Question about SanDisk Memory Media
Can't play songs on favorites.
Alright this is weird because it worked before. I added songs on the 'favorites' and i dont know when but all of a sudden i noticed that the word 'favorites' was replaced and now it says 'playlist' and that there are no files on it. Also, it doesn't let me add any songs to my favorites and i have no idea how to fix this.
  • Carina Carina Jul 16, 2007
    Sandisk Sansa M240 (^_^;; sorry)
What kind of mode when you transfer the music to the player,MTP or MSC?
Posted on Feb 12, 2008
What media player are you using?
Posted on Jul 15, 2007
SOURCE:
How do I put songs in playlist on my Coby MP620 MP3 player
The Coby is weird, but I found a way to create playlists. It might not be the "real" way, but it works :)
Before I plug the mp3 in my computer I create folders containing the songs I want for each play list. For example I'd create one folder labeled "work out" for songs I want to listen to while working out, and another folder labeled "sleep" for songs to listen to while sleeping, or you could label them based on artists or genre or etc. Then I would copy the songs I want in each playlist into their respective folders.
Next, I plug my coby into my computer, and open it's folder. (should be in computers, and have a icon with a C on it). I'd copy (or click and drag into the coby folder) my play list folders (the ones I labeled work out and sleep). Then eject and remove my mp3.
If you do this, when you turn on your mp3 you should select Music. Then select Broswer (on the bottom). Select the first row, which has the symbol "\" [underneath this is all your songs] and you'll see the names of your play list folders (they'll be below ROOT, MAC OS X Coby Me, and PHOTOS) . If you select your play list name you'll see and be able to play the songs under that playlist.
Feb 19, 2013 | Coby MP620 MP3 Player
How can i download my favorite songs to my notebook? dont know where to search
You can download software for purchasing music (iTunes) and then download all your favorite songs from there. http://www.apple.com/itunes/
Hope this helps you, if not please describe your problem in detail.
Aug 21, 2011 | ASUS Eee 4G Notebook
How do you make a play list?
You make a playlist by playing a song and choosing it as a favorite/adding it to a playlist via the = button. Hope that helps you.
Mar 04, 2011 | Coby MP601 MP3 Player
Making a favourites list
hi i hope this solution helps you and works for your sandisk too.. got it from a blog post who has the same concern with the sandisk... he actually contacted sandisk customer service (email) and this is what they replied to his email...
The Sansa m200 series supports favorites and can be configured with customized playlists.
Concerning Favorites: they can be created on the mp3 player itself. Set the player in Advanced mode (menu>settings>Advanced to ON). Once a song is playing, if you press and hold the center select button, it will say, 'Add to favorites' and have a check and a X. Select the check (default) and press the center button again. To remove it from the list, press and hold again; it will ask if you want to delete; again, select the check. This will remove it from the list only; however, the file physically remains on the mp3 player. To clear the entire list, go to menu>settings>playback>clear favorites.
Note: Each time the mp3 player is attached to the computer, even if nothing is added or removed, the favorites list is erased.
Concerning Playlists:
Playlists stay on the device even if connected to a computer or if the device content is changed.
Sep 12, 2009 | SanDisk Sansa m240 MP3 Player
Favorites keeps getting wiped out
your prety much just fucked on that bro every time it doesnt shut down properly you get an error or the batery goes causeing it not to shut down properly it wippes all settings favorites equalzer shuffle mode everything just dont buy rcas they allso have a tendancy to crash permenetly the procesers burn out easely and have the worst tech support EVER
May 19, 2009 | RCA M4204 MP3 Player
Songs in My Music on LG Voyager phone will not play.
One of the files that you're trying to play on the phone is messed up. Something is wrong with it. I've seen similar things happen. Isolate the file by loading one song at a time or a group of songs, and then check to see if it's working correctly.
Feb 05, 2009 | LG VOYAGER VX10000 Cellular Phone
My digital camcorder wont play my music files!please help
Try this.Hook your Camera up to the Computer,Go to Computer and click on the Drive for your Camera.Then Drag and drop songs on to the file.If this does not work try the media player,With the snyc button at the top,And making a playlist.
Jan 28, 2009 | Video Cameras
Wanting to organize the files already on my GoGear 6GB...
no. unless your player has the feature of a favorites folder then you cannot move the songs.
Jul 19, 2008 | Audio Players & Recorders
Unable to play new songs added to MP3 player
Wal mart downloads are notorious for not working with subscription devices (i.e. - devices that use rhapsody, or yahoo.).
You have 2 options;
 1) dont use any music from wal-mart
 2) burn the music to a cd, the re-rip them to your PC, thusly removing any copy protection and then re-transfer them to your device.
Best of Luck.
Oct 24, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
My mp3 doesnt play music properly
This is caused by the ground connection from the earphone socket not making contact with the main PCB.
This can be repaired by anyone competent with a soldering iron.
The four contacts on the earphone socket need to be re-soldered.
Aug 28, 2007 | Philips SA1100 MP3 Player
Electronics - Others Logo
48 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Marvin
Marvin
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
