Question about Technics SA-DX940
WHAT IS THE VOLTAGES ON THE 3 FALT WIRE CONNECTION FROM su-X911 T
In the past week my technics twin tape deck RS-RS-X911 has stopped plying tapes in the forward direction on first the secondary deck then on the primary deck. It seems too complicated for me to see why after a little cleaning and very careful lubrication.
BUT I wanted to sort out the voltages on the flat 3 wire cable from the amplifier to the tape deck So I could psossibly take the tape deck only to a repair shop. and use a seperate power supply.
BUT both analogue and digital volt meters just donot seem to give any readings from the cable connections despite the deck is presently working on primary side where reverse replay still works.
What are the voltages for each of white wire , centre balck wire and outside black meant to be ???
What is your opinion of non forward tape play, no right hand spindle turning on each deck ???
  • errolf Jan 29, 2009
    Voltmeters digital and anlogue gives no significant readings. Are these wires a digital supply?
  • errolf Feb 04, 2009
    Yes the motors are labeled as that but my meters do not measure significant voltages although motors work OK. Why have my tape decks stopped playing tapes in forward direction?
    Sergeant:
  • 250 Answers
Its the problem of the reels which spins in the forward direction as some part is blocking it to move in forward direction.or the reels are slightly cracked.so its not functioning properly.
Posted on Feb 04, 2009
  • 6,784 Answers
You may have old rubber band belts that have lost there tension rate. this can cause slippage and prevent the motor from doing its job efficiently. if its a totally gear driven then, its you motor. it should be replaced.
  • Technics Master
  • 19,396 Answers
The voltages out from an Amp on an audio circuit are variable, that is what an amp does.
The voltages in from deck whires connected to the head is very low, you need to read it with a multimeter, the signal is not preamped and go straight to amp section, where it comes out with higher voltage.
If you send the unit for repair , better not to do any modification, and send the whole unit. You risk to damage the unit further.
Posted on Jan 29, 2009
  • Ginko
    Ginko Feb 04, 2009
    Re "Why have my tape decks stopped playing tapes in forward direction?"
    Decks use same motor for forward and rewind, if the deck does not work on forward, this has nothing to do with faulty motors or voltages, this is a mechanic problem as deck will switch motor action from forward to rewind using the deck mechanisms, prbably one of the springs or of the little tabs in deck meckanics had gone lost.
    Scholar:
  • 140 Answers
If the wire are routed from the tape deck to the amplifier (as you stated) then the voltage on these wire will not be readable on a normal multimeter. You will need an o-scope.
These are the wires sending the signal from the magnetic tape head back to the amplifier for amplification.
As far as repair goes... I don't know that it would be worth the investment. You can get a really nice dual tape deck (similar to yours) for under $100 online. You will at least spend $45 plus parts at a repair shop.
Might just be time for an upgrade.
    Brigadier General:
  • 8,619 Answers
Hi
Click on the following link its of great help :
http://service.us.panasonic.com/OPERMANPDF/SADX940.PDF
Posted on Jan 26, 2009
  • 1 more comment
  • Rylee Smith
    Rylee Smith Jan 26, 2009
    Check out the above link for the service manual, it has all the technical specifications of your Technics system and also the parts specificationslike voltage ratings, current ratings, etc.
    The voltages of white and black wires (that are inside your technics near the capacitors) are of 27mV. And check for continuity in them when mains power is not connected.
    Please revert for any clarifications.
    Thanks
    Rylee
  • Rylee Smith
    Rylee Smith Jan 29, 2009
    Voltmeters should give you a reading whether it is a digital one or analogue voltmeter/multimeter, if not then that part is faulty. Replace that part and then your problem will be resolved.
    Thanks
    Rylee
  • Rylee Smith
    And, for faulty location and its part no. refer to the service manual i posted in my first post. Please revert for any clarifications.
    Sergeant:
    Champion:
  • 242 Answers
Use a multimeter, to see what the voltages are. White usually means + and black means negative. But for some reason, they might flip them around. A multimeter will help you with.
    Top Expert:
  • Technics Master
  • 70,346 Answers
The power supply to the motor is 12 volts.
Posted on Jan 31, 2009
How do I hook up a graphics equalizer SH-GE70 to the amp SU-A707? I've already plugged in the CD player SL-PG5 and the tape deck RS-TR474M2, but can't see how to wire in the graphic. If I could...
hi,
Try this. You need 4 RCA setreo Chord for this.
1. connect the cd player out to the LINE input of Equlizer.
