll require Adobe PDF Reader installed on your computer to view this manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Also, the manual has very small print, so kindly magnify it by using the "+" button in the Adobe PDF reader window.
Hope this solves your problem. Thanks for using FixYa
Mar 25, 2010 | Uniden Cordless Phone
Directions on replacing battery
Found manual online and found page with replacing batteries instruction
Feb 04, 2010 | Probasics Digit-Ox Finger Pulse Oximeter
I blended my instruction and owners manual.
You can get this with google.
Otherwise ask manualfox.com - this is the hazzle-less way to get it.
Apr 08, 2009 | Jack Lalanne Health Master 100 8-Speed...
My VTech 2461 cordless phone is stuck on Pulse
To switch back to tone dialing, hold down the SELECT button for couple of seconds. The display on the base unit will read PU indicating pulse dialing. Now press and hold SELECT to change it to TN (Tone dialing).
Dec 17, 2008 | Vtech VT 2461 Cordless Phone
Pulse Bagless dust press system vacuum cleaner I need to download the instruction manual
Dear Customer
please check the following link for
Sanyo Instruction Manual Upright Bagless Vacuum Cleaner SC-150, SC-180
http://homeappliance.manualsonline.com/manuals/mfg/sanyo/sanyo_upright_bagless_vacuum_cleaner_product_list.html
please rate this,Thank u
Dec 16, 2008 | Sanyo Vacuums
Changing from Pulse dial to Tone
Go to Menu > Set tel line > Set dial mode > Tone. That should solve it.
May 26, 2008 | Panasonic KX-T7730 Corded Phone
From Pulse to tone
TONE/PULSE DIALING
1. Make sure the phone is OFF (not in TALK mode).
2. Use the CID/VOL left (-) or right (+) arrow button to
scroll to 1TONE or 2PULSE, or use the touch tone
pad on the handset to enter the desired setting. For
example, to choose TONE dialing, press the number 1
key. 1TONE is the default setting.
3. Press flash/program to store selection. You will hear a
confirmation tone.
Aug 31, 2007 | GEH5450 Cordless Phone
Pulse/Tone
These units just have a small switch on the side of the handset with two positions for pulse or tone, just to the left of the earpiece Here is the link to the instruction manual for your phone; http://www.swbfreedomphone.com/ib/ibcord/fc2548.pdf Check page 2 of the pdf file if you are struggling to find the switch. Hope this helps :)
Apr 22, 2007 | Southwestern Bell FC2548W Corded Phone...
GE Phone Model 25881
Per the instruction manual, there is supposed to be a switch on the base (look on the back or bottom) for TONE/PULSE mode. Here is a link to the manual: http://www.home-electronics.net/GE/ProductDownloads/25881EE3_IB.pdf In the "troubleshooting" section, there is this entry: Dial tone is OK, but can?t dial out: Make sure the TONE/PULSE setting on the base is set to the type of phone service you are subscribed to.
Dec 31, 2006 | GE 25881EE3 Phone
Lands Phones Logo
51 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
