Question about Sony AW-Q170A-B2 DVD RW Dual Layer Burner
Plz help Can anyone tell me how to set this driver as a slave driver.... I looked in the control panel and didnt see this drive...... Some said something about BIOs and IDE and im a little lost with all this!
  • Darrell Brown Jul 15, 2007
    Hey can u experts just email me so we wont fooled this board! my email is dbrown71379@hotmail.com
    Thanks to all that gave me solution on my driver...... The sloution worked....
  • 624 Answers
I was too slow to post this first, however, it will add some detail to what Andyrst has already written?. Setting your drive as a slave is fairly simple, but there are a couple of ways to do it. Little class first: IDE or integrated drive electronics is the entire system that controls the computers drives and how data is stored and read. The typical computer has two IDE channels, each channel can control two IDE drives, a master and a slave. BIOS: Basic Newer computers use what?s called ?cable-select?, basically the IDE data cable tells the computer which drive is the Master and which is the slave. All you do is make sure the drive itself is configured to ?cable-select? mode or ?CS? (small jumpers on the back of the drive, default is usually set to CS) and plug in the data and power connectors. Older computers or custom built usually have the master/slave configuration you were referring to. One device, usually the hard drive, is set to master the other is set to slave using the same jumper system you saw on the CD drive. How do you tell? If it?s a Dell or HP cable select, if not you?ll have to take the PC apart look for the hard drive and look at its jumper setting to see if its set for CS or as master. Last step depends on who makes your PC and if you are replacing an old CD drive or installing a second. If you?re just replacing an old drive with the new chances are really good you won?t have to mess with the BIOS.
Posted on Jul 15, 2007
  • tomj23 Jul 15, 2007
    Oops, forgot BIOS: Basic Input-Output System. The core computer instructions that takes control of the PC when you turn it on. It tells the PC what hardware is attached and where to go to start loading the operating system.
    I noted that you posted a similar question earlier. If we?re talking way over your experience level just let us know. Sometimes its hard to judge just where someone?s knowledge level is so just let us know what, if anything you don?t understand and we?ll do our best to explain better.
    New Friend:
  • 83 Answers
There are jumpers on the rear of the unit and changing the position of the jumoer forces the computer to either a master or slave as it boots...on the rear panel it says cbl,sl,ms....ms=master, sl=slave, cbl=cable select...i hope this helps... also after done the jumper thing make sure your ide controller is on for the units on that cable...good luck my email address is troublerst at hotmail if you need further assistance....
I dont know why but my screen position went wrong after u restart my computer and its not getting fix i didnt change any thing plz help i try to set it with my monitor but it didnt help :(
Go to the windows control panel and select the display icon. This will take you to the display menu where you can change your resolution. If changing it doesn't make a difference, then you may need to update your graphics drivers by going to the website of your graphics card manufacturer and downloading updates.
Mar 12, 2011 | Computers & Internet
Want to install wd1200jb-75cra0 as slave drive in dell xps420 with vista operating system operating master drive. do i need a driver installed first before it will recognize the wd1200 as a slave?.
there is a jumper setting on the drive itself that determines master and slave. Look closely at it, there is always a diagram of the pins to connect or disconnect for master slave setup.
No longer needed with Sata drives...
Feb 18, 2011 | Western Digital Cavier SE WD1200JB 120 GB...
I have connected my 300 gb sata hdd to my pc which already has a 160gb sata hdd set to master when i start up my pc they r both set to master but i am told sata hdds dont have master / slave settings
They don't have master/slave settings as only one SATA drive can connect to a controller, however some BIOS have a setting designed to facilitate older OS's like XP that don't always have drivers available for the newer SATA RAID controllers built into most mid to high end PC's. If this setting is enabled on your PC then they would look to windows like a pair of master IDE drives on a Primary and Secondary IDE Channel even though each has it's own dedicated controller.
Sep 21, 2010 | Western Digital Hard Drive
My kingston2gb pendrive not working ,plz insert a disk into drive g plz tell me a solution
control panel admistrive tools,computer management,device manager scroll down universal serial bus controllers you should see a yellow question mark? right click to reinstall drivers or ports(com&lpt)right click updare driver
hope this helps
Sep 09, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
What is the jumper setting for 'Slave' on Maxtor
Look at the picture, I cannot memorize all hardisk jumper but almost all drives have label in it. where you put the jumper for the Cable Select, Master, Slave.
See picture below. Opposite pins has label on it to where you put the jumper.
Oct 24, 2009 | Maxtor DiamondMax 6L160P0 160 GB Hard...
Volume control
Try uninstallyng and reinstalling the drivers for the device.
May 25, 2009 | Computers & Internet
Intel 845GVSR Sound driver problem..!
Hi...
Uninstall the sound driver installed thru the control panel.
Try this link (click me)... just download the files and install
Keep us posted if the problem still did not change.
Happy Fixya!!!
Apr 05, 2009 | Intel D845GVSR Motherboard
Hard drives
If you set it to CS and then plug it into the second connector it should be on the slave. The end one is always master. Sometimes you just have to do a trial and error deal. Go into your bios and set your hard drive dectection to auto and on your bootup screen it should show the drives. Even in the bios once it is connected right the bios will tell you where it is recognized at. If all else fails, go to www.maxtor.com and look for your model hard drive and see what the settings are there.
Jul 15, 2008 | Quantum Fireball (LM20A011) 20.5 GB Hard...
Dell Dimension 5000 Desktop
You don't need drivers for a hard drive! Just plug it in and it will be recognised by the BIOS.
The only thing you will need to do is make sure you designate it as a primary or slave drive - whatever the old drive was set to. On the back there is what looks like an eight pin plug, with a jumper across two of the pins. Depending which pins are connected will change the drive designation. There is usually a sticker next to them telling you which to connect for primary and slave.
Matt
Mar 21, 2008 | Hitachi ( 0A30229-20pk) 400 GB Hard Drive
Dvd drive
Typically the master/slave setting is done with jumpers on the back of the drive. Look at the connection at the back and look for markings for Master and Slave. If you have the manual, that will tell you too.
Feb 19, 2008 | Computers & Internet
Sony AW-Q170A-B2 DVD RW Dual Layer Burner Logo
128 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