2. connect the Record out of equlizer to Tape's Record input.
3. connect the Play out of the Tape to the Play in of Equlizer.
4. connect the Line out of the Equlizer to the CD input of amp.
Always Select CD in the amp. And select between tape and CD in the Equlizer.
OK
Aug 22, 2011 | Technics SH-GE70 Home Equalizer
Tape deck not working on a technics rs-eh600. Small belt has slipped off, need advice in putting back on.
My tape deck is not working. When starting play it goes forward and then reverse. What can I do?
Apr 02, 2010 | Technics Audio Players & Recorders
Faulty technics rs tr333 twin cassette deck,no sound or led idications,tapes do work but nothing coming out of unit,can anyone help as i have never had a fault with the system,had unit from new its a few...
It is likely the circuitry that senses tape head output and amplifies it has failed. The part of the circuitry where heads are switched from record to playback may be at fault.
Mar 25, 2010 | Technics Audio Players & Recorders
Power to technics rs-t24 dual deck
I own a RS-T24 as well and stumbled upon this thread while searching for this exact same solution. The RS-T24 generates no power on its own. It gets its power from, in my case, the SU-V75 amplifier. I still have a working SU-V75 and got the following readings out of the plug-in for the RS-T24 on the amp:
Left = pin 1 - (white wire)
Middle = pin 2
Right = pin 3
1-2 = 11.5 vac
1-3 = 23.0 vac
2-3 = 11.5 vac
Jan 30, 2009 | Technics RS-TR272 Single Cassette Deck
Having a hard time connecting various audio components
Yes, it is a little tricky...
1) CD Changer (output) -> CD input on Amp
this is tricky... this will allow you to record to your tape deck, and control the sound via the EQ:
2) Tape Deck (tape out / recout) -> TAPE PLAYBACK on EQ
3) Tape RecOut on EQ -> Tape 1 Playback on Amp
4) Amp Tape 1 RecOut -> Tape Deck Playback / Input / RecIn
in essence, your creating a loop starting from the tape deck, going to the eq, then to the amp, then back to the tape deck to record.
Your EQ has another set of LINE IN and LINE OUT - use the second Tape 2 on the amp to create another loop. This will
allow you to control the EQ for any of the other sources.
5) LINE IN on EQ -> Tape 2 RecOut
6) Tape 2 Playback on Amp -> LINE OUT on EQ
5) Radio Tuner (output) -> Tuner input on Amp
6) DVD/VCR Combo Output -> AV/AUX on Amp
7) PC Computer... you don't have room for this. You can either use the PHONO input, and you'll have to purchase a Line Level Phono Converter
or, get a Y cable and split the signal and share with some other source.
Hope this helps.
- OPTiC
www.djproaudio.com
www.repairny.com
Dec 13, 2008 | Technics SH-GE90 Home Equalizer
Connection between CD, EQ, SP technics
Each unit (the EQ and the Processor) should have left/right in/out rca jacks as well as L/R tape in/outs. The EQ or processor use the receiver's tape loop and then provide a tape loop to replace the one they've used on the receiver.
You plug the first unit (let's say the Sound Processor into your receiver/amp as if it were a tape deck (Processor's outs connect to reciever's tape ins (play) while the Processor's ins connect to the receiver's tape outs (record).
Then you chain the EQ off the Processor in the same way (EQ outs connect to Processor's tape ins (play) and EQ ins connect to the Processor's tape outs (record).
Last you connect the tape deck to the EQ as follows. Tape deck outs connect to EQ's tape ins (play) and the tape deck ins connect to the EQ's outs (record).
This will put both the Sound Processor and the EQ in the receiver's tape loop. In order to have all the receiver's source signals routed through them you may have to engage a Tape Monitor switch or button somwhere on your amp which will route the tape loop to your speakers.
Jan 09, 2008 | Technics RS-TR272 Single Cassette Deck
Help
Just connect you EQ to your receiver as if it were a tape deck: EQ's outs connect to receiver's tape ins (play) and EQ's ins connect to receiver's tape outs (record).
Then you hook the tape deck up to the tape ins and outs on the EQ: Tape deck outs connect to EQ's tape ins (play) and tape deck ins connect to EQ's tape outs (record).
This will put the EQ in your receiver's tape loop. To hear the EQed signal with all receiver sources you'll need to engage the 'Tape Monitor' button or switch which will route the tape loop to the speakers.
Nov 22, 2007 | Technics RS-TR272 Single Cassette Deck
Technics SA-DX940 Logo
140 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
