Question about Teac Computers & Internet
TEAC VDRS7 TRAY MECHANISM
Will not open
Teac lev2494fhd
MAKE Please this steps and fix it. Merry Christmas.
Turn on your DVD player.
    • 2
Open the DVD player's main drive, also commonly called the DVD "tray." The region cannot be changed while a DVD is in the machine, so many DVD players require the tray to be open as an extra precaution.
    • 3
Push "Info" or "Setup" on your remote.
    • 4
Use the remote to select the "Region" option as indicated on your TV screen.
    • 5
Select "Region 9" to change the system to multiregion formatting. Regions 1 through 8 represent specific geographic locations and will not allow multiregion playback.
Dec 17, 2013 | Teac DV-3000 DVD Player
When i switch my teacpdh300 cd player on the drawer open and when i close it, it reopens
hi,
Check the tray loading belt of your cd player. If the loading belt is over sized then this problem can occur. Normally the loading belt will become over sized after a few years of use according to the weather condition. . If so the loading tray will not go inside fully and will not engage with close sensing switch. if so the it will open automatically without any external command .Normally in all players the loading belt will be under the loading tray near the frond side of the mechanism. check the same. keep the player in eject position remove power and then try to replace the belt.
ok
Jun 16, 2011 | Teac PD-H300 CD Player
I want to unlock the regions on my TEAC DV2800
  1. Turn on
  2. Open tray
  3. Press 2, 1, 6, 8 then ENTER using the remote control
  4. press 0 then turn the player off.
Jul 10, 2009 | Teac Televison & Video
Region Unlock TEAC PL-D3200
Multizone code for Teac PL-D3200 Here is the procedure to unlock your Teac PL-D3200 to play all zones of DVD's.
Using your remote control:
1. Switch power on 2. Open the dvd tray (leave it open with no dvd in it) 3. Press "stop" 4. Press "734466" 5. Use cursor to scroll up or down until it says "Region 0" 6. Press "OK/Enter" 7. Switch power off 8. Switch power on
It will now play all region DVD's! :-)
Nov 28, 2008 | Teac DV-H500 DVD Player
Unlock region codes for teac dvd player, model dv-4180
Hi Pacificmarli
I found the following Multizone Instructions for Teac DV-4180:
  1. Open the disc door
  2. Press Setup, Vol +, Vol -, Vol +, Vol - on the remote control
  3. Press < or > on the remote control to select the region code (255 is all regions)
  4. Press 'enter' to confirm
  5. Close disc tray
Hope this helps.
Miche
Jun 12, 2008 | Televison & Video
Unlock procedure for Regions
1. Press Open/Close on remote control. DVD tray opens. 2. Press the following buttons in sequence: 2, 8, 1, 2. 3. TV displays "Region 2" 4. Press the Enter button on the remote until code changes to 9 5. Press the Open/Close on the remote. DVD tray closes. 6. Press Power on the remote control. Now code free...
Feb 19, 2008 | Televison & Video
TEAC CD P1120 wont play
hi there krell
you definetly have a fault in your cd players main board best solution take to electrical shop and ask them to test all the circuits it wont cost much to get them checked out and see how you go
hope this helps and if you have the time please rate me if you dont mind
thank you
fixya
Jan 10, 2008 | Teac CD-P1120 CD Player
Tray Sticking on CD Player
reoccurring tray problems are a paim. It mauy be a spot of oil or grease on the tray motorbelt, or the wrong belt fitted, and or dry failing bubricant to opening cam and sliders. Best approach is to strip and clean everything, lube only with white plastic grease, and sparingly. I use graphic powder on tray sliders, be careful not to get lubricants on drive belts. try next size down belt also, or be sure the belt fitted is 2.0 mm crosssectional area
Dec 16, 2007 | Teac CD-P1250 CD Player
Hacking code for Teac PL-D3200
Sep 16, 2007 | JVC TH-S8 System
Computers & Internet Logo
26 people viewed this question
Top Teac Computers & Internet Experts
k24674
Computer Links
Are you a Teac Computer and Internet Expert? Answer questions, earn points and help others
